Yamaha psr gx76
The "Touch-Sensitivity" has quit working. Is there anyway that can be repaired?
    New Friend:
  • 19 Answers
Restart your computer.
If still not work, set it on control panel
Posted on Oct 21, 2013
2 Suggested Answers
  • 59 Answers
SOURCE: yamaha psr-gx76
when i checked for a manual for your product it came up as musical keyboard not a computer keyboard so if it's the manaul to the muscial keyboard you want here is the link.
http://www.yamaha.co.jp/manual/english/result.php?div_code=emi
type in psr-gx76 into the search then it will show up in the results as pdf file, this is adobe file and will open with that program and most computers have it installed.
hope this helps.
Posted on Oct 14, 2008
Yamaha psr-gx76 keyboard-sound comes through headphones. Does not come through speakers.
Try cleaning the headphone jack. If that doesn't help, it'll be the amplifier board and will need to go to the shop.
Aug 14, 2015 | Yamaha Music
I have a Yamaha PSR-S700. Recently, the touch sensitivity in one of the keys stopped working. Very little pressure applied would cause the note to sound as if the touch sensitivity was off completely. Now...
You MAY be confusing touch sensitivity with VELOCITY sensing. Touch sensitivity is PRESSURE put on AFTER the note sounds that causes modulation. VELOCITY is what is used for example to control the loudness of pianoo notes depending how fast they are struck. VELOCITY sensing is done by using TWO contacts at every key... one closes first. IF one of these gets dirty, FULL velocity will be sensed and it will be LOUD. The contacts can be cleaned using ONLY 99% isoprophyl alcohol and Qtips after MUCH disassembly of the keyboard. The contacts are conductive rubber pills in silicone rubber domes. Clean boththe contacts and the circuit traces they pres down onto.
Apr 02, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
Am looking for a power supply board for yamaha keyboard
Normally if the board is there, I repair failed components. If the board is missing, call Yamaha America parts dept. They MAY have the part you need. That will be the only source of a complete replacement. Power supply boards are usually easily repaired.
Mar 04, 2011 | Yamaha PSR-295MS Portable 61-Key...
The keys are broken and some at no sound can I order the notes and sound kit. Yamaha PSR-295 . Regards Elias
Hi, i think you can. You can go to any of the Yamaha companies around you area and explain to them the problem of the keyboard. They will give you good and quality replacement part for your Keyboard.
Make sure you go to only Yamaha company to avoid getting a wrong part for your Keyboard.Avoid road siderepairsforissue like this,it's more complicated to handle
I guess that will do.
Thanks for using fixya...
Jan 12, 2011 | Yamaha PSR-295MS Portable 61-Key...
Yamaha PSR-79 keyboard fried fuse
i have the same problem please someone help us.
Sep 10, 2009 | Yamaha Portable Keyboard with 61...
Yamaha PSR-GX76 musical keyboard problems
Does it have onboard speakers?
If so, try to tighten down (fix firmly in place) the wire mesh that protects the speakers, if it's loose, it will vibrate and cause distortion in the sound.
I once had to repair a portasound which sounded really crappy when a group of keys was struck at high volume, and it would only calm down when i fixed the speaker mesh so that it didn't vibrate with loud sounds.
You may want to put some rubber or similar into the groove where the mesh edge fits in to prevent it from vibrating (i solved mine just by tightening up the mesh strips where they protrude into the housing).
If this doesn't help, then it's something else (possibly a bad or dirty connector contact or a bad solder contact).
regards
3rq8 (Triarcuate)
Jul 30, 2009 | Music
Yamaha psr-gx76
hope this helps.
Oct 14, 2008 | Yamaha Computers & Internet
Computers & Internet Logo
David Payne
David Payne
