Question about JVC Audio Players & Recorders
Jvc rx-6018v overloading on startup - JVC Audio Players & Recorders
4 Suggested Answers
xalint1
  • 152 Answers
SOURCE: i have my jvc rx-778v
There could be a couple of reasons that its overloading one is make sure that there is no bare wire touching at all.The other thing it could be is the ohms rating over your speakers may be to low for you receiver.Most receiver can handle 8 ohms to 6 ohms there are a few that can handle 4 ohms check your speaker ohms rating then check how low your receiver can handle with out going into overload.
Posted on Oct 19, 2010
dunnbiker
  • 8546 Answers
SOURCE: how do i turn off the linear pcm on a jvc rx-6018v
The nature of a source's digital bitstream is automatically detected at the receiver. Look at your unidentified source and ITS manual for that answer.
http://www.retrevo.com/support/JVC-RX-6018VBKJ-Receivers-manual/id/315ag011/t/2/
See the box on page 14.
Posted on Sep 23, 2011
  • 6771 Answers
SOURCE: when i turn on receiver JVC rx-6032v it says overload
Overload indicates a short in the audio output semiconductors, check speaker wires for shorts, if okay! you will need a professional to assess cost to replace outputs.
Posted on Mar 21, 2012
How do I get the digital audio cable to work from my tv to my JVC rx-6018v reciever
To start, make sure your receiver supports "digital" in the form of coax (rca) or optical type to their respected video inputs.
Mar 31, 2014 | Audio Players & Recorders
How can I hook up my jvc rx-6018v to a gemini xga-2000 amplifier?
you can do it a couple of different ways, depending on what you're trying to do with your set-up.if you're trying to do something different than what I describe here, add a comment.
for independent volume control (each unit contols volume to a set of speakers independent of each other) use the rca 'tape' out of the jvc into the rca inputs on the back of the gemini.this puts a stereo signal from the jvc to the gemini. if you want your gemini to power your subs, get an rca y-splitter (single female to double male) and a single rca cable, hook single rca cable to sub out of jvc, connect y-splitter to gemini rca inputs, and single rca to y-splitter.
Mar 05, 2013 | JVC RX-6018V Receiver
How do i turn off the linear pcm on a jvc rx-6018v
Sep 23, 2011 | JVC RX-6018V Receiver
When the reciever is powered on it flashes overload what does that mean?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
May 29, 2011 | JVC RX-6018V Receiver
5.1 surround sound will not work. Only showing digital auto and linear pcm.
You should try pressing the surround on/off button or the speakers on/off button
Jan 02, 2011 | JVC RX-6018V Receiver
Reciever won't stay on
Do you have too much of a load on the amplifier? Or as SallieJohns mentioned, is it getting adequate ventilation?
Apr 02, 2008 | JVC RX-6018V Receiver
JVC receiver
Did you check impedance value and wattage on speakers you want to add to receiver?
Sep 30, 2007 | JVC RX-6018V Receiver
Overload
No, one of your speakers is damaged (could be an amp channel went bad, but speaker is more likely). Unplug all spkrs, then plug one in and see if it acts normal when turned up. Repeat this until all speakers are hooked up or the culprit spkr is found.
Sep 25, 2007 | JVC RX-6018V Receiver
Overload
Try first to disconnect all of your speaker wires and turn back on this receiver. If the problem persists, you will need to take the unit into a shop and have the output circuits checked out, as these are all solid state parts that are soldered into the printed circuit boards and there are no user replaceable parts inside this receiver. Good Luck
Jun 07, 2007 | JVC RX-6018V Receiver
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
