Question about Vacuums
Electrolux EL8807A Precision Brushroll Clean Bagless Upright Vacuum It has no succion with the handle
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 47 Answers
If it's an upright, the suction occurs at the base, where the rollers are. Can you explain in more detail what you are having a problem with?
Posted on Oct 19, 2013
debbily
  • 101 Answers
SOURCE: Dirt Devil vacuum Release pedal not working
take off the bottom like you are replacing the belt. You will find a little metal clip that controls the upright lock.  It may be lose or broken.
Posted on Oct 11, 2007
Agent Don
  • 310 Answers
SOURCE: brush roll not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=453845
Brushroll not spinning
Posted by vistaloopy on Mar 19, 2008
I have a Eureka Bagless Optima 431 Lightweight Upright that is not working. I took it apart to clean the brushroll and have tried to put it back together several times, but the brushroll will not spin anymore. Maybe I'm putting the belt in the wrong spot? Where can I find a diagram or something?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. You have only 2 choices, the belt is either side driven belt or the belt is a center driven belt and the brushroll has one side that is for the belt and the side driven brushroll and the motor pulley must be in line in order to work properly, you may want to check the bearing holders, some vacs will mark the ends with words like NEW or USED and both have to be identical in order to fit right. Once you have the brushroll out it should spin if you set it on it’s side and if that happens you are OK, then watch the ends of the brushroll. Align the end with the motor pulley, B4 install the belt place the belt on the pulley side and install the brushroll. Then once the brushroll is in and spins properly, and then you can use a belt puller and stretch the belt onto the motor pulley and then track it in a straight line. If you need further help please feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 10, 2008
  • 21 Answers
SOURCE: Looking for the instruction manual for the Eureka
Go to http://www.eureka.com/service/manuals/80244.pdf this is a direct link to the owners guide for your model or you can call customer service at 800-282-2886 and request a hard copy
Posted on Jul 19, 2009
skyblue67
  • 71 Answers
SOURCE: Dyson - Ball HEPA Upright Bagless Ultracompact and
Hi have you checked underneath to see if the belt has snapped, you will find it either side of the brush, if so you can obtain a replacement at most retails stores but take the model number and make with you, hope this helps
  • 190 Answers
SOURCE: How do you replace Hoover Handle Release Pedal on
The handle pedal is snapped in to the base, where it pivots.
The pedal needs to be pried away fron the base, exposing the pivot pin to release it for removal. On your model, you will likelly have to remove the lower handle from the base (where it pivots) to get room to release and replace the pedal.
Posted on Mar 12, 2010
Where does the belt go on the Electrolux el8807
EL8807 no belt, separate motor for brush, use reset button. Call customer service, see my other post with the number.
Sep 30, 2014 | Electrolux EL8807A Precision BrushRoll...
What does yellow exclamation point light mean
YELLO and RED mean danger - clogging, not brush turning, overheating, .... it is time to RESET -- turn it all off and let it sit for half hour - that is what the manual says, check the brush that is not clogged up and check the inlet to the hose and where the hose goes into the body from the head unit where the brush is - make sure those not clogged either. Turn it on, push the RESET button on left back side of head unit by the switch that changes height. The reset button is like a circuit breaker - stops unit when overheats, starts when reset. Yello is ERROR, and fix it before it turns red and stops all the way. Cheers!!!
May 31, 2014 | Electrolux EL8807A Precision BrushRoll...
My brush piece is corroded
El8807 - call customer service at 800-896-9756 push 1 or 2, then push 3. They sent me a new replacement, no cost. Need your Serial Number so they know date of purchase. 5 year warranty. Best vacuum ever, better than dyson and cheaper by 100%, but the brush stopped working after getting tangled. Called support and they replaced. Great. Cheers!!!
Apr 21, 2014 | Electrolux EL8807A Precision BrushRoll...
Precision model blockage
No solution but we seem to have the same problem it is as if the valve isn't working. Please don't tell me to check for blockages.
Feb 24, 2014 | Electrolux EL8807A Precision BrushRoll...
Wand has no suction
had same problem, tried for two days to figure it out. husband figured out that at the bottom of the 'cup' where the wand sits is a round protrusion in the middle--that is your answer, that is what controls the valve. he pushed down on it with a tool, we actually had a small rock in the bottom of the cup preventing the plunger from working. now we know for next time. obviously out of warranty and did not want to buy a new vacuum.
Feb 22, 2014 | Electrolux EL8807A Precision BrushRoll...
I have an issue with an Electrolux Precision EL8802 - I can't figure out how to access the belt. I have removed the bottom dust cover and roller, but the belt isn't visible and it's not apparent how you...
There is no belt. The brush is direct drive by a seperate motor. There is a motor reset switch that you use if the brush is not turning. If that does not fix the problem, you have to take the unit in for service http://manuals.electroluxusa.com/prodinfo_pdf/Edison/86668R4en.pdf
Feb 02, 2014 | Electrolux EL8807A Precision BrushRoll...
The red "!" icon is on when I turn on my vacuum
Button on CARPET, lower the handle for use, turn on power and the brush turns. Handle up like for storage, brush does not turn. Bare floor button pushed, does not turn.
Dec 25, 2013 | Electrolux EL8807A Precision BrushRoll...
The brush is not turning and a red light is on
It could be that the brush motor just needs to be reset. You should find a button near the brushroll cleaner step lever.
Nov 25, 2013 | Electrolux EL8807A Precision Brushroll...
My Electrolux Precision Brushroll Clean Bagless Upright Vacuum, EL8807A Won't Start. I Plug it in and turn it on and nothing ... no motor sound no suction, it has a burn smell. The brush will roll but the...
The burn smell means you should take it to a qualified Electrolux repair facility. It may be an electrical issue and could catch on fire if not repaired properly.
Oct 25, 2013 | Electrolux Vacuums
The roller wont roll
take it apart and clean the crud out of it, re-assemble and NEW drive belt while you are at it!
Sep 14, 2013 | Electrolux EL8807A Precision BrushRoll...
Vacuums Logo
61 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
