Question about Garden
Cylinder head torque settings for zetor 6011 - Garden
  • 1779 Answers
SOURCE: need torque settings for 1985 4A corolla cylinder head
hey, torque must be done in 3 steps:
1st 22 ft lbs
2nd 43 ft lbs
final 47 ft lbs
use this sequence of tightening:
9 - 3 -1 -6 -8
7 - 5 - 2 -4 - 10
Posted on Jan 14, 2009
c17hydro
  • 2984 Answers
SOURCE: cylinder head torque settings 1990 2.6L isuzu motor
From front to back is this:
7 3 1 5 9
8 4 2 6 10
First torque value is 58 ft lbs.....then final torgue is 72 ft lbs.
Posted on Mar 21, 2009
  • 462 Answers
SOURCE: what torque spec for chev aveo 2004 cylinder head
18 lb ft+60°+60°+60°+10°
NEW HEAD BOLTS ARE REQUIRED WHEN REPLACING THE HEAD OR HEAD GASKET.
Posted on Jul 04, 2009
  • 88 Answers
SOURCE: Hi I'm looking for cylinder head torque settings for a 1992 BMW 316/318 e36
BMW cylinder torque setting all models
According to my service manual as follows.
Cyl head to engine block (torx e12 M10 bolts)
Stage 1 30nm (22 ft – lb)
Stage 2 + 90 degrees
Stage 3 + 90 degrees
Cyl head to lower timing chain cover 10nm (89in – lb)
The tightening sequence is from inside to outside crossover as normal. Loosening sequence is from outside to inside crossover. Remember to set torque wrench at low setting and work gradually up through the whole sequence until you get the desired torque.
Posted on Aug 29, 2009
inspectmycar
  • 233 Answers
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Posted on Sep 17, 2009
What is torque settings for head bolts on Kia pregio 2001
What are the cylinder head torque settings for a KIA K2700
www.answers.com > ... > Categories > Cars & Vehicles > Asian Cars > Kia
What is the torque specification for the cylinder head on a 2002 Kia Sportage? ... the correct torque for cylinder head bolt of kia pregio 2.7 diesel is 130-135ft-lbs. ... Thehead bolt torque settings, on your Kia 2.7 diesel engine, is 70 pounds per ...
Aug 17, 2015 | Kia Cars & Trucks
I need torque settings for engine 15B/F 4104cc
Check out the help links mentioned below:----
Cylinder Head Torque Setting http://schematicsdiagram.blogspot.com/2012/10/cylinder-head-torque-setting.html
----------- Lexus LS400: Transmission or Torque Converter? http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
For more help.keep updated.
Thanks.
Oct 15, 2012 | Toyota Cars & Trucks
What is the torque setting on the head bolt for a harley davidson sportster
Cylinder Head Bolt Installation
Factory Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in three stages.
1. Tighten each bolt to 7-9 foot pounds of torque.
2, Tighten each bolt to 12-14 foot pounds of torque.
3. Mark each head bolt and head with aligning marks. Tighten each bolt 1/4 turn (90 degrees).
Torque Wrench Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in four stages.
2. Tighten each bolt to 12-15 foot pounds of torque.
3, Tighten each bolt to 22-25 foot pounds of torque.
4, Tighten each bolt to 38-42 foot pounds of torque
Good luck, i hope this helps.
Aug 06, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Cylinder head torque settings bmw 318i m43
Hi dear40,
The m43 engine should be similar to both the m42 and m44. The cylinder head torque settings are 22ft/lb and 90degree torque angle, and another 90 degree torque angle. Make sure to wait approximately 10minutes before performing the 2nd torque angle.
Jun 11, 2011 | 1997 BMW 318
What are the torque specifications and tightening sequence for cam journal and cylinder head for 2001 daewoo nubira 2.0 :(
  1. The torque settings for the cylinder head bolts on a daewoo ...
    www.answers.com > ... > Categories > Cars & Vehicles > Asian Car i need how much pression (torque) for head daewoo nubira 2001 2.0 ... What is the cylinder head torque specs for a 2001 daewoo nubira 2.0 litre engine and ...
Apr 15, 2011 | 2001 Daewoo Nubira
What are the torque settings for a 1997 audi a3 1.6 cylinder head
The torque settings for a 1997 Audi A3 1.6 cylinder head:
1. Tightening sequence
2. Cylinder head instructions:
2.1. Renew bolts: Yes.
3. Tightening torques:
3.1. Stage 1 - Tighten: 40 Nm.
3.2. Stage 2 - Tighten: 90 degrees.
3.3. Stage 3 - Tighten: 90 degrees.
Please do rate my response. Thanks!
Jan 22, 2011 | Audi A3 Cars & Trucks
Need torque settings for cylinder head bolts on a 52 reg skoda fabia 1.4 16v any help much appreciated thanks
Torque settings for cylinder head bolts for Skoda Fabia 1.4 16v
Cylinder head bolts tightening order:
IMPORTANT NOTE: RENEW BOLTS!
Stage 1: Tightening torque = 30 Nm
Stage 1: Tightening torque = 90 Degrees
Dec 17, 2010 | Volkswagen Polo Cars & Trucks
Torque setting cylinder head bolt 4 cylinder KIA sportage
I need the torque settings and pattern for a Kia Sportage 2.2
Nov 24, 2009 | 2001 Kia Sportage
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Jun 16, 2008 | 1992 BMW 3 Series
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
