Printer is showing an error.cant reset followed all technical recommendations
  • linda prescott Oct 21, 2013
    printer is showing a 5 and E flashing,contacted tech. and followed theit instructions but did not help.unplgged but dont know how to remove error from printer.is their a way to reset ?
    lexmark x2600
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 67 Answers
What model and be and printer
Posted on Oct 20, 2013
How to reset error E000-000 for Canon ir2202
To help you understand and troubleshoot the error E000-000 for Canon ir2202 printer, please follow step-by-step instructions given below:
This error occurs due to high temperature readings on the printer. Occasionally, the fuser will run too hot. First thing is to perform factory reset on your canon printer but if it still show error code E000-000 again, then try to reset it in Service Mode. To do these, follow the steps below:
- Press ADDITIONAL FUNCTIONS, #
- Go to #7 Printer and Press OK.
- Go to #4 Printer Reset and Press OK.
- Yes = ( * )
- Power cycle unit.
Now check it the error is resolved. If issue persists, please try definitive reset. To do these, follow the steps below:
- Press Additional Functions key.
- Press #
- Press > to #7 Printer Function.
- Press Set.
- Press > to #4 Printer Reset.
- Press Set.
- Press <
Now restart the printer and check if it resolves the error. If issue persists, it is recommended to contact Cannon Support Center from the link given below:
https://www.usa.canon.com/internet/portal/us/home/contactus
GuruAid.com
Jun 14, 2016 | Canon Office Equipment & Supplies
Brother printer MFC-3240C error message "printer busy"
For some reason when you are not able to scan an item of yours. To fix Brother Printer Error TW006 which has arrived with the scanner when scanning with the ControlCentre 3. When you try solving to scan a document using Brother ControlCenter 3 software but it failed to connect to Brother Printer. Interesting thing is when you attempt to configure the device remotely using same Brother ControlCenter 3 it worked actually without any issues. Initially there can be some form of firewall issue either on computer system however that was not the issues. As you are trying to scan a document from the ControlCenter, the following error message may occur under certain circumstances "No connection to the device is possible [TW006]". Printing is, never possible without problems.
If your device is switched on and ready for operation, this can be a problem with the DNS resolution. Even if the MFC has been installed using fixed IP, as recommended above, the scanner app may use the node name. This leads to this problem under certain circumstances. As the problem, usually comes in the MFC Model of Brother Printer. Connect to http://www.brotherprintersupportnumber.com/
for more clear understanding of the issue.
Follow the steps to troubleshoot the Brother Printer TW006:
Step1: Make sure your computer device is not using multiple network connection
Step2: Reset the Twain Settings using the Twain Reset Tool
Step3: Enable the Windows Image Acquisition service in the registry
Step4: Reinstall thebrother machine software and drivers
The steps mentioned in above section should be sufficient to fix the error code TW006 but in case you fail for immediate and instant you can call Brother Printer Customer Support Number 1-800-213-8289. Brother Printer Support Phone Number 18002138289 Repair Service
Oct 05, 2013 | Konica Minolta bizhub Office Equipment &...
Error message: Service error 5100 on my Canon MP160 Printer
The main reason of Canon Printer error code 5100 If you receive Canon printer error code 5100 message this means you need to reset the printer. This also signifies that your computer does not recognize the printer. Your printer will show this error code because the LED is blinking. If your PC does not recognized the printer then it will also affect your printing jobs and you will not be able to do any printing work.
When the error code 5100 appears in your Canon multi functional printer then the Printer LED light will blink. This also means that you need to reset your printer. You must fix this error as quickly as possible. For instant technical support please contact Canon Printer Technical Support.
Tips to Resolve Error Code 5100
  • The Canon printer will show error code 5100 to warn the user that there is some problem.
  • In order to fix the problem, you require to opens the top of the printer.
  • In the right side of the printer you need to search for the waste ink absorber pad.
  • The next step is to clean the waste ink absorber compartment with a paper or cloth. This also completes the resetting process of the printer.
  • Inspect the paper feed area of the printer and confirm that there are no obstructions or paper jams in the printer that may be responsible for the error.
Dial our toll-free number +1-800-213-8289 for quick online assistance for resolving technical issues relating to the Canon printers. Our Canon Printer Support Number service is available for fixing technical glitches of our customers. Please get in touch with our tech support team and will receive online remote technical help at highly reasonable charges.
Our Epson printer support technicians are always ready to sort out each and every printer related issue with latest solutions offered to its clients. We are a team of fastest printer tech support solution provider for every issues related to all printers such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc. If users are unable to solve this problem, they are welcome to drop us an e-mail and we promise to get back to them in short time span via our professional printer contact details. So, come and join us for tom experience our exceptional level printer solutions to your unexpected and critical issues. And also our Canon printer technical support technicians are always ready to sort out each and every printer technical issues with instant solution. We also provide instant remote support for Brother Printer technical support services for your common printer errors such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc.
How to Fix Error Code 5100 in Canon Multi functional Printers
Jul 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Hi I bought a Lexmark X204N and now it is showing the following error message: error message: 931.01 service no first Hsyncs I am unable to print from this printer at the moment and it is causing a lot...
