Question about Dynasty DGRSC 48-6G Gas Kitchen Range
Viking oven broiler will not ignite - Dynasty DGRSC 48-6G Gas Kitchen Range
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Your gas valve would be my first guess. Is this broiler (and bake ) lit with a glow coil or spark probe that goes (goes click, click, to light)??
If spark probe, you will have to replace either gas valve or spark board.
If glow bar lights the broil but does not glow, then replace glow coil.
Posted on Oct 19, 2013
Viking VGIC oven burners ignite but cycle off repeatedly temperature rarely gets to 300 after 30 minutes. If igniters ignite is problem elsewhere - like bad bi-metal valve? Range and broiler work OK,
There is a sensor that detects the oven temperature, it must be defective and sending a signal that oven is at set temperature and this shuts off the gas valve.
Nov 02, 2016 | Viking Kitchen Ranges
Viking VGSC3676BSS oven wont light
Check the igniter and the burner near it - you may just need to clean it. If you try, you can probably even get to some point where you can observe whether the igniter is sparking in the gas path or not.
You may also be out of gas, the burners just running on the last dregs of gas in the pipes.
Aug 12, 2014 | Viking VGSC3676BSS
Broiler won't light on a vgic36. Smell gas
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 13, 2010 | Viking Ovens
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
Oven and broiler won't come on
It's most likely the igniters in the oven. They cost about 40$ apiece and our oven has two. They are fairly easy to replace.
1) Turn off the electricity to the stove, either with a switch or your circuit breaker.
2) Remove grills, side support grills and oven base. They all just slide out.
3) Remove door to avoid breaking it. It slides off.
4) Remove old igniters, they are attached with two screws. Remove 2 wires from plugs. It might be necessary to lower the front base panel to get to the plugs - the panel is attached by two screws on the side of the panel.
5) Install new igniters, put the door and grills on and you're good to go.
The first time, it might take an hour to get used to your stove, but its really about 15 minutes of work.
Jan 13, 2009 | Viking VGSC306-4B Gas Kitchen Range
Viking pro. gas range/oven leaks when all knobs turned off
check both oven ignitor and broiler by turning the oven first, and time the time that the ignitor takes before the flame lights up, it should not take more then 60 to 70 seconds, and do the same to the broiler.the one that takes the longer passing that mark of the 70 seconds needs replacing it 's not getting hot enough to light the burner on time that's the one that passes gas with out igniting. replace that one.
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Viking stove
no the termostat but the ignitor that's the part that's nest to the broiler burner. the part that ignite the flame. when you turn on the broiler the ignitor becomes red like a glow.
Nov 25, 2008 | Viking VGIC305-4B Gas Kitchen Range
Dynasty DGRSC 48-6G Gas Kitchen Range Logo
152 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal DeAngelo
Jaime Hernandez
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
