Question about Kenmore Dryer Timer Switch 3391658 Model M460-G
My dryer will not shut off when done. Is my timer shot?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
HELLO
SOUNDS LIKE THE TIMER IS THE PROBLEM.
Posted on Oct 18, 2013
Dryer runs thn shuts off before done
bad motor windings shuts off after 20-30 minutes right?
May 22, 2014 | Frigidaire Dryers
Maytag ldg26cs gas commercial dryer never shuts off, runs normally and drys clothes but never stops or goes into cooldown mode.
Sounds like timer is stuck in one place and not counting down, can it be done manually? If so replace timer.
Dec 15, 2013 | Maytag MDG7600AW Gas Dryer
My dryer will not stop running
Timer motor might be shot. Check it for continuity. If you cannot get a reading then your timer needs replacement. If the timer motor is fine check the heating element for short to frame.
Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2012 | Kenmore Dryers
The dryer works and heats up but it won't shut off
I believe that your timer has run out of time! ;) Seriously though, Your problem is more than likely your selector (the dryer timer knob) is worn out. Time to replace it with a new one.
Good Luck my friend!
Phillip
Dec 27, 2011 | Whirlpool Washing Machines
Knob does not automatically turn so dryer does not shut off
Reach inside and clean these sensors so the mini-board can sense the dampness and power that timer motor towards the finish line. 73ce909.jpg
If that don't do it next grab the mini-board, yank it out and clean the corrosion on the contacts. If yours does not have sensors then the system relies on control thermostats to move the timer motor. If your dryer ain't a fancy model then the timer motor is simply shot.
Feb 27, 2010 | Dryers
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
My dryer shuts off before it is done with the drying cycle there is still time on the timer by the dryer quits
1 all dryers have a cool down cycle from 15 minuts down
if this is not the case does it stop at the same place everytime
if it does you need a new timer
Oct 08, 2009 | Dryers
Dryer doesnt shut off,stays on
Change your timer
Mar 24, 2009 | Dryers
Timer and Shutoff
Go for the timer. The timer is nothing but a bunch of contacts and some minor electronics. When the timer reaches the end of it's cycle, it closes a set of contacts which sends power to the buzzer, which could be bad, therefore continued buzzing. If the timer continues on to the next cycle either the electronics or contacts are shot. This is also age dependant on the dryer how the timer is built. You might go into price shock depending on model. This is not ruling out that if you have a buzzer on off switch might be bad, but I doubt it. Hope this helps. If you are unsure and are good at reading schematics and a meter, then you can be sure.
Jan 09, 2009 | Dryers
Dryer keeps running
hi,
okay, the timer wont shut the dryer off right? okay so maybe a a stuck start button, unplug one of the leads after you start it, unplug the lead and advance the timer knob to off and see if that was it. higher end dryers have that auto dry sensor feature that is supposed to shut it off when its done. Study the wiring diagram and find the circuit for autodry feature and disconnect one of the leads off that thermostat try that
J
Jun 24, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore Dryer Timer Switch 3391658 Model M460-G Logo
66 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
