Question about Neurosmith Together Tunes Soft Musical Cube by
I need a battery cartridge for a together tunes cube that plays old mcdonald, pop goes the weasel, itsy bits spider, wheels on the bus. It's my granddaughters favorite toy and somehow the cartridge is missing
How to treat a spider or ? bite.
Most spider bites are not really spider bits at all. There are small critters like bed bugs that can be picked up on a train,bus etc. You will not see them,you will see the bites.
Then there is a bacteria that can cause this too.
If it is not getting better consider a clinic. If it gets worse go right away. If I knew what area you live in I may have had more info.
For now keep the area clean and dry. Odds are it is a minor issue. Most of all, don't panic.
Oct 27, 2014 | Health & Beauty
At 4000 rpm engine management light comes on and and starts to splutterpp
in what vehicle ? light sputters or engine? does the check engine light come on? did you check for engine codes? most chain auto stores check engine codes for free!
Jan 11, 2014 | Taylormade Taylor Made Rossa Itsy Bitsy...
I have a lexmark T520, just replace the old cartridge because it was leaving ink marks down sides of paper, smudges. Replaced with the new cartridge and it makes a loud popping noise. Now it's giving an...
Hello thanks for using Fixya
A 929 Service Toner Sensor error indicates a problem with the toner sensor, the front harness cable, or the developer drive. It could also mean that the toner cartridge is defective.
The most likely cause of this error is the toner cartridge itself. This is especially true if it is a new cartridge and the error started after you installed it.
To solve it try this:
Take the cartridge out of the printer and locate the encoder wheel on the right-hand side of the cartridge. The encoder wheel can be found on the right side of the cartridge (usually over a bar code sticker). It is a thin, black, plastic wheel with small rectangular notches cut into it. This wheel will sometimes get stuck, but you can free it by turning it by hand.
Try moving the wheel forwards and backwards a little. If it does not turn correctly, you will receive a 929 Toner Sensor error on the printer when you try to use the cartridge it is attached to
Note: The encoder wheel moves only a little bit each way. It should not make a complete revolution. If it does, the wheel is probably broken.
Try to move it a little bit each way a couple of times to see if you can free it up. Caution! DO NOT force the wheel as you could break it.
If the wheel on the toner cartridge is stuck, try another new toner cartridge. ( If you do not have another new toner cartridge available, an old toner cartridge or another cartridge from a working printer of the same model will also suffice for this test.)
Power the printer off and install the second toner cartridge. Then power the printer back on. If another toner cartridge clears up the 929 error, the printer is fine and the problem is with the toner cartridge.
If the error does not clear, there may be a problem with the printer.
If you narrow down the problem to the toner cartridge, call the point of purchase and explain the situation to them. They may have a replacement policy.
If you receive this error with a second toner cartridge, you may want to check if the Front Harness Cable is plugged into the Toner Sensor then Do the following:
Turn off the printer and remove the toner cartridge.
Look inside the printer at the place where the cartridge goes (on the right). You should see the Toner Sensor. On the back of the sensor assembly, you should be able to see a white cable connector.
Push this white cable connector into the toner sensor assembly by pushing the connector towards the front of the printer.
If you continue to receive the 929 error the final option is your printer will probably need service.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Feb 11, 2011 | Lexmark T520 Laser Printer
How do you replace the rear axle seal?
Its easiest to buy a hanes manual for this vehicle for this repair. Here goes. Remove the tire and wheel. Remove the drum if drum brakes or brake caliper and rotor is its disc brakes. remove the cover on the rear differential. remove the small bolt that holds the lock pin in place. slide the lock pic out of the spider gears. **its very important not to let the ring and spider gears turn at this point or the spider gears will fall out of the carrier. Once the lock pin is removed then go around to the axle where the tire was and push it in (toward the rear end) as far as it will go. Go back to the differential and remove the retainer clip (looks like a big "C") from the axle shaft. You can now pull the axle completely out of the housing. At this point you will be able to see the axle seal and the wheel bearing located behind the seal. Carefully remove the old seal (be sure not to damage the wheel bearing) and install the new one. You can then put everything back together. Make sure to refill your differential with oil when everything is back together. check your owners manual for the exact gear oil that you need because these cherokees can use different types depending on the model and towing capacity.
