Question about Philips 23PF5320 23 in. HD-Ready LCD Television
Horizontal Lines Moving Through Screen
Since connecting a HD-cable box to my TV, I have started to notice dark (possibly green) lines running vertically up the screen. The lines vary in thickness, depending on the program, and are even visible on the black screen when I turn the cable-box off. I have contacted Philips about having the unit repaired, but they have told me that I would need to mail it to Arkansas for replacement. I have read some horror stories about that, so I am reluctant to do it. Any suggestions?
  • 105 Answers
Your tv has a carry in only warranty. i would ask philips for the closest authorized servicer. i find i hard to believe there wouldnt be an authorized servicer within a few hours away.
Posted on Oct 25, 2007
HD TV what would cause a dark gray vertical line in the middle
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Televison & Video
Bad picture on a Samsung DPL TV
Failing DMD board or it is also possible it has bad ribbon cables
Jan 31, 2010 | Televison & Video
Green Line in Philips 42TA648BX/37 42" LCD
Just a guess. Try to get hold of a different cable box & see if you have the same problem. If so, problem is with cable box.
Jan 15, 2009 | Televison & Video
Vertical Lines and Ghost image then powers off
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts..
Mar 24, 2017 | Samsung LN-S4695D 46 in. LCD HDTV
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Dark vertical line(s) on Lcd tv
Most likely it's the LCD panel failure. You can replace the panel if you can find a spare part. But the new panel may cost you as much as to buy a new tv. Hope that will help you.
Jan 27, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Dark vertical lines on tv screen
If under warranty then of course use that.
This is a display problem. One solution someone knowledgeable in electronics can try.
This problem can be caused by a bad connection fitting of the flat cables on LCD controller board. Dis-connect the flat cables from the LCD controller(T-CON) and carefully reconnect them. Try the unit before reassembling the back cover. You may have to disconnect/reconnect several times to show improvements if this is the problem.
Sep 25, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Thin horizonal line in middle on dark screen
The several thin white lines at the top of the screen is the warning that the vertical output IC is not getting the boost voltage it needs to run correctly. The IC cannot operate for long like that and shorts out inside, which is when the vertical collapses altogether and you get the thin white line through the center of the screen. The good news for your son is that he had nothing to do with that, and it has nothing to do with the cable F connector. The set needs to be serviced by an experienced tech who will restore the boost supply and replace the vertical output IC, and when I do that I charge $75 but techs in your area will vary, so be sure to ask around.
Jul 26, 2007 | GE 24GP653 24" TV
Philips 23PF5320 23 in. HD-Ready LCD Television Logo
148 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
