Question about GE GFWH2400LWW Washer
Diagnostic mode test
I just replaced circuit board now it only counts down on the time. each minute is only a second and nothing happens as far as no water door does not lock.
  • 3422 Answers
SOURCE: Ge Adora front load washer not working
I don't know how you could have got it into diagnostics mode by accident - - but here's how it goes . Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal
Posted on Sep 30, 2008
  • 58 Answers
SOURCE: Washer will not fill
Your drain pump is obstructed. You need to remove the bottom panel to access the drain pump. The drain pump will be in the front center of the unit. Once accessed you will see a large knob/screw this will need to be turned clockwise (be ready with some towels and bucket) once you have it open, you should be able to clean out the trap. Reverse to reassemble.. Good luck.. Hope this helps... Bill
Posted on Jun 04, 2009
milten1
  • 1304 Answers
SOURCE: Water in tub and nothing happen when we try to wash cloths
usually this is indicitive of a bad pump or something stuck in it.these machines when first started they try to pump out first
the cycle will continue as long as it senses water
have them inspect the pump
good luck with sear service i hope it goes well
Posted on Oct 13, 2009
SOURCE: Water will not drain. On the timer the door
bad pump impeller
Posted on Nov 02, 2009
SOURCE: WBVH6420F Will not lock the door nor start when
Do not feel alone on this one. I too am experiencing this problem. I've cleaned out the lint trap and not much was in there. I am still getting the two beeps and nothing happens. Please let me know if there is a solution.
Posted on Sep 19, 2010
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
How to read the engine codes without a Nissan CONSULT or scan tool. (Set ECM in Diagnostic Test Mode II) Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds....
there is a screw on side of the ECM. turn screw counter clockwise all the way and monitor dash board/check engine light on and count the number of flashes on dash board. when you are done turn the screw back into original spot.
Sep 04, 2011 | Nissan Maxima Cars & Trucks
LN-S4692D samsung volume stuck in up or down mode.
Nothing else. Thee boards he replaced are the correct boards to fix this problem. You are going to have to get them replaced again. You can call samsung to see what is up, but when it gets down to it, you are going to have to get those boards replaced again.
Jun 14, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
I have a Precor EFX544, old, that won't display times correctly, counts down to 5 seconds then quits, any suggestions. When I do diagnostics, I get what I think reads Life 109?
In diagnostic mode you have 5 modes LED Diagnostics,Lift calibration number check, identify software version, heart rate diagnostic and keypad test. other than that I suspect that the upper console is going south. You can sent the upper console for repair. Contact National Gym Supply @ 1-800-496-7278 and they will give you pricing and address to send to.
May 19, 2010 | Precor EFX 546i Elliptical Version 4
Need trouble shooting proceedure to enter self diagnostics for maytag neptune
From the service manual there is more to it but that was all I could put here.
Accessing Service/Diagnostic Mode:
Pressing down the damp dry and time (-) keys
for 5 seconds places the machine in the
diagnostic mode.
SPECIAL TESTS
The following table lists the various tests
available while in the Service Mode, which
can be accessed by pressing the following
keys:
Press Keys Special Test/ Function
wrinkle
release Diagnostic Codes
dryer
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
Number
very dry(< ) View current cycle
temperature (Co)
start/pause
Start or pause cycle running
but remain in Diagnostic
mode
Accessing Diagnostic Codes
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
dry
and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane Pad Check
While in system check mode, pressing the
damp dry and sensor dry keys for 5 seconds,
will start a membrane pad switch test.
The membrane check involves turning all the
embedded LED on the membrane pad on.
All the LED’s can be toggled off by pressing
the key associated with the LED. To exit the
test at any point, press the damp dry (>) &
sensor dry keys again for 5 seconds or press
the off key to exit diagnostic mode.
Key Pressed: Function Performed
sensor dry
Enable sensor dry circuit.
(sense dry LED) When short
circuit is detected across the
sensor bars the normal dry
LED will turn on.
start/ pause
Cycles the motor relay
on/off. When the motor is
running the start/pause LED
is on.
dry temp(^ )
If motor is running, cycles
the heater/gas valve on/off.
When the heater is regular
temp LED is on.
temperature (Co)
www.appliancehelponline.com
Mar 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I can not get it into service mode.
There is not a "diagnostic mode" for the neptune washer.
All tests and functionality are done at each setting using the timer (except the tach circuit)
What is the problem you are looking to diagnose??
Thanks!
Mar 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Ei210 in wall countdown timer in undocumented ''test mode''?
You could try disconnecting power to the switch for a few minutes maybe that will reset it. Other than that I would say cut your losses and replace it. Hope this helps a little.
Nov 12, 2008 | Intermatic EI210 Electronic Auto Shutoff...
MDB7100AWB STOPS AFTER 3 SECONDS OF RUNNING
1. The Maytag sevice centers, if close, are "great". You describe the problem and they supply the part. If far still give them a call.
2. The problem is probably the control. It's a simple fix. Just replace the part. And you can order the part from the service center. Takes 10 minutes.
Tango
Feb 09, 2008 | Maytag MDB7100AWB Dishwasher
GE GFWH2400LWW Washer Logo
62 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
