Question about Dryers
Sdg109wf when running it like rattling sound coming out. what do i\I have to do?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
You may have to find a way to identify the location of the sound; type of sound..metal on metal, like something is loose?
The only thing I know that rattles in a dryer is if something got into the baffles/the wings on the inside of the drum.
If this is the case you have to open the top of the drum and unscrew the one baffle that that has something loose in it.
Posted on Oct 19, 2013
How to tell if the waterpump is faulty
Hi Charlene:
A faulty water pump will usually give you some indications.
1) Look for a coolant leak. Not always evident
2) Grasp the fan and see if it will wobble. A bad bearing can happen without the seal leaking.
3) Rattling sound could come from alternator, air conditioning compressor, tension idler, or power steering.
Use a mechanics stethescope or dowel sound rod to CAREFULLY listen to the different parts with the engine running. You will hear the faulty part.
Feb 03, 2016 | Cars & Trucks
1 2 vw passatt
There is not much to come loose there because the suspension bolts are typically torqued tightly. Does this rattling only occur when the car is rolling, or will it happen at idle. Assuming it is when rolling, I would recommend having someone drive the car on some bumpy road and run beside the car to get an idea where the sound is coming from. There is just too much insulation in the car to get a good feel for it. Also, do you hear it if the window is down, or just with the window rolled up. I would make sure that your coolant reservoir is held tightly with the 3 screws that hold it on. It is possible that the person who last did your oil change did not reattach those screws (the reservoir has to be removed to get access to the oil filter). Maybe post more information with information about when you hear the rattle, and where it sounds like it is coming from. I have often found issues running beside a car. If it is a constant clicking sound, then it may be a failing CV joint.
Apr 06, 2014 | 2003 Volkswagen Passat
My 2004 Prius has a rattling metallic sound on acceleration. It is coming from the top of the engine on the passenger side. Does anyone know what this can be?
Does the car make this sound when the car has just been turned off and engine is still hot? Lightly push the car back and forth while it's in park. Does it still make that sound?
Sep 23, 2012 | Cars & Trucks
My daewoo tacuma engine management light is on and im looseing oil also engine is rattleing
where is the oil coming out from? do not run engine, daewoo engines sound like they rattle when there is no oil pressure.
Sep 20, 2011 | 2000 Daewoo Leganza
Klx 250 07 rattles after ridden while low on oil , still rattles since oil has been topped up!
most likely did crankshaft, top end damage, where is most of the rattle sounds coming from?
Feb 07, 2010 | 2007 kawasaki KLX 250
1995 kx 125 rattling
seems like somethjing foreign could have been forgotten in the transfer case. this most likely is causing the rattle, when the viberation from the motor reaches a certain pitch or frequency.. best to have it checked by a pro...
Nov 12, 2009 | kawasaki KX 125 Motorcycles
95 4Runner, hearing a rattling sound underneath, from drive train perhaps (do not think it is trainie, drive rod or rear gear box?), sound occurs during drive acceleration or braking -- indicating loose...
rattling when doing what? if it rattles when it is running or when it is driving, this will tell you roughly where to look. If rattling while idling, coming from engine or transmission. If you ONLY hear it when you are driving, check you U joint. they can wear out and start to rattle and clunk sometimes, especially when going in and out of gear...reverse to drive etc...
Jul 23, 2009 | 1995 Toyota 4Runner
99 A4 has very little power above 3K and idle bounces & rattles
sounds like a clogged exhaust system , from the outside of the car does the rattle sound like it is coming from the convertor or muffler? if so run an exhaust system back pressure test via a oxygen sensor port or drop the exhaust and run car with open exhaust and see if the power comes back. doing this will likely set a dtc so be prepared to clear codes after test.
Mar 24, 2009 | 1999 Audi A4
I have a rattle noise . it sounds like my front sprocket
were is the rattling coming from?the onle rattling that i can think of without noing were its coming from is your chain might be snaping around from 1st to 2nd cause its a little to loose, or your cam chain is a litttle loose. a bolt near the engine could be loose and the vibes from the engine can be rattling. tell me wat bike u got, the year and were the noise is coming from and other details and i can help u out
Feb 02, 2009 | 2001 Suzuki GSX-R 750
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
