Question about Furniture
I'm assembling a Brenton Merido Writing desk. The entire desk is assembled, but the main drawer will not set properly in the sliders. The sliders are the small ball bearing type. I push the drawer in about half way, then it catches on the small ball bearing piece and will not go any further. I'm afraid to force it for fear of breaking the bearings completely. Any suggestions? Thanks in advance.
  • Danny
    Danny Oct 22, 2013
    Problem solved. Just took some GENTLE, gradual force and a little WD40. The drawer finally set into the ball bearing sliders. It opens and closes smoothly now.
keemo68
  • 1263 Answers
SOURCE: Need wheel bearing replacement
unfortunately your bearing assembly is a sealed unit and you have to purchase it as a complete part. they do have a way to change out the bearing at a shop, however the labor cost involved would most certainly be alot more than a replacement it's self. I have come across this problem many times and it's not as easy to switch them out as you have been told. i hope this helps. (note) to repalce them on your vehicle if you don't do the work yourself have a small shop do it not a dealer shop. the cost will be alot less. the labor time should be no more than 2 hrs. that is roughly about no more than 120- 150 dollars for the labor . if the place you take it to quotes you way more than that take it somewhere else... good luck please rate this
Posted on Sep 01, 2008
SOURCE: Stuck Right Front Wheel Bearing Assembly
With a "puller" or if that doesn't work the old hammer and chisel all around the parting line till it frees up.
Posted on Nov 11, 2008
SOURCE: hub assembly and wheel bearings problem
I just had my wifes replaced.[4x4 blazer S-10] Chev want 300.00 for each, I went on line and got the parts cheap and a friend from chev put them on in his garage. I think the whole thing cost me 200.00
Posted on Jan 11, 2009
  • 1114 Answers
SOURCE: 2006 Saturn Vue Wheel Bearing
it should come out once you have disconnected:Brakes,strut,ball joint.tire rod end,cv joint!if it is not put the cv joint nut back on until safe enough to give it a tap with hammer to knock back & out shaft this should come as one piece HUB the bearing is pressed in! better to change whole HUB good luck this hopefully helped you out!
Posted on Jan 31, 2009
techbuster
  • 5081 Answers
SOURCE: Torque specs on a 2006 chevy silverado front hub
The nut on the axelshaft is 177 ft. LBS.
The 4 bolts on the bearing hub is 133ft. LBS.
Posted on Sep 14, 2009
How assemble instructions brenton merido collection desk
Request assembly instructions from the manufacturer/distributor/purchase source.
May 27, 2017 | Furniture
Where can i buy replacement glass for a zline desk
at your local glazier any good one will cut a new one for you
Jun 29, 2014 | Z-Line Belaire Glass L-shaped Computer...
How do i put it together?
Read the instructions, if you are struggling or don't have them call customer service on (888) 736-2141
Zentra Main Desk
Jun 01, 2014 | Brenton Studio Zentra Collection Computer...
H08882ROTX sei lattice
The drawer was very hard to place in the slider runners, took 20 mins to get it in without it locking and getting stuck. Please note the small grayish tabs in side both slider runners, very hard to press theses tabs and see them but these tabs do release the drawer from being locked when you only have it half way in the slot it goes in.
Mar 08, 2013 | Southern Enterprises Lattice 48 in....
What is a writing desk?
A writingdesk is office furniture that's traditionally been used for writing letters, byhand ofcourse. These desks have been used at homes since the late 19thcentury.
Jul 25, 2012 | Furniture
CHANGE FRONT SLIDERS
This requires removal from the bike, complete dis-assembly, re-assembly and proper fluid level setting after/during reassembly.
Apr 21, 2010 | 2006 Harley Davidson FLHR Road king
How do you change the entire triple tree for 2007 suzuki sv-650s
You need to support the entire weight completely off the front end. If you have frame sliders these are useful points under which to place jack stands (on wooden blocks if necssary.)
Then you must remove the wheel and forks before removing the triples.
This is not a trivial procedure - a special tool is required to properly set the bearings when re-assembling.
I would recommend a service manual to follow the process specifically.
Jul 27, 2009 | 2006 Suzuki SV 650 S
Desk drawer: can't full close drawer'' waterloo bearing glides
Just a guess, try pulling the track out of the box,onto the drawer
Mar 30, 2009 | Omega Waterloo Wi 1511 'waterloo 41 11...
Furniture Logo
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
