Question about Cell Phones
I have comet bxd2528 the pressure is good. But when I stop praying, the cut off not working,the motor is forcing all the time
    Sergeant:
  • 396 Answers
NOT a cell phone please re-post in the correct forum.
Posted on Oct 19, 2013
Comet Shredder Comet CM-C-100 will not turn on.
The 'tension ' bar is probably to ensure you have not put in too many sheets at a time, and cuts out if you do. Look at how the bar is fixed at one end then try to reconnect the other end. A good shake of the unit should loosen and free whatever is rattling. If you cannot fix it I doubt Comet will give you much help
Apr 05, 2014 | Comet Shredder Comet CM-C-100 10 Sheet...
B&E pressure washer w/ comet 3540 pump
Things to check:
1) is water coming out of the bottom of the pump or is the oil in the crankcase high level and milky yellow. If so your seals are bad.
2) Your check valves might not be seating properly. A couple of fouled check vavles will cause either no pressure or pulsing pressure. A good inlet water strainer keeps foreign matter out of valves. But valves do wear out and get build up that keeps them from working right.
3) Your unloader valve might be worn or fouled. Bad unloader would usually show as low pressure ( but more than hose pressure) or low volume out the trigger nozzle.
Valves are your most likely problem.
Feb 17, 2014 | Comet Pressure Washer Hw3540s Triplex Pump...
Comet axd 3020 will not build pressure
junk axial wobble plate pump. Usually axial pumps are not worth the time to try to fix them. This one has a 5 year warranty , so they think they have a pretty good one. ( I would never buy one) If you want to try to fix it, I would check the check valves first. Take them out and see if some are broken or not sealing properly. There is a valve kit available.
The other likely problem is your unloader valve. If the seal is shot or the valve stuck open the pump will not build pressure.
parts diagram http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/axd-PUMP%20BREAKDOWN.pdf
Oct 31, 2013 | Comet Garden
Comet bxd2528
NOT a cell phone
Oct 18, 2013 | Cell Phones
Comet C-60 Basic Cross-cut paper shredder
Contact Comet. I've had the same issue. They will send a new one.
Jan 12, 2013 | Comet C-60 6 Sheet Cross Cut Paper...
My pressure washer stops running when i let off the trigger
hi there sal rick85
sounds like the unloader valve is not working or stuck closed , check the setting of the unloader valve may be set too high, the unloader must open in odrder to cycle water back to inlet side of pump - if not builds up heaps of pressure , stalls the engine - service the un loader valves on the pressure head
take look and let me know - what brand your blaster unit is i know its honda but what pump
comet - axd, lw/zw, - in line or axial cam
in the mean time here is good web site on power washers
http://www.the-power-washer-advisor.com/
or go to
http://www.the-power-washer-advisor.com/pressure-washer-pump-trouble-shooting.html
cheers pauly46
May 30, 2011 | Honda Pressure Washer PSI 3000
On our electric pressure washer. Nolonger works. Disconnected the pump from motor. Motor spins freely. My guess is pump is bad?mike
Good guess. You can find parts at: www.pressure-washer-parts.com
They handle comet pumps. See if you can find the number on the pump. Not a bad brand of pump,but they do wear out. Never run pump dry, never let idle more than a couple of minutes, the water recirculates in pump and gets hot. Install a temp relief vavle when you rebuild.
Jun 27, 2010 | Comet GXD2527G Pressure Washer Pump
EC119SA less than one yr old just has started showing signs of low air volume. Was using it to clean off work bench, first blast of air was strong then quickly has very little pressure. The pressure gauge...
hi there, if there is enough air pressure present in the compressor the motor will stop,the pressure switch is working.if there is a good pressure at start then suddenly lost the pressure,there is no maintaining pressure to use but on the pressure gauge appear to be have a good or enough air pressure. check if the pressure gauge have enough air pressure the motor is stop,meaning the cut out limit switch stop the motor,if you loosen the air pressure from the valve until the cut in pressure attain or meet the motor will run again there will be a cycle process of differential pressure of cut in and cut out set up on pressure switch. checking the compressor,be sure there is a high pressure on compressor and the compressor motor is stop,shut off service valve and disconnect unit device / tools from the service valve. if the compressor have enough air pressure crakc down the service valve and observe the pressure until it run again the compressor motor,if the pressure maintain the pressure you need to clean the bench, the problem is the unit device/tool you use is defective, but if the maintaining air pressure in the compressor is lost due to malfuction of motor and the compressor engine. check the pressure switch, check the motor function by loosening the belt and run the motor w/o the compressor engine if it is tripping brought it to service center, check also the lubricant oil,if neccessary change oil.have a nice day and fix my rate thanks a lot.
Apr 20, 2010 | Hitachi EC119SA Twin-Stack Air Compressor...
Comet pump will not release from gas engine. Can you help? Thanks
Sometimes you can put the bolts on the pump loose and run the machine. The vibration from the motor will work the pump loose. If you do that, remove the brass head or the pump will overheat.
Dec 01, 2009 | Comet BXD2527 Pressure Washer Pump
I have a MTPAXR 8/120 PUMP THAT IS seized and I
The best tool for this job is a gearpuller -- there are many types -- get one which matches your problem.
May 08, 2009 | Comet BXD2527 Pressure Washer Pump
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
