Question about Hotpoint RVM1435 Microwave Oven
I'm getting a F3 code, what does this mean? - Hotpoint RVM1435 Microwave Oven
I have Amana microwave hdc182 displaying f3 code what dose this mean?
According to the tech info manual, when you get a code F3 you need to replace the HV/LV board. Here is a link to the manual for your reference.
Jul 02, 2015 | Amana Microwave Ovens
Get F3 warning on panel. where are the codes located so i can see what the problem is, thank you JOHN BOMSA
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Feb 01, 2011 | General Electric PEB1590SMSS Stainless...
About 1 hour into the 4 hour clean cycle an alarm started gong off. Code is F3. Frigidaire smooth top electric slide in stove.
The F3 code means
The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. Check oven temperature sensor, 1100 ohms Good Luck
Nov 27, 2010 | Microwave Ovens
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    It has an f3 code on it what ledoes it mean
    F3 means fault code number 3, I think this is Power Supply, or Magnetron.
    Feb 09, 2010 | Samsung MW1030WA Microwave Oven
    My ge microwave is showing a code of F3. model JES1034 what does this mean?
    hello there
    Tthe f3 code is referring to a faulty touch pad which may need to be replaced i would contact the manufacture of this microwave for a parts replacement
    Jul 29, 2009 | GE Microwave Ovens
    Spacemaker Microwave Oven
    F3 means shorted key panel. You get prompted with F3 error if a short on key panel is detected for over 60 seconds.
    Test key panel wiring and eventually replace key panel.
    Enter the model number on one of two websites below to get parts and diagrams for your appliance:
    Appliance Parts From PartSelect
    Appliance Parts Pros
    May 17, 2009 | GE Spacemaker JVM1750 Microwave Oven
    F3 Error Message
    the code means this.
    F3 Shorted touch pad panel
    Good Luck
    Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    F3 Error Message
    It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
    Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
    Microwave malfunction
    On a GE microwave F3 means you have a failed keypad.
    We replace these for customers nationwide with our guaranteed $39.95 service.
    If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
    Please feel free to contact me directly if you need more help.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    William E. Miller, AS-EET
    prototech@usa.net
    http://www.microwavedisplay.com
    May 29, 2006 | GE JVM1861SF Microwave Oven
    Hotpoint RVM1435 Microwave Oven Logo
    26 people viewed this question
    Top Hotpoint Microwave Ovens Experts
    William Miller
    William Miller
    Jim Thurston
    Jerry Greenberg
    Jerry Greenberg
    Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
