Question about Stihl Garden
Can't get my Stihl Blower to accelerate without stalling. I sprayed carb and put new fuel line on. Only idols and that's just with choke on. It doesn't have a high and low speed adjustment. Just one screw that say's LD and it doesn't matter turning it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Could be Excessive carbon build up in exhaust caused problem. Remove muffler and clean exhaust side of cylinder.
Posted on Oct 19, 2013
  • John Van
    John Van Oct 19, 2013
    I took muffler off but I didn't see any screen in it
3 Suggested Answers
  • 149 Answers
SOURCE: poulan pro bvm200 leaf blower/vac won't run on high
Is the exhaust spark arresor screen clean? a blocked exhaust will do this.
Posted on Jan 08, 2009
2strokeJim
  • 577 Answers
SOURCE: stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
check your muffler screen for being plugged, this will cause it to not accelerate
2StrokeJim
Posted on Nov 19, 2011
It will idol when choked apon release motor revs big and stalls
So it idles fine when the choke is on but not when its off, am I correct.
When the choke is on, the butterfly on the carb is closed. Meaning that Air is restricted upon entering the carb. This is telling me you still have a fueling issue. As when the butterfly is closed, the engine is getting the optimum amount of fuel and air to burn. However, when you release the choke, you open up the butterfly on the carb mean more air can get into the carb, in turn this draws more fuel through the carb to create that optimum burn.
Yours however isn't getting the fuel it needs when the butterfly is open, meaning its getting too much air and not enough fuel. Check and clean carb, replace any fatigued gaskets and diaphragms.
Apr 26, 2016 | Echo Used Trimmer Gt200r Outer Drive Tube...
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
I can't get my blower to accelerate. It will only idol on full choke. If you pull trigger it bogs down. I replaced the fuel line and sprayed carb out.
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the Fuel Tank
  • Spark Plug
  • Spark Arrestor - at muffler
  • Carburetor - May need a rebuild kit
Watch this as well...
and...
Oct 18, 2013 | Stihl Bg 55
I have a stihl hs 45 hedge trimmer, It starts but wont run, idles on choke than as soon as i swap it to run it stalls, i start on run it fires and than stalls. I have changed the spark plug and dioframes...
Hi, re -check the fuel pickup line. To do this you need to stretch it at the ribbed section as they are renouned for perishing in this area between the ribs, especially if it is a black line. The new type is green. Hope this helps, regards Phil.
Aug 08, 2011 | Garden
My poulan wild thing will start but will not stay running without holding the throttle. What should I do?
Get some sta-bil fuel stabilizer. add twice the amount recommended on the bottle for storage to your mixed gas. Empty out chainsaw tank and refill with the new mix. Rub for 2 minutes, then shut off. Remove cover over carb and spray inside carb, soaking it down good and cleaning all internal surfaces visible - allow to sit overnight.
Next day
Spray down carb with carb cleaner for about 15 seconds. Start saw, allowing 2 minutes to warm up and reduce choke. If saw stalls, restart and spray inside carb as it runs with choke on - keep motor at the highest rpms you can as you spray - spray in 2 second bursts, not allowing motor to stall from spray. If it stalls, change sparkplug and try again. You have varnish build up in the carb and are trying to remove it so the carb will work without the choke. This may take some time but it is the exact procedure I used for my Poulan Team Realtree last spring - I spent about an hour spraying and staring before it ran without the choke.
Good luck!!
Nov 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Stihl Gas hedge trimmer will not start after sitting idol for some time (4 months) with gas in ti.
Purchase a new spark plug. Pour all the fuel out of the tank and fill it with a fresh supply of fuel. Now, remove the spark plug and spray a small amount of carb cleaner in the combustion chamber. Quickly install the spark plug and fully close the choke, press the primer button 3 times and try to start it. You may have to do this several times until it starts and runs.
May 31, 2010 | Garden
Need repair Manuel for Stihl br-550 blower
A shop like www.arcolawn.com can get you Stihl tools and parts.
It sounds like your carburetor is not meetering the fuel properly. A rebuild may work but the carburetors on many machines have fropped in half in the past 2 years.
You may have a bad seal on the crank shaft or an air leak somewhere. If you take it to a dealer most shops charge less than an hour time to perform a full check on the machine and you can do the work.
Good luck
May 30, 2010 | Oregon Scientific Complete Carburetor for...
I have a stihl br340 backpack blower that stalls
pull fuel intake line and blow through it to see if filter in tank is clogged, also the vent in fuel cap may be blocked up, try runnig it with fuel cap loose to check for this, if this doesn't help, prob gonna have to tear in to carb
Apr 21, 2010 | Garden
We have a used Toro 521 snow blower without a manual. It started and ran last year. we drained the fuel over the winter and cannot get it to run now. We put in new fuel, choked it and nothing . We tried...
It is a fuel issue. Pull the fuel line off the carb and make sure fuel is getting into carb and that the fuel is good. If verified that good fuel is getting to carb then rebuild carb.
Nov 30, 2009 | Toro Blowers Rake and Vac - Electric...
Stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
Your carburetor needs cleaned or you need a carb. kit depending on how old the carb. parts are. If you need tips on carb. cleaning, feel free to ask.
Jim
May 30, 2009 | Echo Garden
Garden Logo
447 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