Oct 09, 2010 | 2002 Jeep Grand Cherokee
Putting it together
Ok these are tricky, so what you need to do is check your poles and connectors. You should have long poles and assorted connectors.
A bit of mathematics and you'll have it done in no time.
Ok lay out the poles and sort into longs and shorts.
Sort the connectors into 2 pole connectors (straights) and 3 pole connectors (three way)
Now check the angles on the three way connectors, sort them into groups. some should be slightly angled, these are the roof connectors and the others ones are 90 degrees and or more squarish these are the floor corner connectors. There should be 4 floor corner connectors and There will be two connectors that fit onto the end of roof front and back of the tent.
Sort out your poles and work out how many you need for each dimention. Basically your tent is a cube with a triangular prism on the top so you will need enough poles of even length to make the base and top bit of the cube and then even lengths of poles to make the upright sides of your cube. There should also be 4 four way connectors for attaching the roof. the top of you cube is the base of the triangluar prism.
Hope this helps. TIP once you get this together, MARK the conections with NUMBERS EG: 2 / 2 / 2 one number on each bit (the connector and each pole that is attached to it), this way when you pull it apart you can reconnect it much easier later on.
Feb 03, 2010 | Pacific Play Tents Train Station
How to change a 2006 Nissan Murano rear wiper balde
There are two ways. You can replace the rubber cartridge by simply removing any retaining clips from the end of the blade and sliding the old cartridge out, then sliding the new cartridge in and reclipping. Replacing the entire blade isn't that difficult either. Tilt the wiper back from the window so you can see where the blade pivots on a pin with clips holding the pin. Gently pry the wiper out from the clips on either side of the pin(you only need to pry on one) while pushing the blade in toward the wiper cover. It should pop out of the clips with a small amount of effort. You'll then have to weasel it out but it comes out pretty easily. Take off any adaptor that comes attached to the new 14" wiper and install.
Mar 28, 2009 | 2006 Nissan Murano
Microsoft Wireless Optical mouse 2.0 Sticky central wheel
I just took mine apart to fix same problem, works much better but not sure for how long.
Quite simple to dismantle the unit.
Take the battery cover off, remove batteries.
There is a small screw in the middle of the battery cavity, you will need a very small Phillips head screwdriver.
Gently ease the base (holding circuit board) from the top shell
The wheel unit can be gently eased out of its cradle, use the small screwdriver to pop it out, watch out for the small spring between base and wheel unit, don't lose it
You can disconnect the wheel unit from the circuit board by unhooking the small plug connector
Now defluff, then clean the wheel - I used a tiny amount of turps on a cloth, anything similar should work. If you look closely the reason the wheel won't roll smoothly is that the gel ring on the wheel is too close and rubs at the front and back of the cradle. Once grime builds up, this problem makes the wheel unusable. Roll the wheel back and forth along a clean surface once cleaned, should start rolling freely again.
I also unscrewed the top shell from the mouse buttons (all one piece, pinch the plastic pegs in the centre of the shell together to release) and cleaned the whole unit up before putting it back together
Don't forget the spring when putting the wheel unit back. When screwing the base to the top shell make sure there is no play between the two parts before you put the batteries back in, mine was a bit tricky to get tight again but worked fine second attempt
Sep 07, 2008 | Microsoft Standard Wireless Optical Mouse
Pop goes the weasel
I agree. The monitor probably blew a capacitor.
Time for a nice new LCD monitor.
Dec 14, 2007 | Computers & Internet
Neurosmith Together Tunes Soft Musical Cube by Logo
47 people viewed this question
Top Neurosmith Toys Experts
ray gallant
Are you a Neurosmith Toy Expert? Answer questions, earn points and help others
