Question about Lands Phones
1 - How can phone numbers in memory be listed by NAME? 2 - How to clear number of made phone calls?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Lands Phones Master
  • 102,366 Answers
What make and model phone?
Posted on Oct 18, 2013
SOURCE: Storing memory numbers
1 - Lift the receiver and get the dial tone.
2 - Hit 'Store'
3 - Enter the number you wish to store in the phone
4 - Hit the store button again
5 - Hit the memory button you wish to store the number into
6 - Hang up!
This should store the number wherever you want to put it. Remember if you want to store it in one of the 'lower' positions (second line of the memory index card) push the 'Shift' button before you push the memory button for that location.
Posted on Oct 30, 2008
  • 49 Answers
SOURCE: VTech model TM3111-2 the time
Assuming you are using T-Mobile@Home for your telephone service you should then;
type into your web browser address bar - 192.168.0.1
On the 'Setup' Tab with the sub category of basic setup look down towards the bottom of the screen for 'time setting.'
Click in the arrow for the drop down box and select your appropriate time zone.
Click on 'Save Settings' and you should be good after that.
Posted on Jan 07, 2009
SOURCE: caller ID displays number NOT name
is there a sprint/nextel phones that has a name caller id?
Posted on Apr 07, 2009
SOURCE: use call phones through voip321
It took me a while to figure out but here is how I am able to dial out from skype to a hardline to a person not in my skype contact. Simply start to dial the number (not from the talk button!!!) then instead of hitting the talk button to dial, hit the skype button on the bottom left hand side. I also have to dial 001 then the phone number. Hope this works for you too. good luck.
Posted on Apr 15, 2009
SOURCE: Comdial 7260 Incoming number displayed not the name.
Call your telephone company and explain the problem. They will give you a code to put on your phone.
Posted on May 21, 2009
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
How to clear a memory full in the block feature on the KX-TG4031?
I have a KX-TG7644. Had to look harder for the Call Block directory. The manual really didn't help much. Press "Menu", go down to "Initial Settings", go to "Call Block". You can access the list and delete all or part to open up memory space. I had to do this after all the election calls.
Jul 09, 2011 | Panasonic KX-TG1033S Cordless Phone
The name of the caller is not displaied
Why does my Nokia device only show phone number of caller or SMS sender, although they are listed in my contacts? The calling phone number may not match with a contact name and the name is not shown in the following situations when an incoming call or SMS arrives:
  • The contact is defined twice in the Contacts application (e.g. if both Phone memory and SIM memory contacts have been selected to be displayed in Contacts settings and the same contact is found in both of them).
  • The same phone number is defined for two or more contacts.
  • The phone number in Contacts application is in different format than the number received in the incoming call. The phone number may have been stored in local format while the incoming call number is in international format (including country prefix), or vice versa. The number may not be properly matched with a contact name in this situation, depending on the device variant and the length of the calling number. In order to verify the correct format of the contact phone number (local or international), check the number which is shown when the call is received and edit the contact details accordingly.
If the problem persists, make sure your Nokia device is running the latest software. For downloads and assistance, go to your local Nokia website.
Jan 19, 2011 | Nokia C7 (8 GB) Smartphone
When I receive a Phone Call from any number, No name or Number is appearing. Only the Word 'Call' is appearing. Please assist. What shall be done. Moreover when I go in the recent Missed Calls or Received...
You have 2 identical numbers save from your phone book. check carefully each numbers you have just save, coz your phone cant show which name to appear every time you have a call. If the problem still persist check the phone contact, and check the settings. try to check if your using both phone memory and sim card memory at once. Just select only one if phone memory or sim card memory to use as phone book storage. thanks
Jan 08, 2011 | Nokia E5 Cell Phone
No contact name displayed when receiving a phone call, only the #
go to menu,select call settings,then select caller id network and set it to 'automatic selection'.the phone will detect the network and name will be displayed.
Dec 05, 2009 | Sony Ericsson Satio Cell Phone
Loading speed dial numbers on a XS1215
1 press the memory key(phone on standby mode)
2 choose from number 0-9. enter the number of choice. this will be the speed dial number where you can store the entry. scroll through the list and press the select/channel key twice.
3 STORE NAME will appear. when it's flashing, you can enter the name then press select/channel key. (name can be upto 13 char)
4 STORE NUMBER will appear. when it's flashing, you're ready to enter the number. (each number can be upto 20 digits) If you have an account number, you can store it so that if you call a hotline that needs that account number, you can just press the speed dial number key. you can also press the pause key after the number if you want a 2 second delay before it rings. you can put several pauses
5 press the memory key. if the phone is idle for 30 seconds and you did not press the memory key, it will return to standby mode.
6. press the end key
Nov 12, 2008 | Uniden Cordless Phone
LG Shine Bar KE770
Ah ha - the prob above has everything to do with phone memory. Once the full contacts from the sim card are transfered to the phone memory the phone history and sms can read the contact name. However, the phone does not automatically sense when a loaded number does not have the +61 country code attached to it, so every single phone number in the contacts needs to have this added so that incoming sms and calls are correctly identified. An interesting experience.
Apr 24, 2008 | LG Shine KE970 Cellular Phone
Contact names do not show when call comes through
This phone either shows the name or number. Not both. If you have a person listed in the phone book on the sim card AND in the phone's memory, it sometimes confuses the phone and just the number will show up. Only put the number in the sim or phone. Not both.
Dec 03, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