This error indicates that it cannot communicate with the laser printhead. Please click on the link below and follow the recommended steps. http://bitly.com/o51ckY
If you need further assistance, please contact Lexmark Technical Support Center.
Apr 05, 2011 | Lexmark X342n All-In-One Laser Printer
Ink system failure....error code 0xc19a0013....what is this error code and how do i clear it....
What is HP Printer Error 0xc19a0013 & How to Solve the Error ? 0xc19a0013 ink system failure error shows in the control panel of printer.
Reason of occurring this error message is listed below:
  • HP printer setup may not be installed properly.
  • Printer cartridges low message.
  • Printer cartridge is damage or not inserted properly.
How to Solve "0xc19a0013" Error Code for HP Printer
  • Change low or empty cartridges: in case ink alert message is display before this message. Changing the cartridges may solve the issue.
  • Make sure the printer cartridge is installed or inserted correctly
  • Remove the printer cartridge and reinstall that.
  • Use HP Printer Automatic Cleaning Utility to Printheads:In case the error message is occurring ,use automatic cleaning utility of printer for printhead cleanup
  • Update the Printer Drivers :It may happens due to outdated printer drivers. We recommend you this to update your HP printer drivers on regular bases for smooth and flawless printing
In case your HP printer still display the error message best option is to dial HP Printer technical support Phone number-1-800-436-0509 (US), +44-800-078-6054 (UK), +61-1800-769-903 (AUS)
1 800 436 0509 HP Printer Technical Support Phone Number
Jan 04, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp photosmart- ink system fail error code 0x19a0006 please help me rectify this error. my system could not print, copy or fax.Only scanning is intact thanks Sanjeev Agnihotri
Is your product in warranty or out of warranty?
For In-Warranty products, please do not do any self troubleshooting. Immediately contact HP technical support to have them troubleshoot the problem for you. In most cases, printers with these error messages are replaced but you must also be patient and follow the technical support's instructions and basic troubleshooting. I recommend you to read our article on how to contact HP technical phone support.
For Out-of-Warranty products, I am afraid you have to exert extra effort to be able to resolve this issue on you HP printer. Below are ways that I recommend to resolve this.
You need to do some basic troubleshooting steps below and hope that it would fix the problem.
  • Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  • Open the cover of the product and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Print a Self Test to verify product is functional.
  • Reconnect the USB cable, and try to print from the computer.
  • If the error is still there continue reading...
Generally, when you have this type of error message displayed on your printer screen your printer may be permanently damage, resetting your hp printer may fix it in some cases but it is almost certain that the problem wil reoccur.
"0xC18? errors may also mean that the printer's temperature is below 40F/5C.. Try warming up the printer and try again. If you have reached this part already and still the problem is not yet fixed, do not worry I still have 3 more suggestions to help you with this problem.
1. Chat for free in real time with an HP online support agent. Hopefully, HP can be able to support you on this.
2. I have stumbled upon a solved problem at fixya wherin user SagarJD was able to provide a special reset for the ink system and was able to successfully solve the ink system failure with error:OXC18a0205. You can try following his procedure.
3. If you have reached this part already, then most probably your product's Ink System is permanently damaged and it is certainly unrecoverable. Servicing the printer is not what I recommend on this. Instead, I suggest you call HP tech support and upgrade your printer to newer model.
By the way, there is another way. By now you are getting ready to replace your printer, right? Why don't you this last solution, and try it to resolve this issue. This step is only intended for OUT-OF-WARRANTY products ONLY as doing this step on IN-WARRANTY products can VOID YOUR WARRANTY. Do this step at your own risk.
There is a CMOS battery inside your printer that keeps track on your printer's history. Ink replacements, resets, etc... Try resetting the data stored on your Hp product by removing the CMOS battery and then putting it back in after 30 minutes. Unfortunately I could not tell where you can find this battery inside your product as location differs for different products but here's what the battery should look like inside your printer.
Oct 13, 2010 | HP Photosmart C6180 All-In-One InkJet...
I received an message 917.00 service transfer roll. How do I fix this ?
Here's an article on A 917 or 917.00 Service Error Is Appearing on a Lexmark T640, T642, T644, or an X64xe Series Printer. Just click on this link: http://bit.ly/aQD8jS. Follow the recommended actions. If error won't clear, printer may require service. Don't hesitate to contact Lexmark technical support for assistance. Thanks.
Aug 06, 2010 | Lexmark T640 Laser Printer
My printer shows the message"Toner exhausted"What can I do?
did you refilled it. the solutions for this machine to accept refilling is a technical job..if you can follow the technical instructions contact me.
Oct 11, 2009 | Samsung ML-1640 Monochrome Laser Printer
Paper jam error on lexmark x9350
Since it is a hardware issue i request you to contact the Lexmark technical support. (US and Canada).
1-800-LEXMARK (539-6275)
Apr 04, 2009 | Lexmark X9350 All-In-One InkJet Printer
Ink system failure-0xc19a002
inksystem has failed.unable to copy,receive faxes or print refer printer documentation error 0xc18a0007
Aug 27, 2008 | HP Officejet 5610 All-In-One InkJet...
19 people viewed this question
jasbo
jasbo
