Question about Kenmore Washer Motor Switch 3952056
Need schematic for motor switch 3952056 - Kenmore Washer Motor Switch 3952056
  • 2,113 Answers
It's a centrifugal switch. if there are 4 contacts then it is like 2 switches that are normally open. No schematic is necessary. You can easily take apart, clean, re-bend etc many centrifugal switches... or just replace them with a new one.
Posted on Oct 18, 2013
Where can I get the schematic for my Kenmore dryer 110.73952101
the schematics sheet is under the head unit of the dryer where the timer is. In some dryers, the ones with the bottom front tray, you can find it in an envelope along side the wall of the dryer.
Jul 06, 2014 | Kenmore 63942 Dryer
Need schematic for BK3 blower sku 6417002
First I would put those two wires on the same side of the thermal. Then see if the blower works. If it does that's the problem. Don't leave it that way, that is a safety switch. If blower works, replace the switch.
Jul 02, 2017 | Heating & Cooling
I need a replacement toggle switch for a chipper/shredder.The 1/12 hp motor experiences frequent slow downs, depending on what is being chopped. Sometimes it even stops momentarily, I presume causing...
My friend did a pretty good search for similar toggle
1) He found a 'wall-type' 30Amp DPDT at Global
2) He said he couldn't find others ... but the internet changes.
3) This switch could be mounted in a box that screws to side of chipper. Switch will work fine with 125V.
4) Radio shack and the automotive stores carry 5 amp versions of the DPDT, but they burn up like you said
5) Here is wiring schematic for switch schematic
6) Note: Wiring is different than automotive-type DPDT toggles where power connects to center pole and loads connect to outside poles
-Power on global DPDT connects to poles L1 and L2
-L1 switches to A1 & B1 ... while L2 switches to A2 & B2.
-Poles L1=>A1 and L2=>A2 turn on-and-off at same time
7) In a reverse of the schematic shown above, my friend is using the global switch on 30Amp water heater to switch voltages between 120 and 240 so we know switch can handle the amperage. schematic
Sep 30, 2010 | RTO 30 Amp Dpdt 3 Position On-off-on...
On My Delta DJ-20 Byrd head Jointer I don't have a wiring schematic to switch it back to 230 previous owner had it wired for 110. Any suggestions besides calling Delta to send me Schematic
Assuming you have a standard dual-voltage single-phase motor, your wire colors should be:
T1 - Blue
T2 - White
T3 - Orange
T4 - Yellow
T5 - Black
T8 - Red
For 220V wiring, you want:
Line 1 (to Black wire from switch):
Blue
Black
Line 2 (to White wire from switch):
Yellow
Tied together with a wire tie:
Red
Orange
White
This should make it so the shaft spins counter-clockwise. If you need it to spin the other direction, switch the red and black wire from the motor.
Also, don't forget to change the wiring the switch. Most likely you will need to run both the black wire and white wire through the switch.
Jun 23, 2010 | Delta X5 Dj20 8" Precision Jointer
Bought new timer for Prodigy but thought i set the wires from the old timer in proper sequence but doesnt work so maybe wrong wires on wrong terminals
Look at the wires. They have markings on them that match the markings on the timer. Did you check the Non-resetable limit? If it is open the dryer will not run.89819b0.jpg
More here
Jun 06, 2010 | GE DVL223EBWW Electric Dryer
Have a 1992 Ford Bronco Eddie Bauer Tailgate window motor problem
I looked at my schematics, and they don't show a relay. They do, however, show two ground wires coming out of the tailgate window switch. There is a ground wire for the "up" side of the switch, and a ground wire for the "down"side. These would be color-coded black, and I think that it is worth checking to make sure you don't have a corroded /broken ground running from the tailgate switch. If only one grounding wire was broken, the window would operate in only one direction. Both dash and tailgate switches share the same wiring circuit, and these wires are "hot" all the time. It's normal when you get both sides of the motor leads at 12VDC when neither switch is activated. These switches function by switching off one of the two motor leads, and connecting it to ground, thus allowing power to flow thru the motor windings. Of course, reversing the polarity on a DC motor will change the direction of rotation, so changing which black lead is switched to ground gives the up or down direction to the motor.. since you can read schematics, you might check out ebay for a used Haynes manual cheap. hope this helps
Apr 29, 2010 | 1992 Ford Bronco
Dodge caravan wiring schematic for free
what schematics do you need and leave me an email and i will send them
Mar 14, 2010 | 2005 Dodge Caravan
Maytag lat8426aae
need a picture of the schematic or better yet scan it.
w/o seing the scheatic can't help you!
Oct 11, 2008 | Washing Machines
Kenmore Washer Motor Switch 3952056 Logo
54 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
