HDMI input says "Input Blocked". LG 55sl4500 - Televison & Video
SOURCE: HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Posted on Jan 18, 2008
JSPCEXPRESS
  • 178 Answers
SOURCE: no input signal hdmi
Are you on the correct video source on the TV
Posted on Feb 10, 2008
  • 979 Answers
SOURCE: Unable to display HDMI Input
Okay so you have the HDMI cables from both the DVD and the Cable box plugged into the reveiver?
Posted on Feb 28, 2008
mistersony
  • 320 Answers
SOURCE: HDMI Input Stopped Working Sony Bravia KDL-40S2000
Bad input board BU or AU
Posted on Oct 18, 2008
  • 267 Answers
SOURCE: Sony 46" LCD tv hdmi input replacement kdl-46v2500
replace that board
Posted on Mar 06, 2009
47" lg 3D tv won't change inputs and only displays "HDMI 3"
Try changing inputs using the touch buttons on the front lower right bezel of the tv.
Feb 12, 2017 | LG Televison & Video
How can I connect my TV to a Dell laptop via HDMI?
if oyur LG tv has multiple HDMI ports, then you might need to choose the correct HDMI port from the 'INPUT' menu. Does the HDMI port on TV (sidepanel / back) has a sticker which denotes the number? if yes, then on tv remote, choose INPUT /SOURCE menu, it will show TV, Component, RGB, HDMI1 , HDMI2, HDM3, etc (depending your tv model, these options might vary) and choose the port number which you plugged the HDMI into. if you do not have a number on the port, then you might need to select each HDMI from "INPUT' menu and wait for a couple of seconds.
Sep 01, 2015 | LG Televison & Video
How do I connect my LG HR836T into my LG TV & LG sound system HB806 already connected
It all depends on how many HDMI input you have in the back of the TV, usually most models have 3. If you already have the TV and the sound already connected, then all you need to do is connect the player to the back of the TV to any of the HDMI input. Those are usually mark as HDMI 1 HDMI 2 and HDMI 3, so when you use your remote control to change the input in the TV, make sure to which input you connect the player to. You don't have to touch or do anything to the sound system.
Feb 15, 2015 | LG Audio Players & Recorders
I bought a bp145 dvd player and when it is hooked up to my lg 32lc5dl tv I get sound but no picture it says no signal how do I fix this
Verify what input source your LG television is on. Using buttons on the tv or the remote you can change the input source. The input you want to choose needs to match the connection type of the dvd player. For example if you are connected using HDMI, than you will want to choose HDMI from the input source menu. There may be more than one HDMI so be sure to try each one.
Jan 03, 2015 | LG Televison & Video
LG tv model 47LK520 has audio but no picture screen is grey. what is the problem?
Most likely your input button needs to be on a different input , if you have cable on HDMI #1 and a dvd player on HDMI#2 make shure your input button on your remote is on the right input ...also double check your HDMI cables that they are working because I have had cases where they go bad ! hope this helps Sincerely Glenn
Sep 02, 2014 | LG 47LK520 47 inch LCD HDTV 1080p 120Hz
HDMI Input Issues on a LG 50PS70FD-AA
Are you sure that the firmware to HDMI is installed? Contact the authorized service center. Electro help
Jun 09, 2014 | Televison & Video
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
The AV2 HDMI are missing from the input list of my Plasma LG 42 ". Please help
Well, first question would be is anything plugged in, and is currently outputting any content? Some televisions will only display input devices that are being fed some kind of content in list form. Like my Westinghouse...when my PS3 is on, my little HDMI3 will show up with a square indicating content....when it is off....HDMI3 is not listed. I'm sure you can however manually scroll through inputs on your remote, and you will find your AV2 HDMI.
Mar 06, 2010 | LG 42PC3D 42 in. Plasma Television
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Sep 11, 2009 | Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
