Question about Garden
Starts then sputters and stalls. Have to wait to start again.
  • 76 Answers
Check your spark plug to see if it is firing good. You do this by taking the spark plug out and put the wire on it and hold the tip of the plug on the metal of the engine with a good insulated pair of pliers and crank the engine over. If the spark is blue then you have a fuel problem, most of the time it is a dirty carb that will need removed and cleaned. If the spark is weak then it is a ignition problem. Change the plug and check the flywheel and coil for rust it may need cleaned good.
Posted on Oct 18, 2013
Car stalls, starts up then stalls again, starts up and stalls again
This could have several problems. #1 Fuel pressure due freezing water in fuel lines add thermal aid or rubbing alcohol . If you have access to a pressure gauge there is a service fitting on fuel rail that you can test pressure while driving and see if the pressure is gone when car dies this could lead to fuel pump electrical or more restricted lines. #2 intermittent sensor failure Mopar uses 2 sensors to control spark and fuel lose one could lose spark lose the other lose injection with a scanner they call it C/C sync ok (cam/crank) if no then check for each parameters for display.# 3 relay controls ASD and FUEL pump for voltage drops.
Apr 18, 2014 | 1997 Dodge Stratus
Jeep sputters
Check fuel pressure at the injector rail. Could be pump is failing or filter is clogged.
Jul 28, 2017 | Cars & Trucks
Is it my fuel pump???? Sorry will post a vid soon but the description is exactly what it does...
Locate the fuel pressure regulator and remove the vacuum line and start the engine, inspect, if vac port leaks fuel , replace regulator, provided your vehicle is equipped with a vacuum operated fuel pressure regulator.
Jan 08, 2014 | Cars & Trucks
My car starts and then sputters and die
It can be clogged intake manifold or issue with low fuel pressure or the problem is low battery voltage or issue with clogged fuel filter.Inspect all this basics.For more troubleshooting,click the link below and go through troubleshooting:----Stalls, Sputters and Pops Through Intake Manifold? http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
Stalls and Stops While Driving? http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
No Idle and Stalling issues? http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html
Vehicle starts then stalls and shutdown? http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
Engine stalls when gas is given? http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
This will help.
Thanks.
Jun 05, 2012 | 2006 Infiniti G35
1998 JGC spits and sputters after start then cleans out untill start again
GO TO KNECHTS AUTO PARTS , HAVE THEM CHECK THE CODES ON THE COMPUTOR THEN GO FROM THERE !!
Feb 26, 2018 | 1998 Jeep Grand Cherokee
2006 Honda 750cc Shadow Aero starts with choke, runs for a minute, sputters and stalls. Won't start again for a couple of days, then starts right up. Electrical?
Hi there
I once had a wee car,whenever it got too much petrol inside itself it refused to go anywhere and had to rest for some time and you had to be very careful with the choke and the petrol so it did not swallow too much of it and need another rest.
kolbrun
Apr 02, 2012 | 2004 Honda VT 750 Shadow Aero
I have a John Deere 170 ( Kawasaki Engine), after mowing about an hour and get in some taller grass, it starts to sputter and then stalls. It will start up but still sputtering and stalls again (...
it sounds like the coil is breaking down at high temperatures. when a coil gets hot it expands. when it cools off it work right. i would change the coil and try it. i think that will solve your problem.
Sep 26, 2017 | kawasaki Garden
The engine turns over ant it starts but then it sputters and stalls
sounds like a crank sensor or control module the crank sensor tells the ecu when to fire the plugs the control module fires the coils hope this helps!
May 21, 2009 | 1998 Volvo S70
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
