Question about Wagner SMART Edge Roller
Wagner smart edge roller worked fine out of the box. Now I'm trying to use it a second time and the roller won't roll freely. Too much friction from the snap fit to the dispense head. Any ideas?
    Problem Solver:
  • 5 Answers
Usually when a roller doesn't roll freely it's because it wasn't cleaned well. Be sure all dried paint is removed from the area where the roller attaches to the arm. A little WD-40 usually loosens it up too.
Posted on Dec 10, 2013
How can I fix a electrical spray gun that does not spray but makes noise like its going to spray.
R D, I think the spray nozzle is blocked with previous paint job. I would try soaking it in paint solvent for a few hours to see if it helps. Use the cleaning brush to clean as much as you can all the channels where you see paint. good luck.
May 20, 2014 | Wagner Spray Tech Model 242 Electric...
Power is not coming on
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
I have an HP Deskjet F4280 All-in-One printer. It will not grab the paper to print. I have tried some solutions that I read on a site to shut the power off, turn the printer on/off button 10 times, wait...
The feed rollers are probably dirty. look inside where the leading edge of the paper sets, the feed roller are right above..might only be 1 roller. Put some rubbing alcohol on a rag (not a tissue or paper towel) and clean the roller. It will only roll one way.
Hope this helps
Apr 06, 2011 | HP DeskJet F4280 All In One Printer InkJet
It wont print at all and when it is the paper suddenly get all clogged up whyy and what can i do?
If your printer jams paper every time you try to print then there are two options, either the paper you use is wet (higher percentage of dew easily piles up if you have the paper boxed out for a while) or the paper is thin (usually the standard printer paper is 80 grams per square meter, if you use thinner paper it can get clogged because it can't get passed on from the intake rollers onto the ejection rollers.
The second option is that your printer's rolling mechanism is dirty/greasy. You'll need to open up the printer by lifting up the cover as when you're replacing the cartridges, and wipe the rollers with a dry cloth. You may need to do this several times before the rollers have enough friction to be able to pull the paper out and eject it onto the tray for printed paper.
Jan 15, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
I bought my son an old fashioned hot dog roller for Christmas. It worked great the first time and the second time he went to use it, the rollers wouldn't roll. I've read several reviews on this product...
The 5 rollers are operated by 9 small gears that a run by the center gear which is turned by the motor on your machine. The gears in between the rollers help drive the next roller as you move outward from the center. The gears are made of what looks like pot metal, (cheap junk). The teeth break on the gears easily and either stick or won't operate the next roller. You can take the unite apart using a thin screw driver an pry the 6 flange on the drive side and straigten the flange with needle nose plyers. It then prys apart. If any teeth are broken, you can only buy a whole new grill part from Nostalgia Electrics. Cost is 20.00. They won't just sell the junk gears
Jan 06, 2011 | Nostalgia Electrics Hot Dog Grill Roller...
Thickness Planer (DW733) leaves fine scratches on wood surface.
It sounds like your blade holder assy has become misaligned on the blade drive shaft. Try if you can to use a straight edge on 2 planes 90 deg apart and see if there are any gaps in either of the srtaight edges. I suspect that the blade drive holder has become slightly dislodged from the drive collar on one end allowing the blade drive to tilt on the drive shaft. I had the same thing happen on another brand named Planer and it was a matter of reseating the collar to cure the stripes. Sure took a long time to sort out. Good Luck.
Feb 06, 2010 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Belts breaking frequently
I had the same problem. Broke 2 belts before I got online and noticed this site! What I found was, the roller ends were not turning freely. I had cleaned the hair (nasty) off the roller, but the ends were still not able to spin around without some force.
What I did was, removed the roller and on the 2 ends there are 2 black plastic caps which fit over the bearing, I removed the plastic caps and put a little WD-40 on the bearing, or any industrial lubricant, even new motor oil will work. After putting on the WD-40, I spun the roller end around a few times and the WD-40 lubricated the bearings and Voila! The roller end spun freely!! I put the black caps back onto the bearings on both sides, reinstalled a new belt, it's been working great since.
It saves the cost of a new roller.
Todd M, Fremont CA
Feb 28, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Brush roller stopped rolling
My daughters is doing the same thing and the plastic at the ends of the brush bar melted just enough for it not to turn properly. You might want to chech that.
Nov 25, 2007 | Eureka 2961AVZ Bagless Upright Vacuum
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Wagner SMART Edge Roller Logo
100 people viewed this question
Top Wagner Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Wagner Tool and Hardware - Other Expert? Answer questions, earn points and help others
