Question about Sylvania SDVD7014BJ 7 in. Portable DVD Player
Emerson Mod. LC320EMIF serial# DS3A1040452693 will not power up
I need the code for emerson model lc320emif
0138,0120,0185. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Feb 10, 2016 | Emerson Televison & Video
Having a situation with color model A51QGK891X
Emerson doesn't make a TV with that model number that I can find
Feb 25, 2018 | Emerson Televison & Video
Emerson mod. ewc 1301 keep blowing fuse
Hello
There must be a direct short in its power regulator section. Normally a shorted switching output transistor at power regulator section will cause this fault. You have to check all the components in the power supply switching retulator section, including rectifier diodes, zener diodes, electrolytic capacitors, small signal switching transistors etc. In fact, you have to check the components in the entire power regulator system. Never put any more fuse into it as an experiment; this will make more components to get damaged. Check the sets' circuit well. OK.
Jul 27, 2011 | Emerson EWC1901 Combo
I nrrd a code for my dynex tv mod # dx-lcd37
Try these: 0135 or 1171. Good luck!
Jul 13, 2010 | Televison & Video
Fuse is blown where is fuse
I think this has the fuse in the back,if not look on the side where the door handle is.
Mar 17, 2009 | Emerson MW8168B Microwave Oven
Staandard 20
the plyback of your tv had a problem, there's a leak that's why you heared a sound.
Oct 01, 2008 | Emerson EWF2004 20" TV
Need to know how to set remote for an Emerson tv
Give me the mod # of the TV and the brand and mod # of the remote you are using.
Apr 22, 2008 | Televison & Video
Sylvania SDVD7014BJ 7 in. Portable DVD Player Logo
18 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
