SOURCE: resetting the atomic clock to the correct time zone, and outside temp to work.
For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
Good luck,
Doc
SOURCE: how do I get the
Hello jdb..... The outdoor transmitter needs to undergo a wee bit of maintenance. Remove those new batteries and clean the battery contacts with the eraser on the end of a common pencil. Then replace the batteries. IF you notice that the batteries slide in easily, use a small flat blade screwdriver to gently lift the battery contacts to increase the contact when you do slide the new batteries in. Joe
Thanks for choosing Fixya!
SOURCE: I have a brown Sharp Atomic clock Model SPC900.
You can get a manual at:
http://office.manualsonline.com/manuals/mfg/sharp/spc900.html/type/product_problem
