Question about Stihl Bg 55
I can't get my blower to accelerate. It will only idol on full choke. If you pull trigger it bogs down. I replaced the fuel line and sprayed carb out.
  • John Van
    John Van Oct 18, 2013
    Also it doesn't have a high and low speed adjustment
  • Stihl Master
  • 1,631 Answers
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the Fuel Tank
  • Spark Plug
  • Spark Arrestor - at muffler
  • Carburetor - May need a rebuild kit
Watch this as well...
and...
Posted on May 19, 2015
Did you replace the fuel? Stale ethanol / gasoline fuel can cause this problem. Get fresh 100% gasoline, then mix in the proper amounts of synthetic 2 cycle oil, and SeaFoam (a gasoline additive) and give that a try. Retrace your steps, making sure your fuel line work is correct. Take the air filter off, if the blower runs properly without the air filter, then it's time for a new one. Take the fuel filter off, if the blower runs properly without it, then it's time for a new one. If it's still not running then it may be time for a new carb, because Ethanol gas destroys carbs. It's not worth the time and hassle to get a carb rebuild kit, just get a new carb.
Posted on Aug 19, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Could be Excessive carbon build up in exhaust caused problem. Remove muffler and clean exhaust side of cylinder.
Posted on Oct 19, 2013
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
Snow blower losing power
Start with fuel. Unhook fuel line from carb. and see if fuel runs out.
Jan 03, 2014 | Garden
Yardman 27cc 445cfm Backpack Blower starts fine, but when I try to depress the trigger for more power it dies. Idles smooth with full choke and dies when on no choke setting. Have had someone say it needs...
There may be a plugged fuel filter in the fuel tank, or perhaps you have the oil mix to rich. other problems could be that it needs a new spark plug or carburetor adjusted.
Try spraying the carb out with carb cleaner, add a little seafoam in with the gas.
Oct 21, 2013 | Mtd Products TB2BP EC 27Cc Backpack Blower
Blower runs at idle then when you give it gas it bogs down until it shuts off
try to choke it part way and see if it still bogs down, if it does then check your exhaust screen, if partial choke helps it then check fuel lines for cracks, fuel filter for being dirty and also remember fresh gas too, if all else fails clean your carb out.
Nov 19, 2011 | Garden
Ryobi backpack blower will run all day with choke up but as soon as I pull the trigger it starts bogging down
Thats a lean condition. Check fuel lines and fuel filter. If the fuel ilnes are discolored or stiff or really super mushy, If the fuel filter has become detatched from the fuel line then the fuel lines need to be replaced.
If the carb can be adjusted you can try to adjust but its likely that the carb should be rebuilt with new diaghrams and gaskets.
Adjust by turning the low speed screw out ( counterclockwise) 1/2 a turn. The low speed screw is always the one closest to the motor and usually marked on the carb body with an 'L'. When you richen a motor up the idle will drop so you will probably have to turn the idle screw in 1/2 a turn. 1 and 1/2 turns out from light bottom is standard starting point ( 2 turns for poulan products). If you get more than 3 and 1/2 turns out on the low speed screw or if turning the screw has little or no effect then the carb should be rebuilt.
Dec 12, 2009 | Ryobi Backpack Blower 25.4cc
Idles but stalls when throttled
If you have the TB2BP EC Troybilt backpack and it bogs down or begins to stall out at full throttle with choke in FULL OPEN try the following:
1. Do the simple stuff first, Check spark plug, air filter and clean or replace if necessary.
2. Remove air filter cover, open choke and spray out the carb with carb cleaner.
3. Inspect carb and look for a flat surfaced screw with a small V notch on the side of it. It will be on the top side just forward of where the fuel lines connect. If you find it don't waste any more time looking for the High and Low fuel adjustment screws (there aren't any) this is the only adjustment other than the throttle adjustment screw you'll find.
4. Start your blower allow time for it to warm up and advance choke as far open as you can without stalling motor (mine just suddenly wouldn't run in anything other than full choke).
5. With motor running, adjust the screw to improve operation. Depending on your initial choke setting you may have to adjust, open choke to next position and fine tune.
6. Note- clockwise reduces fuel to carb, while counter clockwise increases it (if it's stalling when you attempt to throttle up it's starved for fuel) I'm sure there's a tool designed so that some tech can charge you 100.00 to turn the adjustment screw 1/4 turn but I found that a pair of fine needle nose pliers did just fine. Pay attention to original position of the V notch and what adjustments you make ( I tend to make 1/4 turns and fine tune from there) so you can always go back to your starting point. Note I'm not a technician so I can't say this the fix for your machine but it worked on mine.
Aug 21, 2009 | Troy-Bilt Garden
1987 rm 125 starts and idols fine, bogs out on take off!!!!
Pull the slide out of the throat of the carb then move the clip at the top of the needle down one notch, two if needed. This will richen the low end fuel mix.
Need a "very helpful" rating asap. Thanks!
Jun 15, 2009 | 2003 Suzuki RM 125
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Stihl Bg 55 Logo
695 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
