Nakamichi 1000 Tri-Tracer.When switch the deck on right channel has noise and doesn`t play.After 10-15 min it appears and sounds ok.Condenser on right channel just gone?
  • Audio Player... Master
  • 1,258 Answers
It can be that or a bad FET or some other part of the circuit. To get it fixed right I would consult Tom at the below location as he is a Nak guy.
Tom Brucker
Hi Tech Service
2934 Nolensville Pk.
Nashville, TN 37211
615-331-9241
hitech@BIRCH.net
Posted on Oct 28, 2013
2 Suggested Answers
  • 133 Answers
SOURCE: Left meter problem in Nakamichi cassette deck .
I once had the same problem with a philips deck, except that both meters were twitching and both channels were distorted.
And guess what - it started happening when i reassembled it after i oiled the motor axis as it was a bit noisy.
No, that doesn't mean this had anything to do with the motor, but i had to disassemble the deck once more, i moved the wires and connectors a bit and the meters and outputs returned to normal functioning, so my guess is that there is a bad connection somewhere.
Try disconnecting the connectors inside the deck, see if the contact pins are dirty or oxydized, if so, clean them and reconnect - this might help.
Also check for any broken or shorted wires, broken insulation on wires and bad solder contacts.
I don't know if this will help, it sure did in my case, but i guess it's worth trying.
good luck
3rq8 (Triarcuate)
Posted on Jul 26, 2009
How I solve the channel overlapping?
This is down to the head alignment. Once that is corrected the sound will recorded normally and playback normally too. However any tapes recorded during the fault will not play right.
The head alignment can be corrected, using two adjusting screws located either side of the head. To get at them the door cover has to be removed. To align you play a pre-recorded good quality tape. You adjust the screws till the sound is bright and clear and only the sound recorded on that side of the tape can be heard. Best done with headphones. If you can use a commercial music tape. If you use the decks own recordings it might not be right.
If there is any damage to the head mounting you will not be able to get the alignment right.
PS use the right screwdriver for the head screws. These are very small and easily wear away. If you wear the screw head away you might have a job getting a new small screw that will fit.
May 01, 2014 | Nakamichi Audio Players & Recorders
Sound pc d3941 zennox
Yes and no. If you swap the channel leads over the fault should go to the other channel. Still the same, then not the Cassette deck.
There are several causes to one channel going. First the lead to the tape head is off or the head has gone!! Secondly a switch either on the front of the machine or the inside (when it switches to record) is faulty. Lastly an electronic fault. The good thing is that you have one good channel to play with. So as they are both the same any readings should be the same for both channels. The electronics will also buzz when touched with an insulated tool. So if it buzzers in one place in one channel it should do the same in the other in the same place.
Jun 22, 2013 | Sony TC-WE425 Dual Cassette Deck Single...
Kareoke machine. cd fine . tape no sound
With audio problems if you look inside the unit, start the machine playing, then trace the wires from the tape head to the PC Board, then all you need do is touch the wires from the head with a small screwdriver. This should cause a buzz in either channel, if working right. Follow the circuit of the audio and keep probing. If you get Buzzing sounds near the output, and where the wires from the head enters, then there's something up with the head. But check for micro switches these can break and bend out of place so the sound is cut off.
If you get no buzz at where the head wires enter the PC Board, then there's a fault in the audio section.
As both channels are out you are looking at something common to both channels, for instance an IC.
Feb 03, 2010 | Audio Players & Recorders
After the recent purchase and professional installation of a used Nakamichi CD 700, I noticed my front speakers weren't working. Activating the fader adjust I noticed that when I turned the knob...
I would recommend taking it back to the pro that installed it given it hasn't been to long. Also the deck should be warrantied and if the front side is not working I would consider that a faulty head unit. I know Nakamichi head units are not cheap.
Go back to the store you purchases it from or contact Nakamichi directly at the link below:
http://www.nakamichi.com/home.html
Sep 05, 2009 | Nakamichi Audio Players & Recorders
good luck
3rq8 (Triarcuate)
Jul 26, 2009 | Audio Players & Recorders
Soundspace 5 Right Channel Problem
Some thing has broken in the unit! Switch speakers around to make sure its not a blown speaker! If its not the speaker then your right channel control will need replaced!
please rate answer!
Jan 24, 2009 | Nakamichi SoundSpace 5 Shelf System
Nakamichi 680zx, no Naka Auto Azmuth control ?, should happer on its own.
Dear all Hi! I am a electronics engineer and I have Nakamichi 680ZX cassette deck, its FL indicators are not functioning. I had checked for both channels output signals on switch PCB. I had received audio signal on pin # 5 of IC 904 (RC4560D) on Indicator PCB C ***'y, further no signal on pin # 7 but (-)10 Volts DC with respect to ground, of the same IC. I would appreciate if you could guide me to rectify the problem. Please also note that I have complete full service manual for Nakamichi 680ZX. Best Regards Muhammad Ali Shah
Senior Manager Service & Technical Support
AVS, Lahore Pakistan
Cell # 0300-8859964
Jun 24, 2008 | Nakamichi Audio Players & Recorders
Nakamichi cd45z
The CD45z does not play MP3's ....Nak is about SQ ...since MP3's are poor quality ...this doesn't fit with what Nak is about.
Mar 03, 2008 | Nakamichi CD-45Z CD Player
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
66 people viewed this question
 Grubhead
Grubhead
