Question about Whirlpool RBS245PDS Electric Single Oven
I get and E 1 F 5 error code and the door locks
What does error code F-90 mean on a Kenmore delf cleaning wall oven
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure. This type of diagnosing will require accessing the lock assembly & using a volt/ohm meter for testing
Nov 03, 2016 | Kenmore Ovens
Oven is locked
Door locked usually pertains to a self clean problem kill power to unit either unplug or breaker as soon as unit has power it is programed to activate door lock motor if cannot do that you will get and error code on display, if no error code press off/cancel off/cancel start might have to do it a few times depending on display either press 3 or 6 to advance to errors or ^ or the other one down can't find it on the keyboard same thing scroll to codes follow prompts if you have and older unit on the oven door there are vent holes at the top you will see what looks like a rod with a hook take a screw driver and push it upwards till door opens dont worry about scratches you own in once door is open leave open again kill power with aid of channel locks clamp onto rod and help it to the 45 degree position when power is restored after that never try self clean again the computer reads the position of the rod thru switches in the back hope this helps
Sep 02, 2014 | Whirlpool Ovens
I went to clean the oven and opened the door as the lock came out. It is beeping with an error code FSEO and I can not stop it or make the lock go back in.
Hi
Error code F5-E0 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Cannot find my manual and would like to know how to use the self-cleaning part. I held the button down for "lock", but the door did not lock, and where do I go from there?
Give this a try:
1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds. Momentarily (less than 5 sec.) press CANCEL key again to remove error code display. 2. Program and start the Clean mode. Observe to see if door locks. If it does not, inspect the locking mechanism from the solenoid to the latch pawl and door to find the cause of the problem. If the door is not locking, then 1 minute from the start of the Clean, the F5 E1 code will again be displayed. Press CANCEL key to remove error code display. 3. Once any mechanical problems with the latch mechanism have been corrected, program and start a Clean cycle (after, if necessary, clearing F5 E1 error code) to ensure proper operation of the door lock. Immediately cancel the Clean mode to observe proper operation of door unlock.
If this doesn't help try this link to locate the right model:
http://www.whirlpool.com/catalog/category.jsp?categoryId=76
Feb 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My kenmore oven will not work . it flashes an F5 code.
Hi, the f5 error code is a door lock code, which means there is a problem with your door latch. its should lock the door at a crtain temperature and its not.
Oct 19, 2010 | Ovens
Heating elements will not heat and getting an error code E1 F-5
Hello,the lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed screw driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Thanks
May 30, 2010 | Whirlpool Ovens
Error code f90, lock motor continuously runs. How
HI, this is a door lock switch failuer code. you will need to check the door lock mechanism for faults. check the wiring harness for lose fit and corrosion at the contact point. if the wires are in good condition and, the door lock mech is functional, replace the oven control board.
Jul 19, 2009 | Ovens
F9 error code while cleaning. What is broken?
HI, this is a lock switch mechanism failure.
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
If the wiring is connected properly, simply replace the door lock switch.
***(It is possible that is is stuck. trying correcting this before purchasing a new switch)---(Highly uncommon)
Jul 15, 2009 | GE JTP20 Electric Single Oven
E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Apr 07, 2009 | Ovens
F93 error
F93 error code means Maximum oven door lock time exceeded. Check oven door lock/door lock switchs.hope this helps
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool RBS245PDS Electric Single Oven Logo
20 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
