Question about Kenwood Car Audio & Video
Installing kdc-bt31ou with a pac c2r-gm32r housing mudulator into an 2000 buick lesabre
SOURCE: 2000 buick lesabre stall after starting or after running for 30 minutes
I have a 1996 Lesabre. I had a similar problem that slowly got worse. I brought it to two different mechanics that did diagnostic checks and could only "suggest" what to replace to fix the problem. Their problem was that it wouldnt stall out while they had the mv. After replacing a bunch of sensors and the fuel pump/ filter, I solved the problem by replacing the Crank Sensor. Its located behind the lower crank pulley on the 3.8 lt motor. Hope this helps!
Posted on Oct 29, 2008
erietrack
  • 37 Answers
SOURCE: 2000 Buick LeSabre Struts
Yes there are struts on the front and shocks on the back. 2 of each. They are around $50-100 for the fronts. $30-100 for the rears depending if the car has air ride or not.
Posted on Nov 08, 2008
  • 975 Answers
SOURCE: Can't find the pcv valve on a 2000 Buick LeSabre.
assume this is a 3800,pcv is on pass side of plastic intake manifold,small plastic locking collar has an arrow on it ,says pcv
Posted on Mar 01, 2009
ButtFuzz
  • 463 Answers
SOURCE: PCV location on a 2000 buick lesabre
Open hood, top left side between the valve covers. There is a "funky" plastic housing that turns counter-clockwise (less than 1 inch of travel). then pull straight up to reveal the "missing" pcv valve.
Posted on Mar 05, 2009
  • 106 Answers
SOURCE: 2000 buick lesabre - water pump replacement
first disconnect the battery then check how the serpentine belt is lined up so u can take it off and put back on. Then the pump should be on the side of the motor with 9or12 bolts there could be more! after taking out take razorblad and skrap the old gasket clean wipe of then put new gasket and pump back on dont over tighten the screws cuase the pump my be aluminum.
Posted on Mar 19, 2009
How to install a ignition module buick lesabre V6 3800
1A Auto shows you how to remove, install, repair, or replace your broken misfiring or damaged ignition coil. This video is applicable to Buick LeSabre 2000-2005.
Nov 03, 2012 | 2001 Buick LeSabre
Tip
How To Install Replace Cabin Fresh Air Filter Buick Lesabre 2000-05 1AAuto.com
on May 08, 2012 | 2003 Buick LeSabre
Tip
How To Replace Install Front Brakes 2000-05 Buick Lesabre 1AAuto.com
on May 08, 2012 | 2005 Buick LeSabre
I installed a kenwood dnx 7180 in a 2009 jeep wrangler x, with a pac c2r-chy4. everything seems to work great except i do not hear any voice promt from the navigation, just hear the music mute. checked the...
It's your c2r-chy4. You need to hook the front speaker output from the nav to the rear input of the c2r. I had the same problem. The c2r only receives input through the rear speaker wires (purple green) Don't ask me why they did it this way but it's a common problem with this adapter. The nav sends it's voice promps through the front speakers only that's why you cant hear them. Connect the white speaker wires from the deck to the green of the c2r and the gray to the purple. Cap off all remaing wires. You loose the fader but oh well. Enjoy!
Apr 16, 2011 | GPS
I have a Buick lesabre 2000 on the rear view mirror it has symbols for farenheit and celcius so how do I display the temperature?
Hello: There is a small hole on the bottom of the mirror housing, stick a wire about the size of a large paper clip and push and you will be able to scroll through different selections.
Feb 14, 2011 | 2000 Buick LeSabre
Where is the thermostat of the buick lesabre 2000
follow the top radiator hose to the engine. The thermostat housing is at the end of thst hose.
Jan 04, 2011 | 2000 Buick LeSabre
I havbe a 2000 Buick LeSabre Limited with the 3800
It's on the housing the oil filter is screwed on to.
May 30, 2010 | 1998 Buick LeSabre
02 bonneville. Stock radio has power, but i install my pioneer and no power. I did use a wire harness.
With the stock radio installed, turn on your parking lights and listen for the chime (same sound for key in ignition with ignition off and door opened). Does the sound come from the front left speaker or from behind the dash? If it comes from behind the dash, disconnect factory stereo and turn lights on again, id the chime still there or does it go away? If the sound comes from the left front speaker or goes away when you unplug the factory stereo, you need a different harness, its called a chime harness Pac Audio part #C2R-GM32R, could be the thing you need.
Mar 01, 2010 | Car Audio & Video
Where is the battery located in a buick lesabre 2000
it's under the back seat in the passenger side. the driver side houses the fuse box.
Feb 23, 2010 | 2000 Buick LeSabre
Mar 05, 2009 | 2000 Buick LeSabre
Car Audio & Video Logo
27 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
