Question about Exercise & Fitness
Repco RP300 treadmill with error 2 message - Exercise & Fitness
SOURCE: Repco Sports Treadmill
Repco RP300TM wont start E1 error message
Posted on Jul 14, 2011
SOURCE: repco fitness Treadmill error E7
This happened to mine, e7 is an error in the incline, meaning that the incline is too high or too low in the accepted range for the starting position of the treadmill. When the treadmill starts it looks to see if the incline screw shaft of the incline motor is in the correct position. If it isn't it gives the error message and shuts down. This happened to us after we had moved and the treadmill was bumped around a bit, this caused the incline worm shaft to move out of position, and that is why we got the error message.
To fix the problem I just took the cover off the motor area of the treadmill (WITH THE POWER OFF AND CORD DISCONNECTED) and located the incline motor, it has a threaded rod and a big nut coming along side the motor itself. It is the smaller motor. On the end of the threaded shaft is a plus sign cut into the shaft, so that you can insert a philips head screw driver into it and rotate the shaft. The shaft will rotate easily in one direction. Insert the screw driver into the end of the shaft and rotate the shaft so it goes as far into the big nut holding it as you can, don't twist it tightly, just make sure that the shaft has gone all the way in without binding, it still needs to rotate freely in and out. Put the cover back on and then switch it on. The treadmill should now start right up.
Posted on Nov 24, 2011
ercupa190
  • 12223 Answers
SOURCE: I have an Ironman 320t treadmill and received the error SI 2. What is the issue and what can be done to correct? The treadmill will not run.
you have a problem with over voltage.
Test you outlet wall. use some voltage regulator.
God bless you
Posted on Nov 24, 2012
ercupa190
  • 12223 Answers
SOURCE: Need manual for RE1000 treadmill
please download from the website www.manualslib.com
God bless you
Posted on Dec 15, 2012
Repco rp300tm
1) reset the treadmil.2) adjust the speed sensor, see the diagram attached. 3) Run the software calibration for easy diagnostic and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button 31d332da-cd1c-4885-8ae4-393941ca1930.gif
Oct 18, 2013 | Proform Perspective Es Treadmill PFTL99806
God bless you
Dec 15, 2012 | Exercise & Fitness
How do you get into the service menu of a precor 932i treadmill?
Typically on the Precor Treadmills if there are errors on the unit, you can press and hold the stop button for 3-5 seconds and it will go into the error log. Not sure what model you have.
E-2 is not what normally shows up on the screen. Do you mean Error 2 was displayed? From what I have read on Error 2's it could be a upper PCA issue, or possibly a dip in AC input during the power up sequence.
Treadmills require a dedicated line, meaning it is on its own dedicated circuit on your fuse panel/circuit breaker.
What exactly is the treadmill doing? Is it constantly showing Error 2 on the screen? Call up Precor tech support. They will be able to give you advice, and or get you connected with an authorized Precor factory trained technician who will be able to get you back up and running.
Nov 07, 2012 | Precor 932i Treadmill
Repco fitness Treadmill error E7
Mar 26, 2011 | Exercise & Fitness
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
Jul 15, 2009 | Exercise & Fitness
Faulty Repco sports treadmill
Not really familar with this brand but if it has a safety key, check to make sure it properly inserted and making proper connection.
Jun 05, 2009 | Exercise & Fitness
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Exercise & Fitness Logo
32 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
