Question about Locks & Locksmithing
BTW . . . Transmission problem is with a Simplicity Regent 500, Mfg #1693528 with Hydrostatic Tuff Torq K56 tranny.
    Problem Solver:
  • 5 Answers
Change betters then reset code
Posted on Oct 22, 2013
Oil type in hydro tranny
Owner's manual, no manual, try MFG website, or email their customer service, or try manualslib.com
Apr 14, 2015 | Garden
Diagram for hydrostatic drive
Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one.A short description of the events preceding the beginning of the problem is also helpful.
The NOT SERVICEABLE UN-TRUTH.
The Huskvarna YTH150 uses Hydrogear transmission 319-0650, drive model 150071. One place to find parts and diagrams for most Huskvarnas is here: http://www.m-and-d.com/Hydro-Gear_parts.html
MTDs use Hydrogear trannys also. Go to the site and enter 618-0319 in the search box. It will bring up a selection of MTD transmissions.
Sears Craftsmen mowers also have trannys from Hydro-Gear.
The best lawn tractor Hydrostatic Transmission Fluid isactually 10W-50 synthetic motor oil (like Mobil 1). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Most of them are made by one or two manufacturers. Tuff Torq makes a lot of them, but not the Huskvarnas. They do make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, an untruth. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. They have a lot of good general info for anyone rebuilding their tranny.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like Mobil 1™). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black drain plug on the top, if they do not have the add on reservoir. You have to remove the tranny from the mower (not a difficult things to do, it takes about 30 min). Pull that black plug (I used a 1" putty knife to pry mine out) and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out; clean it and replace it. It may fall out while the tranny is upside down.If anything else falls out, you have a broken tranny and will have to take it apart.
When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
Tuff Torq Lawn Garden
Apr 07, 2015 | Garden
MTD 918-0319 Hydrostatic Transmission is it a sealed unit or do you add grease
you add hydrostatic fluid through the filler hole
Oct 03, 2014 | Garden
What type of oil for hydrostatic drive?
Hydrostatic Transmission Fluid is actually 10W-50 synthetic motor oil (like mobil). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Many of them are made by the same manufacturer. Tuff Torq makes a lot of them. They definitely make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, a lie. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. It's quite likely they made your tranny too.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like mobil). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black plug on the top. You have to remove the tranny from the mower (not a difficult things to do, takes about 30 min). Pull that black plug and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out, clean it and replace it. It may fall out while the tranny is upside down. When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
Sep 25, 2014 | Husqvarna Garden
What oil do I use in my ***** hydrostat?
Sep 25, 2014 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
What can I use for transmission fluid for my Cub Cadet tractor?
If your unit is a Hydrostatic model, Universal transmission fluid should work just fine. The proper type oil type should be listed in your operators manual and the hydraulic oils you see on the shelf will have the viscosity ratings listed. Just match the ratings to your model and you will be fine. Best Wishes
Sep 01, 2014 | Garden
Tuff torq k51
https://www.tufftorqservices.com/EnvEEdefault/FlatHTML/Troubleshooting/Diagnostic_Flowchart_EN_23DEC08.pdf Hey, check out the manufacturers trouble shooting chart. This is a hydrostatic not a geared transmission right?
Apr 09, 2014 | Garden
Finally decided to follow the manual's recommendation and changed the transmission fluid (SAE 10-W-30) while doing an end of season overhaul. Engine runs fine, but no forward or reverse. Over the last...
Did you loose forward and reverse right after fluid change or was it gradual? Sounds like you have air in the system. I would jack up back end and leave fluid fill cap off overnight. Maybe lay a light rag over it to keep debris out, but with the cap off and back end jacked up it should help air bubbles find there way out. Then, replace cap, leave jacked up and try bleeding by forward and reverse. Hope this helps.
Oct 19, 2013 | Garden
Husqvarna hydrostatic transmission
my transmission on the right side do not have the power the lifr side have what do i need to do to fix it
May 14, 2013 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Locks & Locksmithing Logo
85 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
