Question about Sharp AL 1631 Copier
My Sharp FO-2081 gives me a system error u2-00 as soon as i turn it on. Ive tried #*c*, 16 enter and it doesnt help. Anyone?
  • Tony Oct 18, 2013
    I replaced the toner and its still the same.Ill have to try and get the developer. Thank you.
3 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: F4-02 Improper Cartridge message on Sharp AR-M450N multi-function
You may just have a Bad Toner Cartridge... It will happen from time to time..... There is a IC chip on the back of the cartridge, it may be bad or the toner feed screw is bound up... Replace the cartride with a new one..... Also, is it a OEM toner cartridge or a genaric one?
Posted on May 05, 2010
Testimonial: "thanks for the answer!!! It was an OEM toner cartridge"
  • 257 Answers
SOURCE: Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Posted on Oct 23, 2010
REPLACED THE TONER CARTRIDGE WITH A REFILLED ON AND GET THE ERROR MESSAGE "SYSTEM ERROR F2-70"
Most Copier Cartridge have chips on them that tell the copier I am new, Replacing the toner/refill, does not change the chip info as long as the chip says I am empty its empty to the copier, replace the cartridge with a new OEM cartridge.
Mar 17, 2015 | Sharp FO-2081 Copier
Sharp FO-2081 clear memory full
enter simulation mode using # * c * after you are in run test command 66-10
Apr 08, 2014 | Sharp FO-2081 Copier
Memory full on a sharp FO-2081
Enter simulation mode using # * c * and then run test command
66-10 to clear image memory. This happends if you get a garbled fax from interference or noise. You should get a power filter with fax and network ports if it keeps happening.
Apr 03, 2014 | Sharp FO-2081 Copier
Fo-2081
I am a tech that Services Sharp. Enter simulation mode using # * c * after you are in run test command 66-10 This problem happens from you getting a bad fax mostly from noise or interference to the line. if it happens a lot to you then try getting a power filter with network and fax ports.
Dec 13, 2013 | Sharp FO-2081 Copier
Clear memory
Dec 05, 2013 | Sharp FO-2081 Copier
Sharp fo-2081 System error u2-00
U2 04 Content EEPROM serial communication
error
Detail Error in communU2 04 Content EEPROM read/write error (Serial
communication error)
Detail EEPROM access process error
Cause EEPROM abnormality
Check
and
remedy
Check that the EEPROM is properly set.
Use SIM 16 to cancel the trouble.
Replace the MCU PWB.
Oct 18, 2013 | Sharp AL 1631 Copier
Clear memory full
I service sharp for a living.
Oct 07, 2013 | Sharp FO-2081 Copier
Clear memory full
I service Sharp for a living.
Aug 08, 2013 | Sharp FO-2081 Copier
Sharp FO-2081 clear memory error
I service Sharps for a living.
Jan 17, 2013 | Sharp FO-2081 Copier
Sharp AL 1631 Copier Logo
48 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
