Question about Garden
Need advice on how to prevent mice from bedding down inside engine cowl.
    Sergeant:
  • 330 Answers
A friend of mine uses Downy dryer sheets. Apparently, the mice avoid them like the plague. I use them in my fifth wheel trailer over the winter. Let me know if this helps!!
Posted on Oct 18, 2013
Getting water in carbs not from fuel tank it happens when I put it in forward it's a 140 evinrude looper
Your engine should be sealed enough to prevent this..unless you have the engine mounted so low it idles under water...???.. There is a seal that goes between the lower cowl pieces and the engine, a seal around the engine cover(cowl)...and seals that surround all wires and cables.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Jul 14, 2017 | Boating
How to screen off cowl drain to block mice from entering interior of car
need to kill the mice or find a better place to park. even if you block this entrance they will not stop. I have seen whole electrical systems, vaccum sysyems. destroyed by mice. interior ect. get some poison and traps bated with chocolate. if you don't want to kill them find some traps and relocate them to a far away feild. if they are anywhere near your vehicle they will chew on anything and everything they can.
Jul 17, 2015 | 2004 Toyota Corolla Sedan
My 11 yr old wets to bed sometimes what cani do
seek medical advice from paediatrician
in the meantime simple things to do are that child uses bathroom prior sleeping and use a plastic mattress protection to prevent damage
Mar 24, 2014 | Health & Beauty
I need to know where the fuse is located
Hi and welcome to FixYa, I am Kelly.
Look inside the cowl on the same plane as the clutch / brake pedals. There should be a rectangular fuse recepticle with a 20 Amp plug in fuse. Just look up and down inside the cowling using the clutch / brake pedal as a reference point to start searching, You will find it. If the fuse keeps failing you will have to start chasing clutch / brake switch wires, PTO clutch wires, and Seat switch wires. Most of the time the failures are at or near the switches. As for the PTO clutch... belts over time slap the wires of the PTO clutch and either chafe the wires or break them at the PTO clutch.
Engine overspeed on this model also causes the engine alternator to fail the fuse.
Thanks for choosing FixYa,
Kelly
Apr 28, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How to replace heate core 1988 buick reagal
REMOVE OR DISCONNECT
  1. Negative battery cable.
  2. Drain cooling system.
  3. Upper firewall weatherstrip.
  4. Upper secondary cowl.
  5. Heater hoses from core.
NOTE Blowing out residual coolant from inside the heater core will prevent coolant leakage into the passenger compartment when the heater core is removed.
  1. Sound insulator.
  2. Rear seat duct adapter.
  3. Heater duct.
  4. Heater core cover.
  5. Heater core.
INSTALL OR CONNECT
  1. Heater core.
  2. Heater core cover.
  3. Heater duct.
  4. Rear seat duct adapter.
  5. Sound Insulator.
  6. Heater hoses to core.
  7. Upper secondary cowl.
  8. Upper firewall weatherstrip.
  9. Fill cooling system and check for leaks.
  10. Negative battery cable.
Oct 21, 2010 | 1988 Buick Regal
I need to install a new ignition coil in my 1998 ford windstar. How do i do this?
You can sometimes (if you have 2 elbows on each arm) reach around the back of the intake manifold and replace the coil pack using a 1/4 inch rachet with a 7mm socket.
Most of the time you need to remove the plastic cowl assembly located under the windshield wipers. To do this remove both wiper arms by lifting the plastic covers at the bottom of each wiper arm. Remove the 15mm nuts that hold the wiper arms down and wiggle the arms while pulling upwards until they come off (take note of which is left and right, they are different sizes). Next remove the plastic phillips screws/ plastic rivets that hold the cowl down on the bottom towards the engine(the screw comes up half way and when you pull up the base/ rivet comes up with it).
Next pull up on the cowl where it meets the windshield left or right side and you will hear the retainers snap and release. Continue pulling until the cowl is loose. Next disconnect the hoses that go to the washer nozzles. Put the cowl aside.
Next remove the micron filter located on the passengers side of the cowl (if it has one it is a good time to replace it). Remove from left to right 8or 9 8mm bolts that hold the lower cowl down. On the drivers side disconnect the 8 pin connector for the wiper motor. Now disconnect the washer fluid hose that goes thru the cowl on the passengers side. Lift up on the cowl and you should be able to wiggle it out and set it aside. You can now see the coil pack behind the intake manifold. Take note of spark plug wire location on the coil pack because they have to go back on in the same order.. Reassemble in reverse order. Note that while the cowl is off it is a great time to replace the spark plugs on the back of the engine.
Good luck to you and congratulations for doing it yourself
Apr 04, 2010 | 1998 Ford Windstar
2000 silverado wipers only work on high
Hello, this is a very common problem on this model vehicle. Your wiper motor control module is bad and will need to be replaced. The motor is underneath the "cowl vent" at the rear of your hood. You need to pop the cover cap off the windshield wiper arms, then unbolt the wiper arms and remove them, they are tough so spray some WD-40 on them and pull and wiggle. Now at the rear of that plastic cowl at the two rear corners lift up that flap and unscrew those 2 screws, one at each end. Next remove the clips at the front of the cowl, just pull them forward. Now lift up the cowl and unplug the washer hose. Just a word of advise, lay the cowl in the bed so nobody steps on it. Unplug the electrical connector going into the module which is mounted directly to the wiper motor and unbolt the module. Bolt on the new module. Test the wipers now and if all is well, put the cowl and wipers back on and you will be done.
Mar 01, 2010 | 2000 Chevrolet Silverado 1500
I have a '93 coleman, cedar tent trailer with a broken rear bed. The bed extends through the end of the track and comes off the rail. I'm looking for a diagram, parts list, and repair advice.
I have the same issue. It looks as though the rivets broke off. I have yet to reattach the slide mechanism. Normally the slide mechanism is stopped by a peice of emtal about 1./2 the way down the slide. Either new rivets or some flush head screws might sole your issue.
Oct 19, 2009 | Coleman Sport & Outdoor - Others
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
