Question about Therapure Four Person Inflatable Round Hot Tub
My Therapure four person inflatable suddenly stopped working. electrician says outlet and breaker are fine. I can get the plug to blink red but then it throws my breaker. no luck with 1 800 #
  • 1,631 Answers
Unfortunately, these Toy Spas do not give you the ability to make repairs to their components! Including the heater, so no ability to replace an element.
For a failed heater, it appears that you have to replace the complete control center. Because parts are extremely to impossible, to obtain.
Contact them, and do some squeaking, maybe they will oil that squeak?
Look here...
www.intexcorp.com/support
Posted on May 06, 2015
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
It is more than likely your heating element. Not sure what style they use but if you send me a pic of your equipment, spa pack w/ the cover removed, I can walk you thru how to test it.
If you have a good grasp of electricity, find the heating element and with the power off remove the leads. Try to plug it back in, reset the gfci, and give it a minute. If it doens't trip and everything runs fine replace the heating element. With most spa packs it is possible to replace only the element, some like watkins you have to replace the whole heater. If the spa still trips with the heater disconnected start unplugging your equipment starting with the ozone, then blower, then pumps, one at a time until your braker stays on.
Posted on Oct 27, 2013
Looking for inflation hose for model #5868.5880 or 5870
I don't know if you have found one but I have all the parts to mine. I have just run into it issue where the heating element I believe is not working.
May 18, 2016 | Therapure Four Person Inflatable Round Hot...
How to deflate and store
DRAINING THE SPA:
1. Unplug power pack from electrical receptacle before draining spa.
2. Put the rubber plug into the outlet in the inner wall of the spa.
3. Open the outlet in the outer wall of the spa. Screw one end of inflation hose into it.
4. Remove the rubber plug from the outlet in the inner wall of the spa.This will allow water to flow out of the spa. 5.When water is completely drained, press BUBBLE and run for 2-3 minutes to drain the water in the air pipeline. 6.When drainage is finished, remove the inflation hose and replace cap on outside of spa. Store rubber plug for future use.
SPA STORAGE
Make sure all water is drained from the spa and control box.This is essential to extend the life of the spa.We recommend the use of a wet/dry vacuum to blow out or suck up water from the spa pipes and pump lines. Remove the filter cartridge. It is recommended you store the spa in its original package in a warm, dry place.
Note: Plastic becomes brittle and susceptible to breakage when exposed to subzero temperatures. Freezing can severely damage the spa. Improper winterization of your spa may void your warranty.
http://img1.wfrcdn.com/docresources/17478/11/119999.pdf
Aug 13, 2014 | Therapure Four Person Inflatable Round Hot...
How to change a heating element in therapure spa?
I don't think you have a heater element?
It might be heating by kinetic energy/heat exchanger/heat transfer by the operation of the pump motor?
Jul 16, 2014 | Therapure Four Person Inflatable Round Hot...
Plug in cord got wet
Use a hair dryer & dry it out completely.
Good Luck
Jul 15, 2014 | Therapure Four Person Inflatable Round Hot...
The plug in cord got wet need to fix it. Is their a fuse or something in the controller?
Sorry, but you do sound competent to attempt repairs. Hate to see you get hurt. Call a pro.
Filter won't turn on
Sorry to tell you but this is a common problem with this unit. Parts will have to be replaced and they are hard to find.
Apr 24, 2014 | Therapure Four Person Inflatable Round Hot...
Wont heat up
other than the heater having a fault inside of it (common problem) the only thing that a user can do is to make sure it was proper power connection (outlet is live) and make sure it has good flow thru the heater , as they do have a flow switch that prevents heater from coming on if water flow isn't enough(safety sensor)
Mar 22, 2014 | Therapure Four Person Inflatable Round Hot...
HOW TO DEFLATE THERAPURE SPA
fastest way is use a wet/dry shop vac , just place the tip of hose over inflation valve and it will draw air from walls (fast!!)
careful if using a home vac system , as some water might be inside walls and home vacs don't like that too much , wet/dry shop vacs are best 4 this
Dec 21, 2013 | Therapure Four Person Inflatable Round Hot...
Outlet and ceiling fan stopped working
If it's not the breaker then I would call an electrician.
Jul 14, 2013 | Dryers
Therapure Four Person Inflatable Round Hot Tub Logo
617 people viewed this question
Top Therapure Pool & Spa Experts
Raymond Richards
Raymond Richards
David Harrelson
David Harrelson
Tom Chichester
Are you a Therapure Pool and Spa Expert? Answer questions, earn points and help others
