Question about Galaxy Ac-1 Door Lock Actuator
I have a 2002 dodge ram 1500 4.7ltr 4 door quad cab truck a/c and blower motor are working but cant get air through vents was told blend door actuator may not be working where is it and what does it look like thanks
Those doors are controlled by whats called vacuam hoses that force air to the doors that control all the selections of the vents on dashboard. the flipper door that changes the floor to defrost is usually located on passenger side up under dash. the actuator valve would be right around there and there should be a vacuam hose about 3/8 in diameter going to it. the flipper door will be insde the big air vent coming through the fire wall to floor vent
Posted on Nov 27, 2013
Heater only blows out defrost
The defrost position is the default for safety so that air always blows on the windshield in case of frost.
The most common problem is a faulty blend door under the dash.
In most cases the door must be calibrated with a scan tool if you replace it.
Feb 18, 2013 | 2002 Dodge Dakota Club Cab
Fan for heater in 2002 dodge ram stopped working?
Check for a blowin fuse or a defective relay, If there good the blower motor is shot, End will need to be replaced,
Nov 28, 2012 | MTX Dodge Ram Quad Cab 2002-2003...
Heater blend door actuator
The blower will supply air no matter where the blend door is positioned, it will be hot cold or somewhere in between but you will have full airflow, so the blend door or the actuator is not the problem. Find the air intake for the blower (at base of windshield) and make sure it is not full of leaves or if you have a passenger cabin air filter (commonly called a pollen filter) it is not plugged up.
Jan 25, 2012 | 2000 Chevrolet Impala
My 2007 Dodge Ram 1500 seems to not be pumping heat from the floor vents, only the dash and defrost vents. Could it be a problem with the blend door? if so where do i find it and what should I do. This...
Yes, it's a blend/mode door problem. Seems like it was pretty common for a few years. I've heard that Dodge has switched manufacturers for this part.
There's no easy fix for this. The dash and the hvac box have to be removed to get to the blend doors. You also have to disconnect the A/C lines and then recharge them...
Any chance you're still under warranty?
Here's a link to a website that has info and parts about the issue. (no affiliation)
http://www.heatertreater.net/Ram%2002-08%20Listing.html
Jan 28, 2011 | 2007 Dodge Ram 1500 Quad Cab Sport
I have a 2002 dodge ram quad cab and i haveing problems with the heat , it wants to blow hot air only on passanger side only and driver side is cold
Hi, check the air vent doors make sure they are not broken and the door motor is working, they have a bad problem about breaking . if i can help just re post .
Thanks dodge tec
Jan 03, 2011 | 1999 Dodge Ram
2004 Dodge Ram 3500 Turbo Cummins diesel, air conditioning is cold but there is very little air pressure even when turned on high, fan sounds like it is blowing like crazy but very little air movement...
Sounds like the "Blend Doors" are not completely closed (or opened). The Blend Doors open and close to direct the air from the blower motor to the vent selection you have made on the control panel (defrost on windshield, floor, front, etc) You may need to try various selections to see if the blend doors actually open or close. If no changes, it could be a blend door actuator failing.
Aug 05, 2010 | Dodge Ram 3500 Cars & Trucks
2003 Dodge Ram 1500 quad cab. While replacing a
it may be the switch itself they do go bad.Otherwise he could have pinched a hose or left one off. But it sounds like he is trying to help.
Feb 11, 2010 | 2004 Dodge Ram 2500
Galaxy Ac-1 Door Lock Actuator Logo
43 people viewed this question
Top Galaxy GPS Experts
Are you a Galaxy GPS Expert? Answer questions, earn points and help others
