Question about Bernina Bernette 75
How to time a bernina bernette 334d - Bernina Bernette 75
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
........... not a job for a DIY er - really. Difficult to do and getting it wrong will cost you $ to replace loopers ......
Posted on Oct 20, 2013
3 Suggested Answers
SOURCE: 334d Bernette Overlocker
went to local berinina shop and purchased booklet for 10.95 aus dollars
thankyou feona
Posted on Jun 15, 2009
  • 30 Answers
SOURCE: looking for download of manual for bernette 334d for uni student
You could check this site and see if they have it.
https://www.2instructions.com/search.php?cmarque=BERNINA&modele=334D%20BERNETTE
Posted on Jun 22, 2009
How do I change the needle on my Bernette 303 overlocker
To be sure you don't drop the needle down inside the machine, place a piece of paper or fabric across the needle plate. There are 2 tiny screws above the needles. One does the right needle, the other does the left needle. Loosen the screw (do not loosen the screw so much that it will fall out--they are Hard to find!). Pull out the old needle. Push the new needle up into the hole (the flat side should face the back of the machine). Hold the needle in place while you tighten the screw.
Bernina Bernette 303 334D 335 Serger
Aug 14, 2017 | Sewing Machines
Is there a manual for the Bernette 334DS surger>
there are none that I can find to download, but here is a link to click on for a manual,, but you can contact bernina customer service and see if they have one, I looked on their site but couldn't find one.
Bernina 334 334D Bernette Instruction Manual
Apr 16, 2015 | Sewing Machines
Old model Bernette 334d, running ok, then kept running, won't stop
Almost certainly the foot control needs to be serviced.
Cheers
Apr 11, 2014 | Bernina Sewing Machines
I have a Bernette 334d that I replaced a broken horizontal shaft gear. Everything is turning but I cannot get it to make a chain. Think the timing is off. HELP!!!
Hi
If the timing is out, to be honest, you need to get it done by someone who is experienced. It is not a simple job - there are many steps in the process and it must be done very accurately in order for it to function correctly. Timing a sewing machine is childs play in comparison.
Cheers
Oct 18, 2013 | Bernina Bernette 75
Need spares cutting blades for bernette 234 overlocker
Bernina Bernette 334D Overlocker - recent service identified the nylon gear cog inside overlocker is broken, Do you know where I can buy a replacement.??
Jan 06, 2013 | Sewing Machines
Can I get a free Bernette 334d manual on line? If yes, where do I go?
Hi!
Here's a link for you, there are a lot of scanned manuals for bernina/bernette machines.
http://www.berninausa.com/news-n862-sUS.html
Hope it helped.
Aug 20, 2011 | Sewing Machines
Find a gear part to repair my Bernett 334d
Has the horizontal shaft gear (white nylon gear) inside your overlocker failed? Does it look like this?
http://www.sewingpartsonline.com/horizontal-shaft-gear-bernina-bernette-50141103.aspx
My repair man obtained this part from Bernina and was able to repair this although it is a labour intensive repair requiring pulling down the whole machine to do. But the part itself was only $US38.
You can buy from sewingpartsonline as per link above.
Or you could ring Bernina head office in your country and talk to someone about it as I was initially told my machine was unrepairable as this part was not available by a local store who wanted to sell me a new one. I guess in light of the 4-5 hour repair time, this is probably a valid call if you buy a new plastic serger but I love my Bernette and felt it was worth repairing, not junking it. It is now 5 years later and still going strong since that repair. My OSMG (old sewing machine guy) Ken told me that the nylon gears sometimes will just crack, even if the machine hasn't had lots of work, just plastic ageing.
Hope this helps you - please rate me 4 thumbs up if so. Cheers
Jun 22, 2011 | Bernina Sewing Machines
I have a Bernette 335ds serger and one of the needles fell out (plus I need to take the second needle out. The thread has broken in that needle a dozen times, also. I can't find my manual, and don't...
I have a Bernette 334D serger - I'll make a guess that your 335DS is similar.
There is a manual for your model for sale on www.ebay.com right now, item number is 150565998515.
Assuming your needle assembly is the same as mine, you switch off the engine, turn the flywheel until needles are at the highest point, then take the green small straight blade screwdriver from your machine kit and use it to unscrew (righty tightly, lefty loosey) the needle screws a little (never unscrew all the way out!!!) so you can remove the needles. I use my tweezers for this job as it makes holding the needles easier. You may also want to unclip the pressure foot and raise the upper blade out of the way for a bit more room.
Then slide a new needle into each holder, flat shank to the back and tighten up the needle screws again. Remember that the two needles sit at different heights from eachother so make sure each goes fully up into the needle seat, then retighten with the screwdriver.
I hope this helps you with your Bernette, I've had my 334D since 1990 and its still going strong.
Feb 16, 2011 | Bernina Bernette 75
thankyou feona
Jun 14, 2009 | Bernina Sewing Machines
Sewing Machines Logo
151 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
