Question about Health & Beauty
Burning smell running
Hello my baby has to inhale. we bought a quite expensive nebulizer called combimist. it smells burned when you turn it on.is it because its new???
  • 32 Answers
SOURCE: refrigerator burning rubber smell when it tries to turn on
sounds like the relay on the compressors is getting hot and cutting the unit out, if the fridge is quite old it may well be the run windings gone short circuit in the compressor pot. The relay switches from start to run windings so may be firing the start circuit, switching over to a shorted run winding, and then getting hot and activating the thermal cutout and hence the burnig smell, plus the start and rapid shut down of the compressor.
Posted on Mar 19, 2008
reddevil6
  • 1673 Answers
SOURCE: Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Posted on Mar 30, 2008
eitan
  • 291 Answers
SOURCE: burning smell
The sulphur smell is the result of the emmisions control system. I have an 06 Expedition with the exact same engine and emmisions system as yours. When the engine is cold, you don't smell that sulphur smell, but as soon as the engine gets to operating temperature, the exhaust gasses smell sulphury. Nothing wrong with your ride - they all do that. The dealership sometimes spray the underbody with some type of rubber to protect the vehicle against rust. This rubber stuff sometimes get sprayd on the exhaust as well and then you will smell "burning tires" after driving the vehicle. This will go away after a few thousend miles though.
Posted on May 15, 2008
SOURCE: Burning smell
We had the same problem. After we used it a few times, the smell went away.
Posted on Sep 07, 2008
  • 124 Answers
SOURCE: bad smell from ac unit in my house
does it smell like literally , dirty socks?if so it is dirty sock syndrome, a plague of heat pumps for years. if it smells like an electrical melting or burning of wires then time to call a pro.it could be a weak capacitor or a weak fan motor. if it is dirty sock syndrome then its the microbes that thrive when temps are middle temps and reproduce when temps are hot and cold in intermittent days. hot one day and cold the next equals call for cool then call for heat and hot steam from heated coils cause s bacteria to grow and microbes to spread across coil. when you switch back it causes the smell.if the coil is clean you can spend a chunk of money on sanitizers but best bet is to run it cool for hot weather and hot for cool weather. the transitional periods are what create the smell. avoid semi cool and semi hot periods. this condition is common to acs from all brands . lots of stuff on the internet about dirty sock syndrome
Posted on Nov 01, 2008
Nebulizer omron mist coming out most of the time but it takes very long for medication to finish
Nebulizers are a slow steady way to administer inhalation medication. the whole idea is that you have to slow down, relax and breath regular and steady to get all the medication. just a side note make sure you clean the face mask on a regular basis because they are great places to grow mold and bacteria. hope it helps.
Nov 19, 2017 | Omron Health & Beauty
Where do you load the inhalation solution?
You may have already figured this out by this time, but figured that others could have the same question. Here's a simplified explanation on how to assemble and use the nebulizer. I apologize if the explanation sounds patronizing. I'm not sure of what you may or may not understand about the nebulizer, so I'm explaining as though you don't understand it. I'd rather someone explain something in a patronizing way, than assume I have knowledge that I actually don't. At least with the former, it's easier for me to ensure my questions are answered. I also apologize for my ADHD. It often cause me to write much more than is necessary or overexplain things.
There should be two pieces that screw together to make the reservoir.
Piece #1 is the male side/bottom side and may or may not have a green cone inside. If not, there are still a plastic piece inside that forms a cone shape. This side should also have a small plastic cylinder shape on the bottom. This is where one side of the supply tube should be attached.
Piece #2 is the female side and has a larger cylinder shape on the top. When the piece is turned on its side, it sort of resembles a flashlight. This is what the breathing apparatus is attached to. You attach the tee adapter to the tube side of it. Then you attach the mouthpiece to whichever of the tee sides it fits best. Once this is all assembled, attach the other end of the supply tube to the nebulizer.
