Question about Samsung Cell Phones
Have a company that calls 8 times or more per day how do I put on my phone not to except the number
    Sergeant:
  • 396 Answers
Add that number to the blocked number list that Samsung has in almost all of their phones. Go into your recent call list, select the number you wish to block and select the options menu. Scroll down to the 'block number' entry, and select it, and you may have to save it too.
You can also save it as a 'junk caller 01 and then set it so that it has no ringtone, or notification of any kind. In this case, you would not even know they called.
Posted on Oct 18, 2013
2 Suggested Answers
toy_ladi
  • 484 Answers
SOURCE: battery won't hold charge
The reason your phone is not holding a charge is simply because there is a problem with the terminal head.
The terminal head is malfunctioning and is not charging the battery.
To fix the terminal head,
  1. After removing your back cover and battery, remove the screws you see.
  2. With the screws removed you can now remove the battery compartment.
  3. With the battery slot removed you have access to the terminal head.
  4. it is the metallic sheets that rests on the head of the battery when inserted into the phone.
  5. Get a pin tip soldering iron and disconnect the terminal head from the green panel you will see,
  6. replace it with a new terminal head.
  7. Reverse the whole procedure for reassembly.
Another fault might be the charger or the charging port,
To test if it is the charger,
Try to use the same charger on another phone to see if it will work,
If it does not work then it is the charger.
To test if it is the charging port,
Test a well tested okay charger on the phone to see if it will work.
If it does not then the problem is the charging port and to change it
you follow the procedure of of changing the terminal but you have to disconnect the screen and the remove the charging port and replace it with another new one.
take care
Posted on Jun 19, 2010
Testimonial: "yes this was quite helpful....so it could be the charger, my local store has offered to loan me a charger that they know works, so I will try that next....if it turn out to be one of the other problems that requires replacing parts, are parts available and if so where ?????"
How do I find out a percentage of a number
You likely mean this to be the 'Average' number of employees per day rather than percentage. However you need to work out based on hr's per day that each employee can work. Lets assume though that they work full time, 8hrs per day. Then you would work out as follows:
3223.5 /8 /28 /306 = 0.047 employees per day
If they only work 1 hr per day it would be:
3223.5 /28 /306 = 0.376 employees per day
Each employee would need to work:
3223.5 /306 = 10.53hrs per month
Mar 02, 2015 | Office Equipment & Supplies
How do i get these people from calling me
Block the number in the phone. Then notify your cell company of the harassment and let them resolve it.
Dec 31, 2014 | T-Mobile My Touch Cell Phone
CAN YOU TRY & CONTACT YAHOO.COM
  • Phone Number
    800-730-2669
  • Talk to a Human
    Enter your 8 digit code used when you sign on, you will then be asked to press 1 to leave your name and number for a call back when you are number 1 in the queue.
  • Useful tools &
    numbers to call
    Compare all options
  • Call Time
    Average Wait: 46 mins - 24 hours, 7 days
  • For better help
    This may be the best phone number, but it's the #4 way overall to contact Yahoo, as recommended by other customers. Compare all options
  • Did this phone number work? Yes No Update this, please
    Help force companies to improve customer service. How
    GIVE IT A TRY
Dec 16, 2014 | Computers & Internet
Remove front plastic control panel of my Whirlpool duet dryer
Remove knobs and screws and then you should be able to pop it off
Nov 23, 2014 | Whirlpool Washing Machines
I have a fault code, NTC open call for service, on my whirlpool microwve WMH1163xvs. What to do?
Whirlpool Customer Phone Number Shortest Wait Best Support
Nov 20, 2014 | Whirlpool Microwave Ovens
How do i block a number from my pgone
If you need to block your number from appearing on a caller ID, simply press *67 before placing a call. Once *67 is pressed, dial the number as you normally would.
If you want your number permanently blocked you can contact your phone company and have a line block put on your number so that it won't ever show up for any calls you make. If you need to unblock it to make a phone call you can dial *82 before the number and that will allow your number to show up one time only on that phone call. If you want to block your number on a per call basis simply dial *67 before the number and that will block your number for that call only.
Feb 24, 2012 | Samsung Cell Phones
Minolta DiALTA Di183 Grayscale Copier Logo Minolta DiALTA Di183 Grayscale Copier printer driver problems
Contact for Konica minolta, Canon copier for repairing/rental/amc/fsma.
We provide CANON IR SeriesDIGITAL PHOTOCOPIER for rental basis also, our rental prices per month 3500/- with free 10,000 copies pre month.
New Delhi & NCR.
Gaurav Pahuja : 9811139117, 9990258388
Jul 01, 2011 | Minolta DiALTA Di183 Copier
My phone is a Nortel Networks phone T7316e I want to change my personal greeting but when i press "pers" it asks me for a greeting number. I do not know what the number is. My extension is 21...
Recording Company Greeting 1 Press FEATURE 9 8 3
The display shows
Log: QUIT RETRY REC
2 Enter 1 0 2 0 0 0 0
3 Press OK
The display shows
Admin MBOX AA OTHR
4 Press AA
The display shows
Auto Atdt Admin GRTG TABLE LINES
5 Press GRTG
The display shows
Greeting Admin GRTG AA
6 Press GRTG
The display shows
Greeting: RETRY OK
7 Enter Greeting number "13" (for holiday recordings
8 Press OK
The display shows
Greeting RETRY PLAY REC
9 Press REC
10 At the sound of the tone record the greeting.
Greeting: "Thank you for calling (your company name)..........."
11 Press OK to end your recording.
The display shows Accept Greeting:
RETRY PLAY OK
NOTE: To listen to the greeting press PLAY, to re-record the greeting press RETRY
12 Press OK to Accept the greeting
To program to play
1 From Step 12 press *
2 Press Table
Auto Atdt Admin GRTG TABLE LINES3 At Grtg table: enter 1
4 Grtg table: Retry OK
5 Press OK
6 Press OK again @ AA menu prompt
7 At Morning: 1 press CHNG to whichever new greeting you recorded
CHNG Morning: 1 PLAY NEXT
8 Continue by pushing next through all times
9 Afternoon:2 CHNG PLAY NEXT
10 You should note which times had which greetings to change back after holiday
11 After you change all the times Morning Afternoon Evening Non-business press Release
This will work for setting a new greeting as well, you can use numbers 1,2,3 etc for the greeting numbers to set them at different times of day in the table.
Feb 24, 2011 | NorStar T7316E Corded Phone
My phone was dropped in water, and i dried it out, But the problem is all the other keys on my phone work, Except for number 8 and that's my second digit in my lock code. What to do?
Get a container three times large then your phone place a bed of uncooked rice in the bottom put your phone in there and cover it with more rice and put the lid on for at least a full day preferably two. Take it out dust it off see if it works if it tries and not quite then put it back for another day. The uncooked rice will actually draw moister out of electronics. Best of luck
Jan 17, 2011 | Cameras
Cell Phones Logo
29 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
