Question about LG WT5001CW Washer
My two year old LG Top loader washer wt5001cw completed it cycle and shut off. The latch will not open now and it won't turn back on. HELP!
  • lorena gonzalez
    lorena gonzalez Mar 14, 2014
    omg this is exactly what happened to me 5 days ago and my clothes still in the washer!!!
  • 122 Answers
Use a putty knife to lift top. Insert between cabinet and top in front. There is one on the left and the right. Then the top should lift up and be able to at least get your clothes out.
Posted on Oct 19, 2013
  • lorena gonzalez
    i just tried it and i cant
4 Suggested Answers
rallupae
  • 9 Answers
SOURCE: LG WFT1081TP Top load washer
The fuse is located in a black cover.  You need to gently pull the front panel out of the way and look to the right of the unit, in the area under where the panel was.  There, you will see a black wire running into a black cylindrical case that has a black wire running out of the other end.  Heed the warning on the label, please, and make sure that the power is unplugged form the wall.  Gently pry open the casing and you will see the fuse within.  The ends of the wires just pull off (gently) and then you have the fuse.
Tomorrow I go on a fuse hunt and try this out.
Posted on Mar 11, 2008
SOURCE: lg-wm1832cw front loader washer won't spin and drain
did anyone solve this problem? Mine is doing the same thing... uggh!
Posted on Aug 03, 2010
SOURCE: My LG washer powers off completely after running
I had the same problem with my LG washer today. I found another post that said to hold down the start pause button 5 seconds, plug back in so you have power, run on drain/spin at highest spin speed. I did it and so far after each load it has not shut down.
Posted on Jan 29, 2011
I have an lg washer model # wt5001cw i have a code le overload protection how can i reset this code
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective.
Nov 17, 2014 | LG WT5001CW White Top-Loading Washer
How do I get my lg waveforce WT5001C washer to turn on? The power went off and now the washer lid is locked shut and none of the lights are on. I checked the wall plug and it is fine.
Having the same problem with my LG WaveForce top loader. Power went off and now lid is stuck shut and machine will not turn on. Power outlet is fine.
Aug 27, 2013 | LG WT5001CW 27" Top Load Washer with 5.2...
Wash machine LG wt5001cw won't turn on
I have a LG wt5001cw top loader washer and after it completed its cycle it shut off and will not turn back on. How do I fix it?
Jan 12, 2013 | LG WT5001CW Washer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
LD WD1238C Door is Locked shut tried every trick you can think of including giving it a little kick
often on the upper grade washing machines, the components are a little more sophisticated. Possibly once you have removed the top lid, you will see the door latch from the back. some of the latches have a drawstring that you can pull which mechanically releases the door and opens. If you are able to before getting into stripping the wachine, gie it a quick cycle run and let it complete the cycle, Then try and open it. go from there.
May 19, 2010 | LG WD-1280FHD Front Load Washer
My washing machine door is not opening at the end of a cycle. I put it onto another and it still won't at the end of that one. I've turned it off as well for 10 mins or so, and still nothing. Please help!
you didn't state whether it's a top or front loader. either way, there's a switch activated when the door is closed and washer is in cycle mode- so you can't open the door when a. the front loader has water in it, or b. the top loader is in agitate, or spin cycle. if top loader- there's a tab on the end opposite the hinge side that activates a switch that latches the cover closed when in 'dangerous' cycles (don't want to get your hand caught in the spin cycle!!). either a loose wire or a failed switch! prob. need to gently pop the top (should hinge back) to access the switch. UNPLUG THE WASHER!! if a a loose wire, re-attach-if not, replace switch! easy! good luck!
Apr 17, 2010 | Washing Machines
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WT5001CW Washer Logo
202 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
