Question about HP DeskJet F4280 All In One Printer InkJet
HP DeskJet 1220C InkJet
Problem after cleaning ink dust off internal parts and position sensor ribbon that now the ink cartridge carriage is in far right position and making a slight clicking sound every 20 seconds or so. Won't print and the printer cartridge light is on. (it has been on for a while say 6 months,as the color cart. is empty byut I print only black so no need to refill) The sensor ribbon has some defects in the small lines. I was careful not to spill liquid in the printer or drip it as didn't want it on the board. I need the sensor ribbon part number if that's the issue (it printed fine just before I cleaned it with plain water)
    Scholar:
    New Friend:
  • 43 Answers
You are not suppose to clean the sensor ribbon with water... it might damage the printer...
however what you can do is you can clean it with a lint free cloth which should be dry..
connect the printer directly to the wall outlet...
what you can do is unplug the printer from the back of the printer without turning the product off... then press and hold the power button for 30 sec... and then re plug it back in... check if that helps...
if it does not work please contact hp...
Posted on Oct 21, 2013
SOURCE: HP Deskjet 1220C cartridge recognition problem
try to clean the ink carriage
Posted on Apr 09, 2007
  • 1003 Answers
SOURCE: HP c3180 inkjet printer problem
apply two or three drops of 3 in 1 oil to top of the big silver rod (inside printer cover)on which the ink cartridges ride.
UNPLUG RESTART AND Print
Posted on Jan 21, 2008
SOURCE: Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Posted on Oct 13, 2008
leroyal
  • 2120 Answers
SOURCE: new tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Posted on Jan 22, 2009
SOURCE: HP Deskjet 4280 does not print. 'E' error on Control panel button
I had the same problem. It was solved once I bought an original color cartridge. Refilled cartridge seems not to work on this printer. Glad if it might help.
Posted on Jun 18, 2009
My cartridge light wont go off even when cartridges are replaced
there might be a problem with the cartridges carriage, find a new one and replace it because generally it can't be fixed. You can also buy a second hand HP DJ series 900 cartridge carriage, it's exactly the same piece ant it's 100% compatible.
Anyways, there's always a slight chance to fix it without buying another one: with a small clothe (or cotton bud) impregnated in alcohol, cleanse the cartridge carriage on its inside, specially in the copper tips that makes contact with the ink cartidge. It might solve the problem, but it isn't a flawless technique
Sep 06, 2010 | HP DeskJet 1220c InkJet Printer
HP Deskjet 1220C has started printing a series of vertical blotches and misaligned text in the same three places. Same problem with black or colour. Have aligned cartridges, cleaned fluff, etc, to no...
there might be a problem with the encoder: remove it, observe it closely with a magniying glass, and you have to see a vertical lines pattern all along the enconder, without no blurs or missing or erased parts on it. Try to clean it with alcohol and a cloth but be careful no to erase the patterns i described early. If there are missing lines in the pattern you'll need to replace.
What is the encoder? a strip of semitransparent plastic that goes in the back of the cartridge carriage.
Sep 04, 2010 | HP DeskJet 1220c InkJet Printer
BLINKING YELLOW LIGHT and the printer will not respond to a print command
it can be a damaged ink cartridge, or a damaged cartridge carriage
Aug 19, 2010 | HP DeskJet 1220c InkJet Printer
Flashing Orange light will not stop printer will not print
THIS IS A CARTRIDGE OR PAPER JAM ERROR.CHECK FOR ANY PAPER STUCK IN THE PRINTER,ALSO TRY REPLACING INK CARTRIDGES
Feb 11, 2010 | HP DeskJet 1220c InkJet Printer
Hp 1220c will not recognise cartridges tries 3 new
Try clean the contacts on the carriage unit with piece of cotton and some alcohol.If not help may have problem in carriage unit.
Nov 23, 2009 | HP DeskJet 1220c InkJet Printer
When I power up my HP 1220C printer, the power light goes on, it makes some noises and turns the drive rollers. Nothing else - the cartridges stay over to the far right. Then the feed rollers stop and the...
IT COULD BE THAT THE INK SERVICE STATION CANNOT MOVE BECAUSE OF WATE INK.ALSO ADD SOME SEWING MACHINE OIL TO THE SILVER SLIDE BAR THAT THE CARIAGE RUNS ON.DONT GET OIL ON ANY OTHER PARTS
Jun 15, 2009 | HP DeskJet 1220c/ps InkJet Printer
LIGHTS FLASHING, FAILS TO PRINT
Sound to me that the ink cartridge carriage is stuck if you can remove ink cartridges and then reinstall them. You may have to take machine apart. There are clips on the bottom of the machine to do this but be aware that when you turn it upside down the waste ink will leak
Hope I could help
Thanks J
Nov 27, 2007 | HP DeskJet 1220c InkJet Printer
HP 1220c problem
Did you try both cartridges? Sometimes a fried circuit on the color cartridge will cause a out of ink on the black even when the black is new. Double check that you are using the correct cartridge for the printer. and look at the copper/gold contacts in the printer where the cartridge goes. look for dried ink or tears. Clean with a Q-tip dipped in water. CAREFULLY. If it's torn.... enjoy your trip to walmart.
Aug 28, 2007 | HP DeskJet 1220c InkJet Printer
Print rarely completes
You need to clean the rail that the print head rides on and especially the carriage portion that makes contact with the rail. The bushings at that location are more than likely gummed up with ink and paper dust.
Aug 21, 2007 | HP DeskJet 1220c InkJet Printer
This happens when the connections on the cartridge get old. Especially when you refill or buy non HP Cartridges, try buying brand new hp cartridges and you might be able to get a couple refill out of them before this happens again.
Feb 09, 2007 | HP DeskJet 1220c InkJet Printer
HP DeskJet F4280 All In One Printer InkJet Logo
24 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
