Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
LOCK BUTTON ON
MY REFRIGERATOR IS A BLACK SIDE BY SIDE, MODEL # 253.51399104 THE LOCK BUTTON IS LIT UP AND THE ICE DISPENSER AND WATER DISPENSER DO NOT WORK. I DO NOT KNOW HOW TO UNLOCK IT AND DO NOT KNOW WHY IT IS SUDDENLY LOCKED. THE FILTER WAS LAST CHANGED IN AUGUST OF 2006.
  • DAWND Sep 26, 2007
    OH, AND IT IS A KENMORE.
  • DAWND Sep 28, 2007
    Thank you so much!! It worked!
  • 290 Answers
I think on this model you hold the lock button down until the light blinks off, about 3-5 seconds. If it locks by itself when you open and close the door it may be within the serial number range that had a recall on the dispenser board. Most of these were upgraded about two years ago but I still run into a few that were missed occasionally. If it is one of these units, as far as I know the recall is still open and it would be repaired free of charge. The most likely thing is that some one held the lock button down without realizing it though.
Posted on Sep 27, 2007
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Ice dispenser/water dispenser in side by side fridge not working
Your dispenser is child locked. Hold the child lock button for 4 seconds and the key should disappear, if you do not know which key to press I will need the model number from the tag located on inside of the fresh food section top right corner.
Apr 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
How to unlock control lock on ge monogram side by side
shoud be amatter of pressing abutton and holding in for 3-5 secs to unlock. look closely at the control panel it should indicate which button(s)
Jan 24, 2009 | GE Refrigerators
Unlock water
you have inadvertently activated the button lock- keep children and other hooligans from playing with the buttons. :)
Hold down the light button until the red key is no longer lit.
Oct 08, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Kenmore Elite Fregirator
i have the same fridge, you have to press and hold the Lock button and it will unlock the ice/water for you.
Sep 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
JCD2389GE Fridge Lock Button Is Lit
Solution found! I located manual on line. If anyone else has this problem, press the "lock" button three times in ten seconds! I'm a genius!
Jan 27, 2008 | Jenn-Air JCD2389G Side by Side...
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Will not dispense
Check that the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the "Unlock" or "Locked" button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.          http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=110&p_created=1147725595&p_sid=lTIkCMOi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzEmcF9wcm9kcz0xOTkmcF9jYXRzPSZwX3B2PTEuMTk5JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9d2F0ZXIgZGlzcGVuc29y&p_li=&p_topview=1
Oct 13, 2007 | Whirlpool GC5SHEXN Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
196 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
