Question about Beko Refrigerators
Red indicator light remains on for 12 hours and freezer not cold
3 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: High temp red light stays on...
You'll need to tear into it to answer these questions. I suspect the defrost cycle isn't working or the fan is broken. The best way to see what's going on is to take everything out the freezer drawer and remove it. Then take the back panel off the interior rear wall of the freezer section to expose the coils. The coils should have a very even white frost pattern on them (not frozen solid anywhere). If they are frozen up then the air can't flow around them to cool the fridge properly. If the coils seem "normal" with frost only then is the fan just above them working? That fan circulates cold air to both fridge and freezer sections. Let me know what you find out in order to lead you to a repair part.
Posted on Jan 13, 2007
kapishtech
  • 2272 Answers
SOURCE: The freezer door was left open for about 10-12
Press the button on the panel few times to change crushed ice to cubed ice.Also it can be related to faulty control board.It must have got wet and got short.Also check the water valve and drain line.If any thing still got blocked in the drain passing line at the back of the unit from evaporator to compressor pan.If its blocked then use hair dryer on the drain line and melt all the frost blocked ion the drain line. Also if the door is left open for few hours and also power ON to the unit then its internal functions and settings get totally disturbed.So try manual defrost once again.Un-plug the unit and keep the doors open for the unit.Empty whole food stuff from the unit.Let it remain in that condition for 24 hours.Then reconnect and check.In 3 to 4 hours it will get all its settings back.Just adjust the temp to normal when you reconnect after 24 hours.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 18, 2010
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
The temperature alarm goes off randomly. It remained silent for 6-10 hours after I turned it on originally then started to sound. I shut the alarm off for 10-12 hours then turned it on again. Once more it...
If you just purchased the freezer 3 weeks ago, I would be calling the store and or the manufacturer, and have them send out a service man to fix it or replace it.
May 02, 2017 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Freezer FZ175 Red Warning Light is flashing
The flashing red light indicates the problem in the temperature of the unit.The temperature is rising over then required so the red light is flashing. There are some possibilities that you will have to get checked.
1) Make sure your freezer/refrigerator door is closing properly and sealing all around.If the doors are not closing properly then this can lead to rise in temperature.
2) If doors are proper and closed properly then other possibility is to check the compressor .Check the compressor is it running properly or its not running.Beside the compressor there is a fan if the fan is running the compressor is turning on if fan is not running the compressor is not running.If the unit is not getting very cold this also indicates the problem is in the compressor section.A weak or faulty compressor causes the temperature rise problem.
3) If compressor also checks out ok then the other possibility is fault in the thermostat of the unit.The thermostat is getting overheated and this is causing the red light flashing.
4) Before replacing any part in the unit try the defrost procedure first .Keep the unit unplugged from power and keep both the freezer/refrigerator doors open .let it remain unplugged for 24 hours.Then reconnect the power and check for some time.If the unit works properly that means defrost procedure solved the problem.But if same error light comes On flashing that means the faulty part needs replacement.
You can get required parts for your refrigerator from the on-line sites like :--
www.partsselect.com.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 04, 2010 | Refrigerators
Am I supposed to turn off the quick freeze once the deep freezer is cold?
http://www.mcappliance.com/document/MCCF5WBX.pdf
i read the entire manual and even type in the words "quick freeze" in pdf. find space and it is not in there.
heres the link read it for yourself
it only mentions green light and red light.
The “POWER” light (Green) indicates that the freezer is properly connected to the electrical power.
The “RUN” light (Red) will not illuminate when the unit is operating below freezing.
The “RUN” light will illuminate when the temperature inside the unit increases above freezing. Please
be advised that the “RUN” light may come on for a period of time when the lid is opened, when new
items are stored inside the unit or when the lid is forced open by irregular contents.
Do not call for service unless the “RUN” light has remained on for 6 hours or more. If this light stays
on continuously for a period of 6 hours, please contact our Customer Service Dept. to consult with a
representative at 888 775-0202 or visit our website to request warranty service at www.magicchefewave.
com.
Apr 02, 2010 | Magic Chef Chest Freezer MCCF5WBX
Freezer has defrosted on its own. Red freezer high temp light will not go off.
Door has accidentally been left open. Have missed a proper defrost and ice has built up internally. Switch off and do a 12 hour defrost. then switch on again. (Thats where i would start.).Because fan is stuck in the ice, it cant blow cold air to the sensor. Sensor detects this and shows red error light.
Nov 13, 2009 | Hotpoint FFM70 Bottom Freezer Refrigerator
Battery charging
I assume that your charger work fain and suggest to change your battery cause its seem that its gone.
Jul 19, 2008 | Black & Decker 50 Watt Electromate with...
Refrigerators Logo
20 people viewed this question
Top Beko Refrigerators Experts
AJMAL KHAN
ray gallant
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
