How to reset an iSC Touch 480 - Televison & Video
Can I install ISC on my samsung chromebook?
ISC products require processor access and chrome book does not allow it.
It needs an app specifically tailored to chrome book operating system.
Although BIND uses the ARM processor it cannot interface with the chrome book links internally.
The only thing that will work are items that are browser based where the processing is done on the ISC site.
Feb 08, 2015 | Samsung Computers & Internet
How to hard reset xperia c1904
http://www.youtube.com/watch?v=iayi5BfTlNE
Mar 30, 2014 | Sony Mobile Xperia M C1904 Smartphone -...
Honda problems
How slow.?
no tach on the puppy? I have a hand held optical tacho, works on any machine made on earth.
slow idle has 2 causes.
1 ISC failure
or
2 ISC cant work due to horrid engine running conditions.
idle is the first to fail and last to work right on all EFI engines.
h3ll , carbs too.
ever do a tune up this decade or every 60,000 US miles?>
the ISC has what is called, command authority.
it can only adjust in a narrow range. about +- 400 rpm
if the engine is too lean, the ISC opens and it just gets leaner/slower, not faster (isc fails to work, and is not its error)
same for misfire.
if the the MAP BASED engine say, gets an air leak and idles too fast
the ISC can not correct this either (too much)
same with a stuck open EGR valve, the engine misfires horribly
and again the idle falls and ISC cant FIX this. (have videos of it,ask)
that is how it actually works ISC +ECU
all this confusing?
Find a mech.
Jan 16, 2014 | 1997 Honda Civic
How do I prevent the resolution from resetting to 640 x 480?
after windows boots press the windows key and the R key at the same time and type msconfig and press enter. after it loads go to your start up tab and uncheck everything that isn't necessary for boot. if you're unsure just google the processes to find out if it's needed.
Jul 22, 2012 | Acer Computers & Internet
H.264 RESET PASSWORD
i have dvr, h.264 model # uvs-116 16ch 480/480
Feb 12, 2012 | Panasonic 16 CHANNEL REAL TIME H.264 DVR...
What does the code po85 mean for a 1994 cadillac deville
It means that the throttle body is dirty and the deposits in the throttle bores are restricting air flow at idle to the point that the idle speed control has no more authority to maintain the correct idle speed.
Take the air cleaner off, hold the throttle wide open and look down the throttle bores. Spray the throttle bores with carb cleaner and scrub the bores and backside of the throttle blades with an old toothbrush. Cleaning the deposits off the bores and throttle blade backsides it will restore the idle air flow to the correct level. When the throttle body is clean, disconnect the battery negative cable for 60 seconds to reset the idle learn offsets to the "clean throttle body" default values.
While you are in the throttle body and looking down the bores....see the two tubes sticking up at you from the intake manifold floor just below the throttle blades...??? Those are the EGR tubes and they are NOT supposed to be full of carbon and crud. Rod them out thoroughly with a piece of stiff wire to remove the deposits. Go all the way down thru the tubes to the cast passage below and make sure that they are clean and unrestricted so that the proper amount of EGR can flow.
Turning the key to the run position extends the ISC anticipating a restart, so if the setting is incorrect it would not erase a hard code. Just turning the key to run would light up both the service soon and service now lights as a bulb check, in other words, letting you know the bulbs work. Do you have the factory service manual?
The ISC adjustment is simple on this car. With the engine running and at operating temperature, You raise the throttle arm slightly with your right hand and push the shaft of the ISC in to fully retract it with your left hand. With constant pressure on the ISC shaft it will slowly retract. The very second it bottoms, you quickly remove the wiring connector to the ISC. Now you should have a very low idle and a gap between the throttle arm and the tip of the ISC. Approx. 0.060 of an inch. Once you know the gap is correct, shut off the engine, wait 10 seconds and reconnect the ISC wiring. Restart the engine and the ISC is set to spec. The TPS setting must be verified at this time. At minimum idle, ISC not touching the throttle arm, and unplugged, the TPS should be reading approx .0 or .1. Once the ISC is reconnected, you should see a TPS reading of approx. .5 at idle. with the A/C off.
A hard code can be erased but will continue to reset as long as the reason for it has not been corrected. Idle learn procedures were designed into later year engines with multi port fuel injection to adjust idle regardless of the amount of coke build up within the throttle body. Your fuel injection system does not build up coke or deposits because the 2 injectors spray down thru the throttle body, effectively cleaning the throttle body while running. Alot of owners adjust the ISC as if it were a throttle stop screw on a carb. guessing as they go. The ISC and TPS "MUST" be in sync to get the best off throttle response and smoothest idle. Adjusting the ISC without verifying gap or TPS voltage usually results in a surging or too high warm idle. You say the car failed at idle. For what reason? CO or HC? or idle too high?
Tell us news.
Jul 20, 2010 | 1994 Cadillac DeVille
V rod 2004 starts every time somtimes wont idle cuts out changed plugs no diff could it be isc step motor if so where do i locate it and what can i do with it cheers
when you shut the bike off if you are on the throttle at all that is where the isc will reset for 4 ignitions it is located on top of the induction module
Dec 07, 2009 | 2004 Harley Davidson VRSCA V-Rod
Tomtom one touch screen not working properly
Here is the cal.txt I used for my 720
929 86 480 75
It is really close to perfect
open a text file put these numbers in save as cal.txt copy this file connect tt to computer go to explorer/aka file manager find tomtom drive and paste it in.
That is it. test it out.
May 11, 2009 | Tomtom GO 720 GPS Receiver
1995 Cadillac Eldorado
Sounds like the ISC motor ratcheting. Either is out of adjustment or faulty. ISC and TPS must be set correctly together with each other. Hope this helps
May 02, 2009 | 1995 Cadillac Eldorado
Video plays ahead of sound on ipod touch
maybe your movie isnt converted right. try a different movie.
Dec 15, 2008 | Apple iPod touch
Televison & Video Logo
1,281 people viewed this question
Top Televison & Video Experts
