Question about Samsung HT-C650W Theater System
My Samsung HT C650W seems to be in a protected mode. After powering on, it cuts right off
SOURCE: Samsung HT-DS610 System Problem
I found this online. Don't know if it helps you guys or not?
Samsung HT-DS610
1. Remove any discs from the tray
2. Flash the RAM (disconnect from the mains for 30 seconds)
3. Plug it back in, switch on from the remote
4. Wait for "No disc" message
5. Press Enter.
6. Press 8,4,2,6,9 slowly.
7. Press Enter.
You may need to repeat steps 4 through 6 before the try is open.
Posted on Jul 02, 2008
ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
ginko
  • 19396 Answers
SOURCE: When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Bad speaker wiring.
Internal fault.
Regards.
SOURCE: SAMSUNG DIGITAL HOME CINEMA SYSTEM MODEL HT-Z110
Maybe the audio amplifier Ic are damaged and need to be replaced
Posted on Aug 14, 2009
johex
  • 75 Answers
SOURCE: Power ON
over voltage to the system causes ur system to shut off.
get it checked or replaced if  warranty is still valid.
Posted on Mar 14, 2010
Code to change settings for Small loud speakers to large. Model No HT-F450K to HT-F455K models
Speaker size selection usually is part of receiver set up; the DVD player has nothing to do with it.
Jun 27, 2016 | Samsung HT-C650W DVD Home Theater System,...
Samsung dvd player display says "protection" . Wont turn on.
Swtch off and disconnect and reconnect all the wiring especially speaker wires.
Also try resetting as per manual.
If that doesn't work then could be capacitor blown on motherboard.
Aug 06, 2014 | Samsung Ht-c650w 5.1 Home Theater System -...
Wireless speakers not linked
Have you attempted to push the search button on the back of the receiving unit? Power down the transmitting unit and the receiver and reset the signal button on the rear unit after re-powering both units. Power surges seem to fry components on the rear unit. surge protection is a must on these things.
Oct 20, 2012 | Samsung Receiver Ah63-02058u For Ht-c650w...
My HT-C650W samung home theater has two wireless speakers and no matter what I try they don't work. I have done the 0135 thing from the manual. Any suggestions
Mine worked plug and play. But maybe try switching the audio mode with the "PL" button on remote. Is ur wireless card plugged in the back?
Dec 29, 2010 | Samsung HT-C650W Theater System
I can't control the HT-C6530 unit with the remote. The remote is controlling the TV instead of the samsung HTS and i can't seem to switch it back. Seems to be something to do with the BDReceiver/TV button...
hi,
press bd receiver / tv button to select the remote for any one. u can use the same remote for tv and blue ray receiver. when u want to control blue ray with the remote, select remote for the same by pressing bd receiver / tv button and wise versa.
ok
Dec 27, 2010 | Samsung HT-C650W Theater System
SAMSUNG HT-Q9 displays PROTECT and then switches off?
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Usually a protect fault will indicate a bad transistor in the amplification section. I suspect that the control circuit is sensing a fluctuation in the power supply and going in to protect mode. (assuming that the protect circuit itself is working properly) If a voltage is too high the unit will go in to protect mode to prevent damage to the speakers and the rest of the unit. Expect a 60 to 80 dollar repair charge depending on how many parts need to be replaced and what the repair labor rate is in your area.Hope this will help........
May 26, 2010 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
It terns on on then it sayes protect
1 suspect speakers or speaker wiring, remove all speaker and replace one at a time to check they are sound.
2 suspect dust in the fan in the back, if the fan stops on the power supply this may cause protection to cut in.
3 First power off and push the "stop" botton more than 10 seconds at right side main player.
this may clear fault.
this seems to be a common problem and the vendor are not forthcoming with solutions, blogs are recommending steering clear of this model.
Nov 13, 2009 | Samsung HT-DB600 System
Bad speaker wiring.
Internal fault.
Regards.
Mar 19, 2009 | Samsung HT-Z310T Theater System
Bad speaker wiring.
Internal fault.
Regards.
Nov 14, 2008 | Samsung 500w Rrss Rear Reflecting Surround...
Open Questions:
Samsung HT-C650W Theater System Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
