Question about Samsung ML 2010 Laser Printer
Samsung 2010 Where is the ink cartridge located? and how do you replace it? I am crazy trying to figure out where the ink cartridge is. Please help.
  • genarolara Sep 27, 2007
    Thanks for your response. I believe I got it. I was looking for a little square item, but it appears that the ink cartridge is a big long piece that sticks in all the way across and is attached to the tongue looking flap. Genaro Lara
  • 33 Answers
Hi, I have one of these and can be a little complicated if you haven't had it from new. First, looking at the printer face on place a hand on each side of the printer as marked 'A' in the picture. Grip, pull and the front of the printer will hinge down towards you. Now you will see a black tongue-like plastic handle as marked by 'B' on the picture. Grip with one hand and pull towards you and the whole cartridge will come out ready to be replaced. Hope this helps. Si :)
Posted on Sep 26, 2007
  • Simon Lasota
    Simon Lasota Sep 27, 2007
    Im sorry, but I fail to see how me telling you how to remove the cartridge is classed as 'almost there'? I even made a diagram to show you how to remove it,as you recall i said to pull, and the 'whole cartridge will come out.This is true, the 'tongue looking flap' is part of the cartridge and will need to be replaced with it. I feel that this is ungrateful, and obviously my time will be better spent on genuine peoples problems in future.
SOURCE:
I refilled my toner ml 2010 when i print the right side of the page is very light hardley any ink
You need to clean the ink cartridge. Check for software on you computer under programs. You could also put some rubbing alcholol on a parer towel and lightly rub the print heads clean.
Jun 15, 2011 | Samsung ML 2010 Laser Printer
Hello! My Samsung ML 2010 Laser Print has started to print pages with streaks of ink across them. This makes the pages more difficult to read, and certainly cannot be used for formal letters. It also...
there must be waste toner in your toner cartridge
the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
Jan 26, 2011 | Samsung ML 2010 Laser Printer
4110 officejet series all-in-one error message saying i installed incorrect ink cartridge? what do i do? it is the correct one
Supported HP Inkjet cartridge part numbers The HP Officejet 4100 all-in-one series products use the ink cartridges listed in the table below. HP Inkjet cartridges HP 56 black cartridge (19 ml) HP 57 tri-color cartridge (17 ml) HP 28 tri-color cartridge (8 ml) Replacing the ink cartridgesThe power must be turned ON to the all-in-one or the print carriage will not move to the right.
  1. Locate and open the print cartridge access door on the right side of the all-in-one. The print cartridge carriage will move to the right for access. Figure 1: Opening the HP Officejet 4100 seriesc00121089.jpg
  2. Press down gently on the top of the old ink cartridge to release it from the print carriage. Figure 2: Removing an ink cartridgec00121090.jpg
  3. Remove the new print cartridge from its packaging and remove the protective tape from the cartridge as shown in Figure 3. Do not touch the gold-colored contacts. Figure 3: Removing the cartridge tapec00121091.jpg
  4. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage and press them into position as shown in Figure 4. If the cartridge does not snap easily into position, it is not aligned correctly. Remove the cartridge and reposition it. Do not try to force the cartridge into position. The black ink cartridge (HP #56) goes on the right side and the color cartridge (HP #57 or HP #28) goes on the left side. Close the ink cartridge access door when the ink cartridge has been installed. Figure 4: Installing the ink cartridgesc00121092.jpg
  5. A message will appear on the front panel requesting that the ink cartridges be aligned. Follow the steps below to align the ink cartridges:
    1. Press Enter on the all-in-one front panel to start the ink cartridge alignment process.
    2. After the Alignment page prints, place the page into the ADF upside down and with the printed side down as is shown in Figure 5.
    3. Press Enter. The all-in-one will scan the alignment page and finish aligning the cartridges.
    Figure 5: Aligning the ink cartridgesc00121093.jpg
Correcting error messages that appear after changing a cartridgeAfter inserting the cartridge, the Check Print Cartridge light flashes or one of the following messages appears on the computer monitor:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth slightly dampened (not wet) with clean water. (See Figure 6) Each contact is very small and shaped like a rounded square. Figure 6: Cleaning the cartridge contactsc00121094.jpg
  8. Allow the ink cartridge to dry for a few minutes before reinserting the cartridge(s) and turning on the printer.
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, the unit may need to be serviced. Contact HP for further troubleshooting or to arrange to have the unit serviced.
Make sure what ur using isn't a refilled cartridge and if it is check the expiration date, if nothing is wrong then you need to get urself a new printer or an upgrade so call up hp at 1800-474-6836 and get help of them,they'll guide you to a new /upgrade printer.
it's not a nice way of saying it but someone has to give you the bad news
Feb 01, 2010 | HP Office Equipment & Supplies
Ink cartridge problem( s) appear to be missing or damaged
hi there,
Ink cartridge Problem
Cause : The indicated ink cartridge(s) are missing or are damaged.
Solution : Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-one, the ink cartridge contacts might need to be cleaned.
IF there is no ink cartridge missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Replace the ink cartridge.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 26, 2009 | HP Photosmart C6280 Printer
Start with orange turning red
if you have old toner cartridge use it to test. if the problem persist again - > check cartridge connectors inside (they should be upstanded)
Sep 30, 2009 | Samsung ML 2010 Laser Printer
"Print carrier stall"?
Error 0502-Carrier Stall indicates a physically blocked carrier. This condition can occur for many possible reasons. Most often, the carrier is blocked because the ink cartridge lids are open while the printer is on (Figure 1).
Figure 1: Open Ink Cartridge Lids
Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
    new_note.jpg Note: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press Select.
new_note.jpg Note: For more information about reseating ink cartridges, refer to the Maintenance or Ink Cartridge Maintenance section in the Online User's Guide.
Back to Top
» Reposition the Encoder Strip
  1. Remove the power cord from the printer.
  2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
  4. Gently move the top part of the printer belt to the right.
  5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    Figure 1: Inkjet Printer Encoder Strip
  6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
  7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
  8. Once the encoder strip has been re-seated, close the scanner lid.
  9. Re-connect the power cord to the printer.
Jul 18, 2009 | Dell 922 All-In-One InkJet Printer
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  2. Remove the ink cartridge indicated in the message and inspect it.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
Changing cartridges
Did you get the answer for how to replace the ink cartridge, because I don't have a manual myself and I can't even figure out where the ink cartridge is located?
Dec 11, 2007 | Office Equipment & Supplies
Samsung ML 2010 Laser Printer Logo
55 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
