Question about Hotpoint First Edition FEW12 Front Load Washer
Door won't lock, so machine won't start
Having just replaced the fromt and rear door over on the machine due to it breaking off near the hinge, the door will not lock properly, so th machine won't start. It feels like it's closing, but the door not locked light is constantly flashing and it doesn't start to fill. Please help!
    Master:
  • 818 Answers
You may have messed the lock up while the door was braking because of miss alignment-does the door line up now-you may have to replace the lock-cheers Denny
Posted on Oct 19, 2013
SOURCE: Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Posted on Jan 22, 2009
cerikitten
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Posted on Feb 24, 2009
frederiquema
  • 76 Answers
SOURCE: door locked light flashing- hotpoint wma31
Check your fuses or wirings.
Posted on Oct 26, 2009
  • 353 Answers
SOURCE: door lock light flashing when door closed and
I beleive this is normal switch off power
Posted on Jan 03, 2010
barkencoa
  • 3463 Answers
SOURCE: machine will not fill the door locked sign
The flashing door lock light is indicating that the door is not closed securely.
Try it again pushing it hard, if it sit still flashes, then could be weaq or broken spring in the door handle, or a fault on the control board.
Posted on Jan 23, 2010
LG Intellowasher WD-8026C having problems with the door latch, I keep getting an error message. Latch appears not to be connecting and locking the door. to start the machine.
The DE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly
Jan 31, 2015 | LG Washing Machines
When the machine is switched on there is a clicking sound from the door and the machine won't start. Opening and closing the door and giving it a thump, works after 2 or 3 attempts. Is the problem
Had a similar problem with our Kenmore front load washer, our grandson was caught leaning on door while it was open and it bent the hinge slightly, this misalignment resulted in the latch mechanism trying to lock the door shut( needed as a safety measure to prevent leakage) but it was unable to do so. Had limited luck with lifting the door while shutting it and holding it closed while pushing the start button,but eventually had to replace hinge. Parts man at service desk also advised not to hang wet heavy items on door (don't know why anyone would want to) as the same thing could happen,also don't try slamming door as that could result in costly latch replacement. Hope this was of some help
Feb 24, 2013 | AEG Lavamat 74640 Front Load Washer
Rear windows won't work but front windows do.
https://s8.postimg.org/caixq1kxh/power_windows.jpg
Click on the link for wiring diagram. Do you have the rear windows locked-out by the master switch, note the diagram.
Is there a wiring harness on hinge side of rear door, probably has a protective rubber boot covering. If problem isn't the lock out switch on the driver door, then we will have to check voltage and ground at wiring harness.
Dec 10, 2017 | 1997 Cadillac Seville
NEED AN ORDERS MANUAL FOR 2003 FORD WINDSTAR
open the cover door and you will found some wrong here and not really work good '
Nov 19, 2011 | 2003 Ford Windstar
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore smartwash error code dl and f? Won't start.
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the problem is solved. Please get back to me if you have any other questions.
Kevin
May 26, 2011 | Washing Machines
When I use the remote to lock my car the alarm goes off. If I try to manually lock the doors the cabin light stays on. Please help
More than likely has a broken wire or wires in a door harness.
Near the hinges for each door there is a rubber boot that contains the door wiring harness. This is where the wires are always bending when the door is opened and closed, and commonly wires will break there. Pull back each boot and look at the wires. They can be spliced right there, but the best solution is to replace the door harness if there are multiple breaks.
Jan 08, 2011 | 1993 Volkswagen Passat
Whirlpool AWM 526 600 Cant get door lock to work and start machine .\r\nNo reset button on this model. Thanks Mike
I have an older Whirlpool and there is a door lock micro switch down inside, mounted on a bracket that opens when the door is shut, that is the throw comes out when the door is shut.
That micro switch has a plastic throw that sticks when it is depressed and did not function.
You have to remove the top of the machine to get to this switch, that is accomplished by removing the two clips on the back of the machine and using a flat blade (putty Knife?) inserted in the front seam, prise up and the front wedge fit clips will release. Prop up the top so as not to disturb the timer wires and such.
Look down in the machine near the hinges and find the micro switch. Replace or try squirting some WD40 on the throw so that it does not stick.
Be sure to disconnect the 220V plug before any work is done.
A sharp blow with the side of a fist may jar it loose, delivered near the hinges, which may prove that it is the switch.
Nov 28, 2010 | Whirlpool Washing Machines
Power windows and locks stopped working but only on the driver side
open driver's door, and check wiring between the door and hinge pillar due to open and closing the door, the wiring will break, use a razor knife and split the rubber cover and check for a broken wire, solder as needed. if no wire is broken, suspect master switch on the driver's door.
Jul 27, 2010 | 2006 Chevrolet Trailblazer
How to replace '96 Ford Explorer driver side exterior door handle
You will need to remove the door panel to gain access to the handle. Roll the window up or down as needed to get to the nuts that attach the handle to the door. You will also need to remove a rod the goes to the door lock. You will see the rod after the door panel is removed. Good luck.
Jan 19, 2009 | 1996 Ford Explorer
Hotpoint First Edition FEW12 Front Load Washer Logo
49 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
