Question about Sewing Machines
Bernette 334d will not make chain stitch. I recently replaced a broken horizontal shaft gear. Think the timing maybe off. Help please.
    Champion:
  • 208 Answers
Email me kendourof@yahoo.com and I will email instructions
Posted on Oct 21, 2013
4 Suggested Answers
  • 30 Answers
SOURCE: looking for download of manual for bernette 334d for uni student
You could check this site and see if they have it.
https://www.2instructions.com/search.php?cmarque=BERNINA&modele=334D%20BERNETTE
Posted on Jun 22, 2009
  • 184 Answers
SOURCE: Can I get a free
Hi!
Here's a link for you, there are a lot of scanned manuals for bernina/bernette machines.
http://www.berninausa.com/news-n862-sUS.html
Hope it helped.
Posted on Aug 20, 2011
SOURCE: Replacing broken gears on Singer Touch & Sew Model 648
Remove the plastic faceplate from the front of the machine. There is a Singer logo button that you will have to pop out to release it, and then the lever nobs to get around to get it off. You can then access the allen screw on the top gear.
Remove all the set screws on both the top and bottom gears on the vertical shaft. Put them in a safe place.
The vertical shaft sits directly below the horizontal shaft, but there is some space between them and wiggle room to do the following. If the shaft does not slip down easily, use a small diameter rod or screwdriver to gently tap the vertical shaft downward until the top gear slips off the end. Remove the gear.
Posted on Dec 17, 2011
My bernette 334d overlocker keeps missing picking up the thread of the lh needle. Is this an adjustment? The other stitches are OK brian
if it has independent thread tensions for each thread , increase the tension for the problem needle thread
May 15, 2017 | Sewing Machines
How do I set my Bernette 334D to overlock thin T-shirt material?
Thin, light-weight fabrics present some issues with sergers, ie the fabric tunnels with the stitching. Usually, it is better to use a narrow seam. Also, a stabilizer (wash-away) or even adding a strip of thin paper (toilet tissue, adding machine tape, etc) to the seam will help the fabric hold its shape when stitching. I have also sprayed & ironed heavy starch on thin fabrics to help stabilize.
sewing patternreview com
Serging Chiffon and Other Slippery Fabrics
Make It Handmade Understanding Your Serger Features
30 Best Tips for Sewing Knits with Serger Sewing Machine Serger Pepper
Jul 02, 2016 | Sewing Machines
How to time a bernina bernette 334d
........... not a job for a DIY er - really. Difficult to do and getting it wrong will cost you $ to replace loopers ......
Oct 18, 2013 | Bernina Bernette 75
I have a Bernette 334d that I replaced a broken horizontal shaft gear. Everything is turning but I cannot get it to make a chain. Think the timing is off. HELP!!!
Hi
If the timing is out, to be honest, you need to get it done by someone who is experienced. It is not a simple job - there are many steps in the process and it must be done very accurately in order for it to function correctly. Timing a sewing machine is childs play in comparison.
Cheers
Need spares cutting blades for bernette 234 overlocker
Bernina Bernette 334D Overlocker - recent service identified the nylon gear cog inside overlocker is broken, Do you know where I can buy a replacement.??
Jan 06, 2013 | Sewing Machines
Bernette 334D bent lower looper
The bent looper needs to be replaced. It is also very likely that the machine has been knocked out of time. Professional service may be needed to get it working again.
Dec 21, 2017 | Sewing Machines
Find a gear part to repair my Bernett 334d
Has the horizontal shaft gear (white nylon gear) inside your overlocker failed? Does it look like this?
http://www.sewingpartsonline.com/horizontal-shaft-gear-bernina-bernette-50141103.aspx
My repair man obtained this part from Bernina and was able to repair this although it is a labour intensive repair requiring pulling down the whole machine to do. But the part itself was only $US38.
You can buy from sewingpartsonline as per link above.
Or you could ring Bernina head office in your country and talk to someone about it as I was initially told my machine was unrepairable as this part was not available by a local store who wanted to sell me a new one. I guess in light of the 4-5 hour repair time, this is probably a valid call if you buy a new plastic serger but I love my Bernette and felt it was worth repairing, not junking it. It is now 5 years later and still going strong since that repair. My OSMG (old sewing machine guy) Ken told me that the nylon gears sometimes will just crack, even if the machine hasn't had lots of work, just plastic ageing.
Hope this helps you - please rate me 4 thumbs up if so. Cheers
Jun 22, 2011 | Bernina Sewing Machines
334d Bernette Overlocker
went to local berinina shop and purchased booklet for 10.95 aus dollars
thankyou feona
Jun 14, 2009 | Bernina Sewing Machines
Bernette Deco 600 makes loud noise after stitching
hi! there,
open needle plate if the shuttle race and the bobbins has been pull out that making noise,or accumulation of thread under bobbins, if nothing there, run machine and check if shuttle race and bobbins are moving,also with the needle if not,there are opening at the bottom of machine try to open if some gears are broken,or belt is slip.
if broken gears there a lot of parts before you can pull out gear, beside the timing order you cannot put back.this should be done by technician expert
in sewing machine.take this to service center.
cheers have a nice day just rate me.
Apr 09, 2009 | Bernina Bernette Deco 600
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
