Question about Honda Automobiles for Phones
I have a 2004 Honda Civic with a transmission Problem. It won't go into 2nd or 3rd gear. It will go into Park, Reverse and 1st gear. A year ago it was worked on and they put in a new torque converter, but now it's out of warranty. I've only driven it less then 8,000 miles since the repair. An advice on what the problem might be?
  • 38 Answers
SOURCE: honda civic 2003 transmission
Its possible that your transmissions Shift Solonoids could be acting erratically, either because they themselves are faulty, or the transmission's ECU is faulty, or maybe even the wiring between the two is somewhat faulty.
However it is also possible that your transmission's Speed Governor is holding too much pressure and doesn't realize it needs to downshift when you start slowing down.
Thirdly it is also possible that your Torque-Converter lockup may be siezed, or the wiring feeding it may be faulty.
Transmission repairs are usually somewhat pricey, and difficult to pinpoint, and fix, and I'm sorry to say that most of these causes to your problem really can't be checked without pulling the transmission out of the car, and disassembling it to see what the problem is.
Posted on May 16, 2008
  • 14036 Answers
SOURCE: my 92 honda accord will not go into 1st 3rd or 5th gear
check shift fork adjustment. make sure you bleed the slave cylinder.also check shift cable adjustment.
Posted on Apr 11, 2009
  • 449 Answers
SOURCE: 1997 ODYSSEY AUTO TRANS SHIFTS HARD BETWEEN 1st & 2nd, 2nd & 3rd
It has nothing to do with the transmission, it's your engine mount thats bad.
Posted on Aug 01, 2009
SOURCE: 97 Honda Civic Manual Transmission Issue(s)
when i take off in first and second i hear a small whinning
Posted on Aug 27, 2009
  • 72 Answers
SOURCE: rebuilding 1995 honda civic transmission
Did you make sure that the tork converter was all the way forward first if not then you will need to take the transmission back out and make sure that the converter has either automatic trany fluid in it or 184/85 gear oil depending on whether or not you have automatic trasmission or manual fill it up until you can put your finger in it and then rotate converter clock wise and it should slip into place before putting trasmission back into car and if after doing that and you still are having trouble take it to a transmission shop to have them do it for you.
Posted on Sep 14, 2009
My plymouth voyager gradually lost 3rd gear and 1st gear and is stuck in 2nd gear
Your transmission is out and will need a rebuild. To confirm this take it to an Ammco. They are very fair and reliable about fixing just what needs to be fixed.
Jul 21, 2014 | Dorman 1996-1997 Plymouth Grand Voyager...
Honda civic CF4 auto transmission sec gear does not work
If it is jumping from 1st to 3rd then you lost the band for 2nd gear, if you drop the pan and see metal shavings then it is a positive on the band. It would require a transmission rebuild. For most transmission inspections you have to pull the transmission.
Aug 11, 2013 | 2004 Honda Accord
99 honda civic won't go into 1st and second gear after replacing the clutch
Check the gear lever linkage adjustment, and the gear lever stick foundation.
Apr 16, 2013 | 1999 Honda Civic
Speedometer quit and transmission will not work in 3rd or drive but will in 1st and 2nd
i have a 2003 chev s-10 pickup with automatic/ 4 cyl I am not able to move shifter from park to drive i believe my shifter cable is binding
gears selection matches fine when shifting. But will not get out park go to reverse or neutral selection only drive, 3rd, 2nd and 1st
do i need to replace shifting linkage cable?
Oct 01, 2012 | 1996 Chevrolet C1500
What different gear box can fit honda integra xsi vtec 1600cc b16a? i want to change my gear box ,and i want to know what exactly other gear box can fit my car?thanks its a integra bot the product can show...
J1/S1 Found in: Integra XSI/RSI (DA6) Type: Cable 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.848 R: 3.000 FD: 4.400 Y1 Found in: CRX/Civic (optional LSD) Type: Cable 1st: 3.166 2nd: 2.052 3rd: 1.416 4th: 1.103 5th: 0.870 R: 3.000 FD: 4.266 YS1 Found in: Integra 92-93 XSI/RSI (DA6, DA9) Type: Cable 1st: 3.307 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.880 R: 3.000 FD: 4.400 S80 Found in: Integra Type R 98+ (LSD) Type: Hydraulic 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.034 5th: 0.787 R: 3.000 FD: 4.785 S80/Y80 Found in: JDM SiR-G (optional LSD) Type: Hydraulic 1st: 3.230 2nd: 1.900 3rd: 1.360 4th: 1.034 5th: 0.787 R: 3.000 FD: 4.400 Y21/Y80/S80/S4C Found in: JDM 96-97 Integra R(LSD) JDM Civic R [EK9](LSD) JDM Civic SiR [EK4, EG6] JDM CR-X DEL SOL SIR (EG2)(optional LSD) USDM DEL SOL VTEC (EG2)(OPTIONAL LSD) Type: Hydraulic 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.848 R: 3.000 FD: 4.400
Jun 08, 2009 | 1990 Honda CRX
Shifting problem
sounds like it may be either a converter problem or u got some bad clutches in third in the case you need to go to a tranny shop.
Jan 27, 2009 | 1998 Honda Civic
98 Civic Auto Trans Slippage
you need to replace clutch pack for that gear can be ordered seperately from parts store or dealer if you want to save money call peach street auto recycling at 1800-365-2341 for a warrantied used one! also might be time for change trans filter and fluid filter could be slightly clogged but I lean towards clutch pack I replace these alot on Hondas
Dec 12, 2008 | 1998 Honda Civic
Honda Automobiles for Phones Logo
79 people viewed this question
Top Honda Apps Experts
Are you a Honda App Expert? Answer questions, earn points and help others
