Question about Exercise & Fitness
Everyoung treadmill 86800
How do I lubricate the walking deck. any other basic maintenance?
    Top Expert:
  • 12,223 Answers
See the video attached. and lube the rollers bearing front+back.
God bless you
Posted on Oct 19, 2013
  • 85 Answers
SOURCE: Noisy deck on proform treadmill
If you can take the machine apart, perhaps replace the deck, if replacement isnt possible try coating it with a polyurathane in order to help reglue the fibers togeter. particle board WILL degrade over time with stress especially running.
Posted on Oct 04, 2009
SOURCE: Have the same problem with my Everyoung Treadmill
End up dismantling the unit and disposing everything except for the motor and belt and rollers. Was a good machine except for no parts support.
Posted on Dec 31, 2009
  • 18 Answers
SOURCE: lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Posted on Mar 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a noisy Pro-Form Model 285T treadmill
Hey Richard Depending on the noise it could be one of several components failing. If loud clanking or clunking noises these components are Drive Motor, Front or Rear Rollers.
If it is a loud humming noise increasing and decreasing when planting yours feet then it is either the Inductor ( square object ) or the internal windings of the Drive Motor.
Unplug your unit remove the motor shroud with a long shaft flat tip screw driver you'll be able to pin point the problem with this tool.
Now locate front shaft and rear roller tension adjusting bolt ( refer to owners Manual) plug in unit, start unit and touch flat tip on the shaft and place your ear on the handle the noise will be amplified and you will be able to locate the noise repeat this procedure on the other above mentioned components if problem is not found. GOOD LUCK!
Posted on Jul 31, 2010
jyackle5
  • 8197 Answers
SOURCE: I have an Ironman treadmill
If the belt is off center about a 1/2 inch you will need to adjust the belt. On the link below page 19 will tell you how to adjust it. If this is not your model Can I please get the model # so I can get you the right info. As for the weight yes they are rated to 350 lbs. so your weight is not the cause.
Posted on Sep 21, 2010
Lubricating walking belt
Video about How to Wax a Treadmill Using Powder Wax
How to Wax Treadmill Using Powder Wax Video
How To Re-Wax a Wood Deck for a Trotter Treadmill
How To Re Wax Wood Trotter Treadmill Deck
Video of How to Lubricate a Treadmill using Liquid Lube
How to Lubricate Treadmill Using Liquid Lube Video
Apr 02, 2014 | Exercise & Fitness
What kind of lubricant fdo you use on treadmill decks
Silicone spray. Did you put it between the deck and the underside of the running belt? Not on the surface of the belt ( where you walk ) . if you put in on the top of the belt , then this is why it is slippery.
Nov 24, 2013 | Bh Fitness TS1 Treadmill
My treadmill walking belt move but when I stand on it it stops, but the motor is on
Dear Sir:
This a problem from worn deck vs deck belt.
The cause is lubrication and lack of maintenance. That produce enough friction, that design of electronic system shut down the machine for to protect the electronic design.
Lubricate in according with your user manual, section Maintenance.
Try to run the software calibration for easy diagnose and trouble.
See my personal TIPS for help.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a
Mar 21, 2012 | Exercise & Fitness
Treadmill cutting off while running
Dear Sir:
Thank you by your request.
This happen when the lack of lubrication between deck vs walk belt, in other words, NOT maintenance.
2) the lack of lubrication produce friction ENOUGH between deck vs walk belt, for that reason the electronic design protect the electronic circuits and trigger the shut down for to protect the electronic.
attached is my block diagram design for diagnose and troubleshooting.
sincerely. God bless you.
ernesto a cuadra
managua, nicaragua. c.a.
Jan 05, 2012 | Horizon Fitness T102 Treadmill
I have an IRONMAN 220T treadmill and have a code # E11 and I do not know what it mean, can anyone help me with this.
E11 Means that deck bel or walk belt is slower speed that speed window .
2 possible causes:a) Locked rotor from main motor b) High friction from deck or walk belt.
3) Use the calibration software from your equipment for easy diagnostic and correction.
4)Use the owner manual or your step under the Hood ,and proceed with the steps indicated.
5) You can lubricate the Deck or Walk belt. please see your owner manual section: Maintenance.http://www.youtube.com/watch?v=f7IZWMMrCM0 please see this videos for easy help in lubricating. and adjusting deck belt treadmill.
http://www.youtube.com/watch?v=AZSMLpXm-tA
sincerely. Merry Chrstmas.
ernesto cuadramanagua, nicaragua.c.a.
Dec 22, 2011 | Ironman 220t Programmable Treadmill (225...
Treadmill shuts off in middle of workout
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Aug 09, 2010 | Precor 9.31 Treadmill
My treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 08, 2010 | Proform Crosswalk 500 Treadmill
Treadmill maintence
Here is a typical guide for maintenance their may be a slight variation from different manufacturers all in all the same.
NOTE: To prevent electrical shock, be certain the treadmill is turned off and unplugged from the electrical outlet before performing any cleaning or routine maintenance. TREADBELT LUBRICATION For average use of your treadmill, factory recommends you lubricate under the treadbelt once per year. For heavy use, which is more than 10 hours per week, factory recommendation is lubricating every six months. . LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes. CLEANING DAILY: Perspiration should be wiped from the control console and treadmill surfaces after your workout. CLEANING WEEKLY: You should wipe down your treadmill once a week with a water dampened, soft cloth. Be careful not to get excessive moisture between the edge of the digital display panel and the console, as this might create an electrical hazard or cause the electronics to fail. IMPORTANT: DO NOT CLEAN OR WIPE THE TOP OF THE DECK UNDER THE CENTER OF THE RUNNING BELT. MONTHLY: Clean dust and dirt that might accumulate under and behind your treadmill once a month. Small rubber particles from the soles of walking shoes will accumulate alongside the belt and also behind the unit
Apr 27, 2010 | Exercise & Fitness
Where do i put lubricant in my reebok treadmill t5.1
To lubricate your treadmill, start by lifting the edge of the walking belt and spread the lubricant between the belt and deck. Once you have finished on one side, do the same to the other side. When you finished both sides, start the treadmill at around 3 mph. Then walk on the treadmill to spread the lubricant on the deck for about a minute. Then your done.
Apr 19, 2010 | Exercise & Fitness
Lubricating a treadmill
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Exercise & Fitness Logo
154 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
