Question about Food Mixers
What type of gear oil is in my hobart model 4412 meat grinder. it is very old.
2 Suggested Answers
  • 3 Answers
SOURCE: hobart meat grinder,model 4322 asking what type of oil in gearbox to use?
You can buy food grade grease from kitchenaid or on amazon. I did use the grease from my work. Any grease would do the job just make sure you read the specifications to find the grease that can stand high heat so it doesn't melt while the machine is running.
Posted on Dec 14, 2011
I am looking for a wiring diagram for Hobart 4822 grinder
Ask direct. not available online.
Electrical Installation; Electrical Connection - Hobart 4822 Installation ...
https://www.manualslib.com > ... > 4822 > Installation and operation manual
  1. Cached
Hobart 4822 Manual Online: Electrical Installation, Electrical Connection. The Electrical Installation Of The Chopper Must Conform To The Local Electricity...
[PDF]4822 MEAT CHOPPER 4822 MEA T CHOPPER - Hobart
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F7515.pdf
  1. Cached
  2. Similar
Page 1 of 2. 4822. MEAT CHOPPER. 701 S Ridge Avenue, Troy, OH 45374. 1-888-4HOBART ... CORD AND PLUG: A 6 foot, flexible 3 wire cord is furnished with the ... CAPACITY: 4822 will grind 16 lbs. per minute, first cutting through a 1?8" ...
[PDF]CATALOG OF REPLACEMENT PARTS
www.hobart.co.kr/data_file/4822Aug04.pdf
  1. Similar
4822 CHOPPER REPLACEMENT PARTS. F-43093 (August 2004). © HOBART. Table of Contents. 3. ELECTRICAL UNIT. 5. #22 CHOPPER ATTACHMENT ... wiring diagram for Hobart 4822 grinder Google Search
Feb 08, 2017 | Hobart Food Mixers
My Hobart grinder is old vintage it has 3 or 4 oil ports do I still use Mobil DTE HM OIL? How much in each port?
Steve I dont know that that is necessary. I have 2 a big heavy monster and a little #12 and I check for full and keep going. I only use mine in winter for sausage and its 50# in 120 sec. not much wear and tear on the lube. I know Hobart has a good web and mobile service here. Mine are Old and I'm guessing yours are too.
http://www.hobartcorp.com/
Jan 10, 2016 | Hobart Food Mixers
I have a hobart 4642 mixer grinder that s leaking oil Need help with diagnosing
can you confirm the model number and where the oil is leaking from?
Hobart make a 4246 and a 4632, but I am not familiar with a 4642
Feb 11, 2014 | Food Mixers
How to pull auger drive shaft for Hobart 4346 mixer-grinder?
The oil seal is the resistance you feel. take a soft mallet or hammer with a soft drift and gently but firmly tap the stub shaft and it will drive out the oil seal in the hopper direction.The lower skirt of the tapered bearing is what contacts the seal so go slow.
Worked for me.
Jan 23, 2013 | Hobart 4346 Meat Grinder Mixer Chopper...
Need to adjust clutch on hobart 4346 meat grinder how do you do it?
On the 4346 mixer/grinder the clutch can't be adjusted. It is a Moorse clutch and will need to be replaced. If you ate handy buy the rebuild kit for the bottom end from Hobart. It's not cheap but once it's done it will last for years. Hope this helps, Food luck
Dec 16, 2012 | Hobart 4346 Meat Grinder Mixer Chopper...
Hobart meat grinder,model 4322 asking what type of oil in gearbox to use?
Dec 13, 2011 | Food Mixers
I am looking for a place to download a manual of a Hobart 4812 meat grinder.
Parts and Owner/Instruction manuals are available at:
http://www.hobartservice.com/
Hobart considers Service manuals to be proprietary info and they are generally available only to "authorized" servicers.
All the best.
Oct 04, 2009 | Hobart Food Mixers
Hobart A200
Yes A-200 are number 12 I would find a hobart grinder they will have a big H in the casting on the neck get one with a stainless pan and stomper to push product down the throat. If you wait on Ebay and put it on your watch list they do come along. look for no rust. Make sure it has the big H in the casting. the other after market ones seem to not last long like the metal wears on the worm and hub to fast. also you always know where to get a piece if you need it if its a Hobart. not so with the forign jobs.
Dec 29, 2008 | Hobart A200 Stand Mixer
Black Residue on meat using Kitchenaid meat grinder attachment
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
