Question about Align Torque Tube Rear Drive Gear Set 700
What are the torque setting for a cylinder head on Zetor 6011
What is torque settings for head bolts on Kia pregio 2001
What are the cylinder head torque settings for a KIA K2700
www.answers.com > ... > Categories > Cars & Vehicles > Asian Cars > Kia
What is the torque specification for the cylinder head on a 2002 Kia Sportage? ... the correct torque for cylinder head bolt of kia pregio 2.7 diesel is 130-135ft-lbs. ... Thehead bolt torque settings, on your Kia 2.7 diesel engine, is 70 pounds per ...
Aug 17, 2015 | Kia Cars & Trucks
I need torque settings for engine 15B/F 4104cc
Check out the help links mentioned below:----
Cylinder Head Torque Setting http://schematicsdiagram.blogspot.com/2012/10/cylinder-head-torque-setting.html
----------- Lexus LS400: Transmission or Torque Converter? http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
For more help.keep updated.
Thanks.
Oct 15, 2012 | Toyota Cars & Trucks
What is the torque setting on the head bolt for a harley davidson sportster
Cylinder Head Bolt Installation
Factory Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in three stages.
1. Tighten each bolt to 7-9 foot pounds of torque.
2, Tighten each bolt to 12-14 foot pounds of torque.
3. Mark each head bolt and head with aligning marks. Tighten each bolt 1/4 turn (90 degrees).
Torque Wrench Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in four stages.
2. Tighten each bolt to 12-15 foot pounds of torque.
3, Tighten each bolt to 22-25 foot pounds of torque.
4, Tighten each bolt to 38-42 foot pounds of torque
Good luck, i hope this helps.
Aug 06, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Torque setting for bombardier rally 200 cylinder head...2006 model
On a Rally 200 the cylinder head nuts should be torqued to 25 lbs/ft. The general torque sequence for all ATV cylinder heads should be in a criss cross pattern. For the smaller head screws the torque will be 7 lbs/ft.
Aug 03, 2011 | CanAm XP 125P Motorcycles
What are the torque specifications and tightening sequence for cam journal and cylinder head for 2001 daewoo nubira 2.0 :(
  1. The torque settings for the cylinder head bolts on a daewoo ...
    www.answers.com > ... > Categories > Cars & Vehicles > Asian Car i need how much pression (torque) for head daewoo nubira 2001 2.0 ... What is the cylinder head torque specs for a 2001 daewoo nubira 2.0 litre engine and ...
Apr 15, 2011 | 2001 Daewoo Nubira
What are the torque settings for a 1997 audi a3 1.6 cylinder head
The torque settings for a 1997 Audi A3 1.6 cylinder head:
1. Tightening sequence
2. Cylinder head instructions:
2.1. Renew bolts: Yes.
3. Tightening torques:
3.1. Stage 1 - Tighten: 40 Nm.
3.2. Stage 2 - Tighten: 90 degrees.
3.3. Stage 3 - Tighten: 90 degrees.
Please do rate my response. Thanks!
Jan 22, 2011 | Audi A3 Cars & Trucks
Need torque settings for cylinder head bolts on a 52 reg skoda fabia 1.4 16v any help much appreciated thanks
Torque settings for cylinder head bolts for Skoda Fabia 1.4 16v
Cylinder head bolts tightening order:
IMPORTANT NOTE: RENEW BOLTS!
Stage 1: Tightening torque = 30 Nm
Stage 1: Tightening torque = 90 Degrees
Dec 17, 2010 | Volkswagen Polo Cars & Trucks
Torque setting cylinder head bolt 4 cylinder KIA sportage
I need the torque settings and pattern for a Kia Sportage 2.2
Nov 24, 2009 | 2001 Kia Sportage
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Hi I'm looking for cylinder head torque settings for a 1992 BMW 316/318 e36
BMW cylinder torque setting all models
According to my service manual as follows.
Cyl head to engine block (torx e12 M10 bolts)
Stage 1 30nm (22 ft – lb)
Stage 2 + 90 degrees
Stage 3 + 90 degrees
Cyl head to lower timing chain cover 10nm (89in – lb)
The tightening sequence is from inside to outside crossover as normal. Loosening sequence is from outside to inside crossover. Remember to set torque wrench at low setting and work gradually up through the whole sequence until you get the desired torque.
Jun 16, 2008 | 1992 BMW 3 Series
Align Torque Tube Rear Drive Gear Set 700 Logo
46 people viewed this question
Top Align Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Align Toy Expert? Answer questions, earn points and help others