Now, back to your question. Open the reservoir, pour the solution into Piece #1, then screw Piece #2 back on. It should only take a second or two for the steam to begin flowing through the breathing apparatus once you turn the nebulizer on. Also make sure the the supply tube is attached securely to both the nebulizer and the reservoir so it doesn't pop off. Now you're ready to begin.
If you start coughing during treatment, that's fine. Don't remove it from your mouth or stop treatment. My mom was my son's pediatric nurse and trained us on its use. She said that if you start coughing during treatment, that actually helps you to inhale even more of the solution which is beneficial..
Aug 02, 2013 | Salter Labs 8900 Series Small Volume Jet...
Brand new Audiobahn amp burning smell
i'd need more info but from what you've stated, sorry to break it to you but it sounds likely you've incorrectly wired you speakers and blown your amp. this will prove no doubt an expensive mistake and learning exercise.
May 23, 2017 | AudioBahn Car Audio & Video
Heard pop and had burnt smell from DELLE207WFP.
Hello
The pop you heard was probably a capasitor. If i am correct the smell will get more prominet how longer the screen is on.
If it is a capasitor, which i believe it is, it will not be expensive at all to repair. Just take it to an electronic repair shop and let them just put in a new capasitor. The vapours of the smell is not deadly fo the small amounts of time and the concentration you are inhaling, but it gives me headaches.
Please rate this.
Best regards
Sep 25, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Peg Perego John Deere Gator has burning smell
It sounds like it may need a new wire assembly.
I bought mine here
http://www.shopjandl.com/
and they also helped me with my other ride on toys.
My grand children have several of these so we are always getting parts for them.
hope this helps
Jul 16, 2009 | Peg Perego John Deere Gator HPX Ride on...
Nebulizer portion is accumulating what appears to be saliva
well i have a inhaller tube to and yes it can be straight and it can slope down too. saliva no it's not possible but it could run down your cheek. or you could go and ask where ever you got the nebulizer from
Dec 01, 2008 | RTO Spider Nebulizer
There is no mist coming out of the neb machine.
No! don't buy a new machine. First wash the mask, tubes and any other washable part really well by hand. There could be some dryed on fluid blocking the flow of the liquid. Then make sure that the part where you put the liquid does not have liquid on top of the ******** part. Usually a bit of shaking off of the liquid or using a paper towel to dry that part off should help. If this doesn't work let the nebulizer dry out overnight with all parts seperate. I constantly have these kinds of problems with my nebulizer and these seem to do the trick if these don't work then you might need a new machine.
Nov 20, 2008 | Cardinal Airlife Brand Modudose 5 Ml Unit...
Nebulizers problem
There are two main types of nebulizers: jet and ultrasonic devices. Jet nebulizers form droplets by using a compressor to deliver a pressurized jet stream of air down a narrow tube and through an opening. This creates a vacuum (through the Venturi effect), thus drawing liquid from a reservoir. The resultant small droplets of liquid are propelled out of the machine by the continued jet stream. Ultrasonic nebulizers produce aerosolized droplets using high-frequency sound waves generated by a special crystal. Liquid drug is usually delivered to the crystal, where it forms a thin layer. Electricity excites the crystals, causing them to vibrate at extremely high frequency. This vibration forces the thin liquid layer through an adjacent mesh, creating a fine mist. Droplet size varies with the frequency of the sound waves created by the vibrating crystals.
Aug 27, 2008 | Cardinal Airlife Brand Modudose 5 Ml Unit...
Nebulizers question
Nebulizers deliver aerosolized liquid medicine by a facemask or mouthpiece. Successful nebulizer therapy does not depend on significant patient cooperation or coordination. This is useful in the treatment of pediatric asthma, and the NIH recognizes the nebulizer as an effective delivery device for young children.
Aug 27, 2008 | Cardinal Airlife Brand Misty Max 10...
Health & Beauty Logo
43 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
