Question about Proform Exercise & Fitness
The console works, the incline works but the belt will not go around
    Top Expert:
  • Proform Master
  • 12,223 Answers
See the video attached. Lube the rollers bearing too , front+back.
If the problem persist, test the control board +motor see my personal TIPS.
God bless you
Posted on Oct 19, 2013
3 Suggested Answers
  • 42 Answers
SOURCE: NordicTrack T5.3 belt stopped working. It's only 1
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
Posted on Nov 21, 2010
ercupa190
  • 12223 Answers
SOURCE: tredmill wont start
http://www.youtube.com/watch?v=23ZgWaVEQjA ( speed sensor)
Watch this videos tips: for motor
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
you must check the Transforme, i am giving tip for to do that.The transforme is for control for board of incline motor. See the fuse or breaker for incline motor board, or some wire loose.
See carefully the videos.
Posted on Nov 13, 2011
Have reebok 8500 ES has been stored turns on but does not respond to console ,it as if they are not speaking to eachother
Maybe check for a reset button around the motor/ belt drive. Manually roll the belt a little to free up motor if it's been sitting awhile.
Sep 03, 2015 | Reebok 8050 ES Treadmill
CONSOLE HAS NOT LIGHTS
Can you change the illumination setting like in a car? The lights are most likely LEDs which dont just burn out. and are independent.
Apr 05, 2014 | Exercise & Fitness
Just got Nordictrack 1750. Assembly was easy but incline does not work. Everything else seems to be okay. Took motor cover off and do not seem to be getting any power to incline motor.
go HOOD cover motor follow the steps or ready your owner manual, and RUN the software calibration for easy diagnostic and fix it.
The
Steps for Newer Style Console Calibration
1. Locate the calibration area on the
rear or underside of the console (a hole, near the console\'s center, that goes
through to the electronics board. (This hole should not have a screw in
it.)
2. Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click when
pressed).
3. Press the button 2 times
(with the pencil eraser). The first click should show CL11 in the
console, the second click should show CL21.
4. If the process was done correctly,
and CL21 appears in the console, you are in "calibration mode."
The next few steps consists of pressing buttons on the console
and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in
the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in
7. Press ENTER. CL24 should display in
8. Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should
display in the TIME window. You should then see the letter
"E."
10.
Press
ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be
off, the treadmill.
12.
Push
the ENTER button. The walking belt should start to move, accelerate to maximum
speed, then stop on its own.
13.
When
the belt stops, the incline should self test by raising to its
highest incline position, then lowering back down to its lowest position.
14.
Once
the incline test is complete, push the POWER button 2 times. The unit should
shut off and the console should go completely blank. If this
happens, the treadmill is done calibrating and is ready for use.
If the letter
"F" appears in the SPEED or INCLINE window when the power button is
pressed 2 times, the treadmill is indicating a failure somewhere
either in the SPEED or INCLINE (depending on the window the
"F" appeared in). Troubleshooting the failure would be the next
step.
God bless you
Oct 17, 2013 | Nordic Track Exercise & Fitness
I have a Proform 1026 EXP treadmill that began running at full speed whenever it is turned on. The incline controls function normally but the belt speed is incredibly high. When set to 1.5 MPH (the slowest...
please run the Software calibration see the instruction.
GOD BLESS you
The Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 18, 2013 | Proform 1026 Exp Treadmill Motor Control...
Horizon treadmill won't incline
Step 1:
see the diagram attached.
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
X9i incline trainer clicking
Step 1:
RUN the calibration software . and fix it. God bless you
Step 2:
Feb 07, 2013 | Nordic Track Incline Trainer X9i...
Tempo 621T treadmill incline Incline reads 0.0 but is not all the way down. How to bring it down.
you must RUN the software calibration, for troubleshooting and fix it.
See the steps.
The Steps fhor Newer Style Console Calibration:
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the
    1. F" appeared in). Troubleshooting the failure would be the next step.
Jan 09, 2013 | Exercise & Fitness
Treadmill belt runs too fast and will not power off with control panel
Step 1:
test the speed sensor,m for open or faulty, clean it, and tight the connector. see the diagram attached.
However follow the steps for RUN the.s calibration for fix it.
God bless you
Step 2:
The Steps for Newer Style Console Calibration:
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Jan 07, 2013 | Exercise & Fitness
Treadmill wont speed up
RUN the software calibration for diagnose, and fix it.
God bless you
Jan 06, 2013 | Exercise & Fitness
We have a 600 mx and the pad is not working, the only button working is the start, i cannot increase speed or incline it either.
It is very unusual to have no incline or walking belt operation..
Try entering diagnostic mode and do a calibration. The instructions are found under the motor cover on a tech sheet.
1: with the safety key removed, press stop and speed up simultaniously.
2: Attach the magnetic safety key.
3: press stop 1 time.
4: at this time, by pressing the incline up, the incline should calibrate, going up to maximum then back to minimum..
5: press the speed up key, you will see the numbers on the console increase. The machine should start moving the walking belt around 25-30 on the display. At 85 the belt should be running at maximum speed.
6: press speed down, the machine should stop.
7: remove the safety key. Now replace the safety key and try the machine again.If any of this procedure didn't work, I would suspect a defective console. Otherwise, the motor controller may need replacing.
Good Luck
Dec 14, 2010 | Epic 600 Mx Treadmill
Exercise & Fitness Logo
29 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
