Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
Diaphragm housing unscreews from the baracuda
Diaphragm housing unscreews from the baracuda while operating.
  • 3,103 Answers
Is the motor mounted on a dampening plate? do these screws have lock eashers behind them? may need to install these..
Posted on Jan 10, 2014
2 Suggested Answers
  • 990 Answers
SOURCE: Can Baracuda Diaphragm be replaced?
If you can't find any junk in the diaphram or throught. The best thing to do is take it to a store they can show you how to do this and they will not usually charge for more than just the part.
Posted on May 28, 2010
Testimonial: "Thanks - I will take it in and have them look at it."
Zodiac ranger has good suction but doesn't move
Usually if you have good suction with a Baracuda and no movement you either need to clear the diaphragm of debris, or replace the diaphragm if it's got a hole in it.
Check out this video (not mine) for how to pull the diaphragm out.
http://www.youtube.com/watch?v=FRR1Gsps8Js
It's pretty straightforward, just keep undoing things until you get to the flexible rubber bit. You have to check fairly carefully for holes because even the smallest opening means it's curtains for the diaphragm.
Good news is though that Zodiac should have a 1 year warranty on the diaphragm, which you can check by looking at the moulded stamp on the part. If it's under a year old your local dealer should just swap a new one for the old without any dramas.
Mar 16, 2013 | Zodiac Baracuda Ranger - Above Ground...
My g3 isn't working correctly, but if you remove the exterior housing then the inside tube part housing the bladder has suction and works fine. When I put the outside housing back on not much if anything...
It could still be the diaphragm. If it gets worn and stretched it may work without a load on it but with a load it will just open then stay there. The best thing to do is take this to a pool store. They will do the work necessary for just the price of parts. I hope this helps. Good luck.
Sep 27, 2010 | Zodiac Baracuda G3 Automatic In Ground...
How to install new diaphram
Page 8 in the users manual for these pool cleaners has a good image of the diaphragm. There is also an assembly break down on page 10. Here is a copy. It should show you exactly how to get the cleaner apart to replace the part.
http://www.baracuda.com/resources/manuals/TL-2050.pdf
Jun 12, 2010 | Zodiac Baracuda G3 Automatic In Ground...
May 28, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My Baracuda Zodiac works for a few minutes and
check the diaphragm for debris, damage, or deformity. unthread the collar above the handle and push the tube downward. Inspect the rubber diaphragm, any damage or deformity will cause erratic behavior.
Apr 07, 2010 | Zodiac Baracuda G3 Automatic In Ground...
No movement with my g3 baracuda
A small rip or tear in the diaphragm will cause that problem. When you put your hand over the mouth you are creating more suction to the diaphragm. Replace diaphragm.
Mar 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Will not operate and filters are clean and clear-adequate pressure is indicated at cartridge filter
Sounds like you either may have something caught inside of it or the diaphragm is distorted and needs to be replaced. You can remove the diaphragm by unthreading the collar just above the handle, then push downward on the tube. The tube and diaphragm should come out of the bottom. Check to see that it is free of debris and that it's opening is uniform and not distorted. There should not be a huge gap but just a small uniform ****. Hope this helps.
Nov 01, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
74 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
